Old 06-11-2017, 11:24 AM   #15
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I see batteries with a lot of pressure often. Sometimes they build pressure bloat and start to stink of H2S. Those are the ones prone to going boom. The explosion isn't all that strong, but it'll spray acid and can hurt your eyes and burn you.
I don't know why, and most batteries have vent on the side, but it happens.
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
humfrz (06-11-2017), Ultramaroon (06-11-2017)
Old 06-11-2017, 04:58 PM   #16
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I thought the caps on most lead acid batteries had a breather hole ......
I thought it was a sealed for life battery. Haven't had to top up a battery for years
Scrappydoo is offline   Reply With Quote
Old 06-11-2017, 06:55 PM   #17
guybo
Huge E85 fan!
guybo's Avatar
A lo of "sealed" batteries just have a sticker on top of caps that screw in to plug up the cells and can be removed.
Old 06-11-2017, 07:04 PM   #18
Fred1
Fred1's Avatar
Drives: Scion Frs 2014
Might sound stupid, but adding water in the battery will not cause issue when freezing temperature?
Fred1 is offline   Reply With Quote
Old 06-11-2017, 07:23 PM   #19
The liquid that is already in the battery is mostly water.
So, a little "top off" of demineralized or distilled water won't hurt anything...... because what went away was water ..... not the acid.
Old 06-11-2017, 08:26 PM   #20
guybo
Huge E85 fan!
guybo's Avatar
Batteries can freeze when it's really really cold out. But it can thaw out and it won't be damaged.
Old 06-11-2017, 09:44 PM   #21
A fully charged battery will freeze at something like minus 80 in which case a frozen battery is the least of your worries.
A dead or very low battery can freeze at just below 32 and if it freezes solid will be toast.
Old 06-11-2017, 10:07 PM   #22
guybo
Huge E85 fan!
guybo's Avatar
Nope. I've seen perfectly good batteries freeze on a really cold night where it got down to the negative teens. Thawed out, was fine.
Old 06-11-2017, 10:20 PM   #23
Gforce
Drives: 2013 Subaru BRZ
All lead acid batteries generate hydrogen gas which is very explosive. That's why they all have vents.
Gforce is offline   Reply With Quote
Old 06-11-2017, 10:25 PM   #24
Gforce
Except for the time issue. Just as you can add water to cooling systems you can add water to batteries. However, to gain freeze protection the water must have a chance to mix with the "antifreeze". In the case of coolant the water needs to mix with the existing glycol mixture. This happens rapidly. With batteries it needs to mix with the sulfuric acid mixture. That takes quite awhile. Do not top up your battery in freezing weather, it can bust the case.
In reality, low maintenance batteries are worn out by the time they need water. Just replace it.
Old 06-11-2017, 10:26 PM   #25
Gforce
It is and you are correct. By the time a sealed for life battery needs water added it is totally worn out.
Old 06-11-2017, 11:15 PM   #26
Well, now, @Gforce ...... I think you are splitting molecules here. Yes, the specific gravity of sulfuric acid is higher that that of water and in a weakly charged battery, acid stratification can take place.
However, in a healthy battery (fully charged), since the added water is soluble in the existing acid/water electrolyte solution, and the amount of water added is usually relatively small, and a battery in a car usually gets jostled around, thus mixing the added water to the electrolyte ..... the chances of the added water freezing and busting open the case are very small.
Besides, I've been adding water to batteries in the wintertime (living in OH, MO, CT and Europe) for the past 65 years and never have had a battery freeze and bust open.
Clipdat (06-12-2017), Scrappydoo (06-13-2017)
Old 06-12-2017, 01:09 AM   #27
qqzj
Drives: MDX, Camry
65 yrs?
qqzj is offline   Reply With Quote
The Following User Says Thank You to qqzj For This Useful Post:
Old 06-12-2017, 01:51 AM   #28
Originally Posted by qqzj View Post
65 yrs?
Yep, I remember adding water to the battery on the NEW tractor (that had a battery) when I was 9 years old ....... which beat the hell out of hand cranking the old tractor (which didn't have a battery).
Oh yes, make sure the magneto wires were dry, get a 5 gal pail and place it near the crank, set the crank, jump off the pail onto the crank (being careful NOT to wrap your thumb around the crank handle) and hope the hell you get your body out of the way on the way down, in case that sucker kicked back.
With any luck, she would start on the second attempt ......
OK, it's time fer ma Metamucil, then off to bed ZZZZZZZZZZ
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Clipdat (06-12-2017), Tcoat (06-12-2017), Ultramaroon (06-12-2017)
Best two way dash cam that uses car battery and it's own battery? azynneo Electronics | Audio | NAV | Infotainment 14 01-22-2016 10:23 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 08:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
