Old 10-25-2014, 01:33 PM   #1
DarkSunrise
DarkSunrise's Avatar
Minimum HPDE Brake Pad Thickness
Does anyone know what the minimum recommended brake pad thickness is for a two-day HPDE? I pulled the front right brake pads on my car today:
It ranged from 4/32 - 6/32" (3.2mm - 4.8mm) -- left to right in that shot.
Here is the other pad:
The only recommendation I could find was 5/32" for a single track day, so I assume I should replace these before my next track weekend, but just wanted to make sure.
And a few other pics I took, in case anyone sees any problems:
Small chunk missing here:
Shot of the rotor:
Thanks!
2022 BRZ Build
2013 FR-S Build
Old 10-25-2014, 02:35 PM   #2
wparsons
wparsons's Avatar
I would definitely get new pads before a two day event, most schools suggest at least 50% of original thickness as a guideline.
What pads are those? I would suggest something that takes heat better, those look like they've been overheated and melted.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
CSG Mike (10-27-2014), DarkSunrise (10-25-2014), zdr93523 (10-28-2014)
Old 10-25-2014, 02:44 PM   #3
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Probably best to state the compound along with all of your braking components, and then ask for input from other drivers running that same compound under similar circumstances.
It's all about the compound, how it tends to wear down, and the sort of braking demands the track and driver are placing upon the ducted/un-ducted brake system. Remember that one major purpose of the pad is to act as a heat sink, so somewhat thin pads like yours demand a top-quality fluid if the driver is using the braking system hard, and it looks like that's the case here.
Based upon the depth you currently have, I think you'd want to have a spare set to throw on in case those pads prove insufficient for the length of the event. The existing chunking is relatively minor. The lower section of the rotor indicates that you may have some pad smear in that region (indicating you've overheated the pad), but I'm not 100% sure that's what it is.
FWIW, and this is definitely in do-not-try-this-at-home territory, I've run one manufacturer's pad down to super-thin thickness and still had sufficient braking effect to continue with the DE. Some compounds don't tolerate thin pads very well - they just give up.
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
Old 10-25-2014, 03:18 PM   #4
jvincent
jvincent's Avatar
No way I'd go to the track with those. Time for some new pads.
The Following 3 Users Say Thank You to jvincent For This Useful Post:
DarkSunrise (10-25-2014), SubiePig (10-28-2014), zdr93523 (10-28-2014)
Old 10-25-2014, 03:48 PM   #5
DarkSunrise
Thanks guys. I ordered another set of front pads to be safe.
BTW these are Stoptech SP pads. Brakes are otherwise stock. Held up better than expected, but I'll probably go with Carbotech XP8 or XP10 next.
2022 BRZ Build
2013 FR-S Build
Old 10-25-2014, 10:48 PM   #6
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Definitely new pads for a two day event. I would also go with new rotors, especially if you change to Carbotech pads. You may be able to use inexpensive rotors like Centric Plain 120 series rotors. I have had good luck with these.
The Following User Says Thank You to Black Tire For This Useful Post:
Old 10-25-2014, 11:24 PM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Yah, those look thin. One problem with thin pads is that you conduct more heat into the caliper. Less insulation there. Some pads wear longer though, like the PFC 08
The Following User Says Thank You to EAGLE5 For This Useful Post:
DarkSunrise (10-28-2014)
Old 10-25-2014, 11:39 PM   #8
ayau
Drives: Some rust bucket
I'd change those. I have some Project Mu Club Racers front and back that were only used for one event. They have over 90% pad left. Don't need them anymore because I sold the car.
The Following User Says Thank You to ayau For This Useful Post:
Old 10-27-2014, 09:20 PM   #9
Definitely need to step up the pads. They're being overheated and smeared onto your rotor.
DarkSunrise (10-28-2014), wparsons (10-27-2014)
Old 10-28-2014, 01:43 AM   #10
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Are you still using the OEM fluid? If so, I highly recommend upgrading to Torque RT700.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
The Following User Says Thank You to zdr93523 For This Useful Post:
Old 10-28-2014, 08:54 AM   #11
DarkSunrise
I was actually thinking the same thing. Will probably do a full rotor swap this winter to new Centric blanks. Thanks for the recommendation.
Yeah I could see some smearing on the front left rotor as well when I pulled that wheel. I'm thinking about Carbotech (or Winmax, which I think you had good experience with) next. Haha you'll probably see a PM from me in a few months asking for a recommendation.
Thanks I was on Stoptech STR600 fluid and actually downgraded to ATE Type 200 (i.e., Superblue) this past season. I haven't had any issues with brake fluid boiling yet with this car. I'll keep the RT700 in mind though if I start running into issues.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
CSG Mike (10-28-2014)
Old 10-28-2014, 10:26 PM   #12
Gen3MR2
Gen3MR2's Avatar
Drives: 93 MR2 gen3 3sgte, 13 FR-S
I would definitely replace those pads, even if I wasn't going to an HPDE. Also something I like to do even if I am not changing brand or compound is to take the rotors off and clean them up really good with brake cleaner, just to try and get the old bedding off the rotor.
Just my 2c.
Instagram @gen3mr2
Gen3MR2 is offline   Reply With Quote
Brake Pads and Fluid For DD/AutoX/Track Days/HPDE ToyoburuBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-23-2016 03:59 PM
Track-Only HPDE Brake Pad recommendations. Stock platform/calipers/rotors fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-20-2014 12:03 PM
HPDE / Brake Pads milhouse Tracking / Autocross / HPDE / Drifting 7 03-13-2014 01:15 PM
HPDE Brake Pads & fluid Gopherboy6956 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 04-25-2013 10:18 AM
Minimum requirements... Blokatos Scion FR-S / Toyota 86 GT86 General Forum 528 11-15-2011 04:04 PM
