Old 06-23-2017, 10:19 PM   #15
Originally Posted by Scrappydoo View Post
You can always the old bodge of a greased tampon to stop swarf entering the journals.
A fresh one obviously.
That is pure genius! I will not forget that.
Scrappydoo (06-24-2017)
Old 06-25-2017, 07:53 AM   #16
Turdinator
Señor Member
Turdinator's Avatar
That is a sucky place to have a crack :-/
Does the crack extend to the block or is it only in the threaded section? If it's only in the thread you might get away with a thread sealer like loctite 567 or 577 but it will have to seal below where the crack starts.
Good luck.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Ultramaroon (06-25-2017)
Old 06-25-2017, 03:44 PM   #17
Building on @Turdinator's idea a thought just occurred to me. There is a nice little shoulder down below the threads. It might be possible to get a good seal between the plug and the case with a fat o-ring or some sort of gasket.
Turdinator (06-25-2017)
Old 06-25-2017, 04:46 PM   #18
Syche
Syche's Avatar
Drives: 2013 Black FR-S 6A
Loctite is a good idea, my only problem with it is the stress you might put on that crack trying to get it unthreaded in the future. But I think the more permanent resolution should be machine shop/welding wizardry
Originally Posted by 22R View Post
Now get off your Mom's computer and go wash the BRZ she bought you.
22R
Syche is offline   Reply With Quote
The Following User Says Thank You to Syche For This Useful Post:
Old 06-25-2017, 08:29 PM   #19
Turdinator
Señor Member
Turdinator's Avatar
Oring is actually a great idea
The 577 and 567 are just sealants without the thread-locking. They are used in hydraulic and plumbing applications. That said, getting it welded is the best solution.
1974 TA22 Celica
2013 86 GT
Old 06-25-2017, 08:39 PM   #20
I'm concerned about over-tightening especially if the o-ring is used to seal an adapter, not the oem plug. A thick composite washer might fare better.
just spitballing. I would be most tempted to try this before resorting to high craftsmanship.
Old 06-26-2017, 01:10 AM   #21
Syche
Syche's Avatar
Ahhh the more you know
22R
Old 07-15-2017, 05:37 PM   #22
So I need a new Engine....
/thread
Old 07-17-2017, 04:28 PM   #23
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
is that the oil galley plug just below the throttle body?
B T is offline   Reply With Quote
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 09:40 AM
Oil leak GsxrMe Forced Induction 4 12-18-2015 08:23 PM
Yet another oil leak.... Astroboy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 09-24-2015 01:02 AM
Help - oil leak tlim Engine, Exhaust, Transmission 4 04-10-2015 08:40 AM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 10:31 PM
