Old 06-27-2015, 12:01 AM   #1
FRStock
Drives: 13 FRS
Quick: Need torque spec for suspension component
Help! Putting together my car and I need the torque spec for this piece:
I think it's the trailing arm? Bottom of the picture, points to the bottom right. Starts in front of the wheel and connects to the bottom of the hub.
FRStock is offline   Reply With Quote
Old 06-27-2015, 12:24 AM   #2
bumppinKota
Drives: FRS!!!
check for it here? http://www.ft86club.com/forums/showthread.php?t=85760
not sure if its in there.
bumppinKota is offline   Reply With Quote
Old 06-27-2015, 07:53 PM   #3
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
I'll tack onto this thread as I need an ASAP type of answer.
Installing RCE yellows today. First install like this for me.
Jacked up car, removed front struts. No spring compressors. Hand tools. Took the strut into my lawn and stood on it and loosened top bolt. Quite difficult by myself, I should say.
Installed RCE yellow onto strut. End of coil up against notch at bottom of strut, more tightly wound end down. I compressed spring with my knee atop Top mount and hand threaded bolt on, and then began going at it. Problem now is that it will not torque down. Something is spinning.
If any saviors out there need more info, let me know. My thought is, if I leave it as is and put the car on the floor, will it maybe compress the spring a bit more and thus allow an extra crank or two where it might then torque down?
Very amateur at this stuff.
Thanks!
ajaxthebetter is offline   Reply With Quote
Old 06-28-2015, 12:11 AM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Thanks!
How did you remove and install the nut? Impact gun or pass through socket and allen key?
If you don't hold the strut in place the shaft will just spin and probably blew. There are two very good DIYs on this forum to explain the install without the use of spring compressors.
Install DIY
http://www.ft86club.com/forums/showthread.php?t=10842
Additional DIY for no spring compressor
http://www.ft86club.com/forums/showthread.php?t=32414
ajaxthebetter (06-28-2015)
Torque spec for lug nuts wrxneffect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 09-06-2016 09:39 PM
Torque spec for steering wheel nut? zooki Cosmetic Modification (Interior/Exterior/Lighting) 3 08-11-2015 03:14 PM
Oil pan torque spec? Astroboy Engine, Exhaust, Transmission 1 12-23-2014 02:43 PM
Camber bolt torque spec ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-09-2013 11:30 AM
OptionJDM- Cusco Suspension Component OptionJDM Brakes, Suspension, Chassis 27 11-09-2012 12:46 PM
