Old 07-03-2017, 02:29 PM   #687
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by wooly35 View Post
That's good news that you are just enjoying the car now. Ive got a few more issues to resolve before I consider mine finished, but I cant wait to drive this car everytime I come home from work. Its so much fun.
Still trying to figure out the can bus module. Everything is hooked up, but nothing works on the dash. I'm sure its something I did and need to look over it again.
I'm not to worried about AC and power adders just yet. lol The car has plenty of power as is. Maybe this winter ill add long tube headers. For now, I just want to enjoy having my car back.
Which PCM are you using?
MRS Install is uploading. I have debated heavily on whether to post it or not. It makes me cringe watching it. Not mention I sound like I am 12. Just going to do it anyway.
Old 07-03-2017, 02:47 PM   #688
wooly35
Drives: 2014 Scion FR-S LS3
E38
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
Old 07-03-2017, 02:57 PM   #689
DustinS
DustinS's Avatar
E38
Try plugging the red wire in to pin 8 that it suggest wrapping up. Had the same issue.
[ame="http://youtu.be/0gm3DYVS5iA"]http://youtu.be/0gm3DYVS5iA[/ame]
The Following 8 Users Say Thank You to DustinS For This Useful Post:
-Phil (07-05-2017), cf6mech (07-04-2017), FRSToyota86 (02-13-2018), gtpvette (07-04-2017), MRS-Colin (07-05-2017), Sportsguy83 (07-03-2017), wooly35 (07-03-2017), Zer0 (07-03-2017)
Old 07-03-2017, 03:49 PM   #690
all4spl
Not sure. Taking it to my friends shop to see what they say. He told me to bring it in and they should be able to work it out.
Not many updates with the car. I have mostly been driving it and enjoying it whenever I can. No A/C is kind of rough, and still unsure about the valvetrain noise and vibrations, but runs pretty darn good.
Doing Research on gauges, and power adders lol.
Waiting to hear back from Colin on a possible update with the Canbus Device to help clear my CEL. Maybe/hopfully my gas gauge? Though I still don't think it is a can bus error. Just stops running at about 1/4 tank, and 1/4 is 10 gallon fill up. Which means 3 gallons is still left in the tank. Do believe the MPG calculation are a bit off. Car said I was getting 40mpg on my trip to KC and I made it to about 170 miles before I had to fill up.
Not sure how I forgot to mention it here, but the friday I was leaving for the Car show 3 hours away, I was rushing to get a bunch of stuff done and forgot to plug in my O2 sensors after taking the exhaust off. Didn't remember until half way through the trip. We stopped off and I found I had melted one of the plugs, so I needed a new O2 sensor. The other one had fallen down out of harms way, but where I couldn't get it while the engine was hot. So I just cruised the rest of the way without it. I was really wondering why it was smelling rich, found the reason haha. Still needing to replace the melted one, just had no motivation here lately. Mostly because its 90+ with a humidity level through the roof.
Looking at AIM MXS Strada
I actually have a group buy going on the Aim dashes right now if you want to hop in?
all4spl is offline   Reply With Quote
The Following User Says Thank You to all4spl For This Useful Post:
Zer0 (07-03-2017)
Old 07-05-2017, 08:34 AM   #691
MRS-Colin
Drives: 2001 Impreza 2.5 RS
Thanks for the video Dustin!
Sorry I've been scrambling on other projects that distract from the fun BRZ/FR-S stuff
Waiting for some more Micro Gateway modules (the one used in the swap) to come in from production and then we can exchange your module to remove the CEL. Worked with Rick to verify we turned it off but it seems that my documentation on the CEL's trigger is wrong for the E40 set. So at the moment I can turn it off but possibly not on when it needs to be. When Rick is doing better we can figure it out
Mind if we share the video?
