#15 |
That is pure genius! I will not forget that.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Scrappydoo (06-24-2017) |
#16 |
Señor Member
That is a sucky place to have a crack :-/
Does the crack extend to the block or is it only in the threaded section? If it's only in the thread you might get away with a thread sealer like loctite 567 or 577 but it will have to seal below where the crack starts. Good luck.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | Ultramaroon (06-25-2017) |
#17 |
Building on @Turdinator's idea a thought just occurred to me. There is a nice little shoulder down below the threads. It might be possible to get a good seal between the plug and the case with a fat o-ring or some sort of gasket.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Turdinator (06-25-2017) |
#18 |
Drives: 2013 Black FR-S 6A
Loctite is a good idea, my only problem with it is the stress you might put on that crack trying to get it unthreaded in the future. But I think the more permanent resolution should be machine shop/welding wizardry
| The Following User Says Thank You to Syche For This Useful Post: | Ultramaroon (06-25-2017) |
#19 | |
Señor Member
The 577 and 567 are just sealants without the thread-locking. They are used in hydraulic and plumbing applications. That said, getting it welded is the best solution.
1974 TA22 Celica
2013 86 GT |
#20 | |
just spitballing. I would be most tempted to try this before resorting to high craftsmanship.
#21 | |
Ahhh the more you know Sent from my iPhone using Tapatalk |
#22 |
#23 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
is that the oil galley plug just below the throttle body?
| Gas Leak? | Fuco | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 10-07-2022 09:40 AM |
| Oil leak | GsxrMe | Forced Induction | 4 | 12-18-2015 08:23 PM |
| Yet another oil leak.... | Astroboy | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 09-24-2015 01:02 AM |
| Help - oil leak | tlim | Engine, Exhaust, Transmission | 4 | 04-10-2015 08:40 AM |
| A/T Pan leak | goke186 | Issues | Warranty | Recalls / TSB | 0 | 04-15-2013 10:31 PM |
