Drives: BRZ JDL uel headers oft Perrin 2.5
quick gasket/ torque question
I recently installed JDL UEL catted headers and when I went to check the torque specs a day later the joint from header to over pipe needed tightening 26-27 lb. ft.. Some days later it sounded off and I found that it needed to be tightened again. It is a week now and it seems fine but if I do need to tighten it again, do you think that a metal gasket rather than the one JDL provided would work better? I don't know what the JDL is but it is a fiber of sorts and I expect will compress more than metal. The Grimspeed gaskets I used at the other connections never needed to be tightened again.
#2 |
My personal take is that it's not the gasket. It's the location. That joint sees the most cyclic stress/strain from the engine rocking.
Rather than focusing on the gasket, I recommend using decent locknuts. The type that has a little crown on top which is slightly coined/dimpled. Use them once. Someone with first hand experience may chime in but that's where I would start. Good luck. Hows the weather in Albuquerque? I'm a UNM alum. Lived there between '92 and '00. I miss Los Cuates and good green chile.
#3 | |
#4 | |
![]() ![]() humfrz |
#5 |
![]() No, six. I fucked around for a while on purpose. Took a bunch of other classes seeing if anything else clicked. It didn't but I deeply enjoyed the experience.
#6 | |
![]() Ya, I hear that. I started at Ohio State University in the college of engineering .... took me a year to figure out I wasn't smart enough for that. So, I transferred to the college of arts and sciences (Geology), decided there wasn't much demand for Geologists. Transferred to the college of agriculture ..... click. I was a year into graduate level courses when Uncle Sam decided I had enough college exemptions and told me to take my last ROTC course and accept my commission ..... or they would draft my ass as a private. Yep, took me 5 years....... ![]() humfrz Oh, yes, OP ...... lock washers are good things ....... it shouldn't take more than two tightening sessions ..... so, you are most like good to go. |
#7 |
Then you got a driver.
#8 |
#9 | |
Drives: 2005 Toyota Camry
Most aftermarket hardware gives you a locking washer, but people tend to torque it wrong after they apply the anti-seize compound. -alex |
#10 | |
| Calling all ARK GRiP owners: Gasket question | Kesler | Engine, Exhaust, Transmission | 3 | 03-24-2017 09:15 PM |
| Quick: Need torque spec for suspension component | FRStock | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 06-27-2015 11:11 PM |
| FI gasket question which to use? | IBill4You | Forced Induction | 4 | 06-22-2015 10:52 AM |
| low end torque question | BlueDubbinTDI | Engine, Exhaust, Transmission | 13 | 10-20-2013 10:50 AM |
| BRZ Donut Gasket same part as WRX STi Gasket? | Zadkiel | Engine, Exhaust, Transmission | 0 | 10-06-2012 07:22 AM |