@wooly35, where was your PCM sourced from? I'm beginning to find that GMPP base LS3 PCM's all use the E40 message set but uprated engine packages (LS376 etc) use the E38. Connect the spare Fast-On terminal to location 8 to tell the device to use the E40 message set. If you have lost vehicle speed then there is an error in the wiring somewhere disrupting the CAN bus.
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following User Says Thank You to MRS-Colin For This Useful Post:
DustinS (07-05-2017)
Old 07-05-2017, 06:59 PM   #692
wooly35
@MRS-Colin
The PCM is for my ls3 376/480 crate motor I ordered from GM. I don't have it wired up to a key on source right now. Ill get power to it and see if the speedometer stops working. I'm just not crazy about opening up my dash again to get to the PCM. I like driving the car to much to work on it. ha ha ha
The Following User Says Thank You to wooly35 For This Useful Post:
MRS-Colin (07-06-2017)
Old 07-06-2017, 12:09 PM   #693
all4spl
I'm still stuck on trying to find a good mounting solution that wont fit like shit lol.
The Following 2 Users Say Thank You to all4spl For This Useful Post:
DustinS (07-06-2017), Sportsguy83 (07-06-2017)
Old 07-10-2017, 12:02 PM   #694
DustinS
DustinS's Avatar
Testing out an air box around the filter. Final product will be built with either ABS Sheet, or aluminum. Leaning towards ABS to help with any heat soak issues. Also very easy to work with. With the box/scoop in place Air temps are generally the same as outside temps or a few degrees less. I will be testing the temps without the airbox and with the scoop today on the way to the bank. Testing without both on my way back to work. Will be interesting to see.
The Following 4 Users Say Thank You to DustinS For This Useful Post:
civicdrivr (07-10-2017), Sportsguy83 (07-10-2017), Summerwolf (07-13-2017), wooly35 (07-10-2017)
Old 07-10-2017, 01:39 PM   #695
DustinS
DustinS's Avatar
With the Airbox and Scoop. Intake temps were within a degree of outside temps. Idling temps were about 20-30 degree over ambient.
With airbox removed scoop still in place, intake temps were about 20 degree higher than ambient. Idling temps were outrageous at 150-170 depending on how long the car sits.
Scoop removed temps jumped to about 30 over ambient while moving.
Air Box is a definite must in this case.
The Following 6 Users Say Thank You to DustinS For This Useful Post:
all4spl (07-10-2017), civicdrivr (07-10-2017), Ramn (09-08-2017), Sportsguy83 (07-10-2017), wooly35 (07-10-2017), wutsaiu (07-10-2017)
Old 07-10-2017, 06:47 PM   #696
wooly35
looks like I need me an air box and scoop. lol
DustinS (07-11-2017)
Old 07-10-2017, 11:45 PM   #697
cf6mech
Drives: FRS Silver LS1 swapped.
@MRS-Colin
Feel your pain, Colin's had me do it a number of times to the point I just leave the glove box off LOL!
cf6mech is offline   Reply With Quote
Old 07-10-2017, 11:47 PM   #698
cf6mech
Dustin you have me rethinking my Vorshlag CAI arrangement.....can really tell when the Texas heat is up around here. Big power loss.
The Following User Says Thank You to cf6mech For This Useful Post:
DustinS (07-13-2017)
Old 07-13-2017, 04:48 PM   #699
DustinS
DustinS's Avatar
Forgot I followed another V8 swap FRS on facebook. Today they posted about traction control and ABS all of a sudden working again. Trying to figure out of the lights just turned off as it has canbus system back up and running, or if they actually are working again. I am assuming they just took the fact the lights are off and the traction light flashes at them that it works again, but doesn't actually control anything.
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (07-13-2017)
Old 07-13-2017, 09:14 PM   #700
cf6mech
Mad Panda Australia?......if so the guy doing his can bus I have worked with before,.....well at least trying to get his translator to work.....must frustrating weekend ever....never did get it to work, and wasted easily 20 hours on it.Finally found Colin through a friend in Seattle.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
