Drives: 2013 Ultramarine FR-S
Another V8 Swap (Now 2jz/DCT)
With the impending release of the Vorshlag Swap kit, I have strayed from my Twin Charged FA20 Plans and started putting together my list to put in a crate LS3 over winter. Simple plans of CNC Heads and a decent Cam at first, with a turbo down the road. Eventually looking at 600-700whp (eventual plans had I kept the FA20 as well)
Current List: TSP Turnkey Forged LS3 - Still deciding on which to go with. Improved Racing Baffled Front Sump oil pan swap kit Vorshlag Stg.0 Swap kit (Brackets/mounts, Driveshaft, Long Tube Headers) Vorshlag Custom T56 Magnum XL Vorshlag Tilton Master cylinder/Slave cylinder setup MRS Can Device ACT Clutch kit w/ Lightweight Flywheel Oil Cooler set-up Assorted Fuel Fittings Greddy Evo GT 3" Exhaust Vibrant 18" Resonators Planning on starting to order things Monday. I have flip flopped on what parts I am wanting to go with quite a bit. Changed between the LS3 and a LS7 four or five times now. So I am giving myself a bit more time to really think it over. Though I am almost positive I won't deviate from the current plan/parts list at this point.
Drives: 2013 satin white brz limited
I love a good mod thread just as much as the next guy but if this is the route you wanna go why not just start with a corvette and go from there?
Because I already own the FRS and I don't want a Corvette. I will be in the LS Swap for less money than I would the Twin Charge set-up and I will get almost the same powerband N/A. This also takes care of the poor transmission.
| The Following 2 Users Say Thank You to DustinS For This Useful Post: | funwheeldrive (03-14-2017), Nick_ysl (11-22-2016) |
I guess LS swaps are cheaper then I thought as I would expect it to cost more to swap and get working properly then it does to just start out with a ls vet.
Normally. Yes. I wanted a broad power band with 500-600whp on the FA20. My plans were an Element Tuning Built FA20, Cosworth Supercharger, and GTX4088R. Should have netted around 500whp with a wide powerband, if not more. So my FA20 plan cost ALOT. They actually came up just about even, but being able to sell all my current FA20 parts brings the end total down.
I was sort of looking forward to where you went with the FA20.
Builder/Driver/Enthusiast
Drives: 2013 FR-S 6MT Turbo Firestorm
+1 the engineer in me really wanted to see the bi-charge set-up documented properly. But the realist was glad it wasn't my money going for it.
Better choice in the end for LS swap for reliability I think. Watching all these build threads for when my motor goes.
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig |
| The Following User Says Thank You to RedFR-s For This Useful Post: | cdrazic93 (10-21-2016) |
I must admit I am torn as well, but the more I thought about it, the more difficult it was going to be to get it done completely right. There were a lot of variables that made the LS swap a much more solid choice.
Panda Trueno
Drives: No twin now.
Why go fresh crate motor? You could be cheaper off with a bottom end since you're changing a lot of the surrounding parts anyways.
#10 |
From what I have priced out, It's about the same either way. If you have links/suggestions, please feel free to post.
#11 |
Panda Trueno
https://www.texas-speed.com/c-3188-a...d-engines.aspx
I considered a stroker from them and they were super helpful. Otherwise, tick performance, TEA, BTR.... the list of lsx performance providers is a mile long. |
#12 |
Drives: frs
I would like if you track every part price so i can figure out how much cost at the end. Considering this route as well when fa20 blow up. Also my concern are related to drive train, and the cost of custom job to fit it. Best wishes and good luck
#13 | |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
#14 | |
Panda Trueno
If he is keeping it strictly NA I don't think a cast iron block would be beneficial. The aluminum blocks are proven to add little weight to this chassis, and are durable enough for FI in the future. 600-700 NA is achievable, but will take more than you think to make that at the wheels and still be completely livable on the street. |
| The Following User Says Thank You to Summerwolf For This Useful Post: | DustinS (10-21-2016) |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) — General Topics | 13 | 03-22-2016 03:07 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 11:14 AM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) — General Topics | 8 | 06-12-2012 07:32 PM |
