Old 06-09-2017, 11:39 PM   #15
netram
Drives: Toyota 86
Originally Posted by Xxyion View Post
Still dont understand why everyone is drawn to the N1 as the first exhaust they want.
I'm going to admit it was my first choice as well. Luckily my mechanic told me it was a bad idea and never did it. It's just strange evertime i see someone say "buying a new exhaust!" its always paired with "Thinking about the N1!"
It's honestly probably the price point and the fact that on Youtube vids it actually sounds pretty good. But after driving a car that has the EXACT same setup the OP was suggesting...it's one of the worst things in the world. Cant talk to anyone, cant listen to music, basically deaf when getting out of the car. Drones at even the lowest of RPM driving.
What would you recommend for an exhaust? I was looking into the Greddy Evo
netram is offline   Reply With Quote
Old 06-10-2017, 06:06 AM   #16
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
IMHO join up with your local FT86 club and you can hear different exhaust systems.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 06-10-2017, 01:23 PM   #17
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Actually yes. The Greddy GT (newest version of the Evo) is amazing. Sounds deep and low and they reduced the drone from the Evo models. Only issue is that it hangs kinda low.
Also since you are getting headers try to look for an exhaust that is a bit quieter by itself. That will shape the tone much nicer. The Nameless is a good one. I run that. Also Perrin makes a great CBE
Sent from my Pixel XL using Tapatalk
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 06-10-2017, 02:51 PM   #18
netram
Drives: Toyota 86
Reason being for the Greddy GT exhaust is because the place I get my parts from is a dealer of both Invidia and Greddy. So really its just a throw up between N1 or Evo. But the N1 has a lot of hate...?
Old 06-10-2017, 10:02 PM   #19
86geek
86geek's Avatar
There's many other online websites to buy from like frsports.com which I believe ships to Canada. www.frsport.com
As mentioned if you're getting a header & the n1 your neighbors will hate you. Any aftermarket header your power train warranty will not be honored.
Aftermarket catback exhaust is fine.
Get a Perrin CBE & header then call it a day!
Or buy a single exit exhaust like Tomei cuz that sucka is hella LOUD & you want LOUD
Old 06-10-2017, 11:01 PM   #20
celek
Resident Gear Head
celek's Avatar
Originally Posted by tyler_win_photo View Post
And as for headers, it really depends if you wanna sound like a subaru or honda.
You mean make more power vs not, right?
celek is offline   Reply With Quote
Old 06-10-2017, 11:56 PM   #21
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
The power difference between UEL and EL is quite negligible with a decent tune tbh
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Token11b (06-14-2017)
Old 06-11-2017, 01:00 AM   #22
netram
Drives: Toyota 86
With the headers, UEL or EL which one makes more power? I know the EL has more high end while UEL is more low to mid range, Which one is preferred
Old 06-11-2017, 05:24 AM   #23
Xxyion
Lowly Cartuber
Xxyion's Avatar
Depends what you wanna do. Track a lot? Probably EL. You'll be driving close to redline almost all of the time. Daily Driver/Spirited runs/Car meets? UEL for the nice sound and usable mid range torque
Old 06-11-2017, 09:48 AM   #24
celek
Resident Gear Head
celek's Avatar
While true if you are looking at 1-2HP
BUT if you compare on a percentage if a EL makes 10 hp and UEL makes 9 is that not 10% difference in power.?
Old 06-12-2017, 04:20 AM   #25
netram
Drives: Toyota 86
Prob not gonna track a lot, just the usual daily drive with a couple friends and what not
Old 06-14-2017, 12:38 PM   #26
Timmy_Jones
Spun
Drives: 23' Supra
I like deep sounding and not as raspy. Not sure how this would sound, but I'm not getting everything all at same time. Prob the N1 first then judge how loud it is and move from there. First and foremost would be getting the exhaust system itself and I'm still conflicted on which one to get.
You're doing it backwards. Do the header first. Then a tune. Then the OP and front pipe. Then do the cat back.
Timmy_Jones is offline   Reply With Quote
Old 06-17-2017, 03:28 PM   #27
netram
Drives: Toyota 86
Doesn't the header void the warranty for your car though?
Old 06-18-2017, 12:05 AM   #28
Token11b
If you want a nice sounding subie rumble with no drone and very little rasp you could always run my set up.
1. Gruppe-S headers and over pipe
2. Perrin inlet Intake hose with drop in filter
3. Perrin 3" catback
4. Currently stock front pipe
It's not obnoxiously loud. Sounds great. It's a real head turner. It's quiet on the highway and only loud when I press the loud pedal.
2013 Scion FRS Firestorm- Current mods: Gruppe-S UEL Headers w/overpipe, Perrin intake tube w/drop in filter Perrin 3" catback, OFT stage 2 turn
Token11b is offline   Reply With Quote
Making some changes to exhaust, thoughts? Tysoncrosby21 Engine, Exhaust, Transmission 1 12-29-2016 09:19 PM
Exhaust? Thoughts? Whitesoul Engine, Exhaust, Transmission 37 07-16-2014 03:04 PM
thoughts on this exhaust setup Boofneenee Engine, Exhaust, Transmission 8 05-19-2014 03:03 AM
The New Tanabe Exhaust- Inputs and Thoughts JM Auto Racing Engine, Exhaust, Transmission 28 08-31-2012 04:40 PM
What are your Second Thoughts? slizoth Scion FR-S / Toyota 86 GT86 General Forum 22 04-05-2012 07:13 PM
