Old 10-21-2015, 05:30 PM   #1
protpibe
protpibe's Avatar
Rod Swap
Does anyone have experience swapping rods on an FA20?
My spare motor has a bent rod, and I'm finally getting around to having time to be able to swap it out. I remember reading that it was designed in such a way that you didn't need to split the block to replace a connecting rod. Can anyone with experience confirm this?
I'm assuming you go in through the oil pan, remove the front chain cover, and then the bottom portion of the block?
Help and insight is appreicated
Old 10-21-2015, 06:46 PM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I don't think you'll be able to remove the wristpin without pulling the head too. But ya flip it over on your motor stand and remove the oil pan and timing cover.
I would crack the case open and check all the main bearings though. Who knows what the shape of them are and it's not worth all that trouble to skip not cracking the case to save time. You might find yourself removing the engine because of something else.
Bearing kits are cheap.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
protpibe (10-21-2015)
Old 10-21-2015, 07:00 PM   #3
While you are in there take a look at the oil galleries and such.
http://www.ft86club.com/forums/showt...40#post2425140
Old 10-21-2015, 09:50 PM   #4
humfrz
101 refresher (in case ya need it) ......
http://www.revvolution.com/blog/2014...he-fa20-4u-gse
humfrz
Old 10-21-2015, 10:50 PM   #5
celek
Resident Gear Head
celek's Avatar
You have to pull the heads the rods and Pistons come out the sides. This not like an EJ block with wristpin access holes.
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Old 10-21-2015, 10:52 PM   #6
protpibe
protpibe's Avatar
Thanks for the info guys.
God there's a lot of sealant on these motors lol.
Old 10-21-2015, 11:38 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
If I see any more pics of that mess... Uggh.
I'm ready to tear into mine just to clean out all that shit. Not joking.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
2JZ Swap Kit? Moe23 Engine Swaps 37 10-27-2016 07:04 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
BRZ Swap!!!! EnviedIke Engine Swaps 59 07-30-2014 06:32 PM
2jz swap p3raltaboi Scion FR-S / Toyota 86 GT86 General Forum 54 06-11-2014 08:09 PM
