Old 06-10-2017, 09:38 AM   #1
Heavyax
Drives: 2015 Ultramarine Scion FR-S
Valenti 4th Brake Light Wiring
I just installed my Valenti brake light and it functions as a reverse light and brake light, but how do I get it to work as a running light when the tail lights are on?
I've looked at a bunch of install videos and all of them have different colored wires than the ones I have. I'm no expert on wiring so I just want to make sure I'm doing this correctly.
I've got a red wire from the Valenti harness tapped into the red wire on my tail light harness, and then the middle blue wire from the Valenti harness tapped into the teal wire on the tail light harness.
Thanks in advance!
Sent from my ONE E1005 using Tapatalk
Heavyax is offline   Reply With Quote
Old 06-10-2017, 09:54 AM   #2
Kravos
Drives: 2015 Scion FR-S
Have you tried that? I just installed mine few days ago and mine were reverse (red to blue, blue to red) only because I modded it for separate brake light.
Kravos is offline   Reply With Quote
Old 06-10-2017, 09:57 AM   #3
Heavyax
I didn't pop mine open to redo any of the internal wiring, but will give that a shot later today, thank you!
Old 06-11-2017, 07:39 AM   #4
Heavyax
You sir, are a gentleman and a scholar. That took care of the issue. Thank you.
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
Valenti 4th brake wiring problem andrewtgg Cosmetic Modification (Interior/Exterior/Lighting) 14 08-21-2017 08:10 AM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 11:57 AM
