Old 05-09-2017, 01:45 PM   #43
tony-brz
tony-brz's Avatar
Drives: '17 BRZ PP
Originally Posted by justinco View Post
Another thing to add about ECUtek: It seems the RaceRom features (ie: launch control, flat-foot shift, auto-blip downshift, etc) do not work on the 2017 cars. I have done extensive testing with my tuner and cannot see to get them to work. Map switching via the cruise control stalk is also not working, we had to go back to the old style map switching, which works (gas pedal + defrost button).
Yeah those are not working on my car/tune either. Hopefully ECUtek is aware and releases a fix soon'ish.
For me the cruise control toggle "works", the tac responds and toggles through 1,2,3,4k but the features don't actually activate.
tony-brz is offline   Reply With Quote
The Following User Says Thank You to tony-brz For This Useful Post:
justinco (05-09-2017)
Old 05-09-2017, 03:06 PM   #44
Zentec
Drives: 2017 Toyota 86
So is it really worth it on 17 to get the tablet or ecutek tune? I understand if you add parts headers exhaust intake ect. But are the gains and new maps really put enough power to $. Could you really gain 10-15hp with all that?
Zentec is offline   Reply With Quote
The Following User Says Thank You to Zentec For This Useful Post:
R_E_L (06-29-2018)
Old 05-09-2017, 05:22 PM   #45
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I had an OFT beta tune on my 2017 car when it was bone stock. Even then it is definitely worth it. The tuning makes the most difference I think.
The parts have the added benefit of weight savings, which is quite a lot actually.
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
D_Thissen (05-09-2017)
Old 05-09-2017, 06:10 PM   #46
Zentec
Justin on your 17 stock car did you a couple hp gain with the oft tune or was it overall more smoother running? I agree a tune will make the most difference. If you up grade other things headers exhaust ect that's the only way to take advantage of those besides the weight savings. I'm weighing my choices now between ecutek and tablet. I'm leaning more towards the tablet now. Reason I ask is on my wrx I had Cobb ap and I saw a few hp gain and it ran so good after installed. I would like to see if the gains are silmilar to that of the ap.
I live in the desert and like you I can only get 91 out here. Rebel dose offer a pump race gas for cars its 100 octane. So when I fill up at half tank I put in 1 gal of the 100 to make 93 but this gets expensive as the 100 is 7.99 gallon. I use top shelf gas as I am still breaking in the car I got almost 4K miles on it now had it since nov of 16.
My main goal is longevity and dependability as I will have this car for a vary long time. I do want to extract the most out of it with keeping those goals. I will shoot for 220-250hp N/A and take my time getting there. So one of my first up grades was the tires but now I'm going to get an oil cooler thent I'll work on the tune. After my warranty is up then I'll start on the inside of the engine as that will be the only real way of getting close to that end goal.
Old 05-09-2017, 06:49 PM   #47
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
The OFT was great for me on my FRS, highly recommended. I went to ECUtek on the 2017 because OFT was not really supporting it heavily and I really wanted the RaceRom features (which ironically are still not working yet ).
I'd say grab a used/new OFT if you just need the basics. It will smooth out the torque dip and make the power delivery more linear. Your butt dyno will approve I am pretty sure of it.
220hp NA sounds a bit ambitious, especially on 91. But, I am not familiar with what the limits are for NA on these cars so I could be wrong.
Old 05-09-2017, 08:04 PM   #48
Zentec
I would be intrested in seeing and feeling a stock 17 Z and 86 to see the differences in each stock tune. I wounded if it has more or less between the two in the tq dip. I have driven my friends 14 frs and what a difference between the 14 and 17.
Old 05-09-2017, 08:17 PM   #49
invaliduser
Drives: 2017 86
Based on Shiv's new post about version 3.0 off the shelf tunes... it's looking like the official OFT tune for the 2017 USDM ecu will be out of beta when 3.0 gets out of beta.
Sent from my Pixel XL using Tapatalk
invaliduser is offline   Reply With Quote
The Following User Says Thank You to invaliduser For This Useful Post:
Old 05-09-2017, 11:06 PM   #50
steve99
Drives: FT86
Id think the tunes in the 86 and brz will be exactly the same as per previous years.
Some countries get the upgraded manual cars some dont, red manifold is the easiest way to tell if its the newer tune
Old 05-10-2017, 09:13 AM   #51
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by wparsons View Post
If the car in question has been tuned, then the AFR will be whatever the tune is commanding. If you're relying on the stock primary O2, it'll be different because it can only read so low without being re-scaled.
The log above AFR measured by vehicles 02 sensor, the 2017 tune calibrates it down to 10 afr.
The previous tunes only calibrated 02 sensor down to 12.17 afr so even if it ran way richer (which it did) you could not see the correct reading using the vehicle o2 sensor unless you flashed a tune with 02 sensor recalibrated to read lower afr. Or you had to use a tailpipe sensor, these usually read a little different to the vehicle 02 sensor that right near the exhaust port, tailpipe sensor usually read 0.5 to 1 afr point leaner from what ive seen.
Here is log of an older STOCK rom , note how the AFR just flatlines at the sensor reading limit of 12.17, its rearly running afr down to 10.8 or so
If Open Loop Fuel table has a value of 10.8 at 7000rpm at say 1.2g/rev engine load, then it would try target that AFR. However, there is no way for the ECU to know that it is achieving that value since there is no closed loop. It becomes an 'estimated' value and is also subject the AF#1 Learning Trims.
Here is a dyno result of a stock '13-'16 car. They show that the AFR is around 11.87 (blue line):
I don't know how they measured it. I'll ask them and let you know.
Old 05-10-2017, 09:28 AM   #52
steve99
Drives: FT86
Unless they rescaled the front 02 sensor in the tune (this is highly unlikely) they must have measured using an external sensor, likely a tail pipe sensor. These measure afr after it has passed through the two stock cats this generally results in leaner readings than actual. (0.5 to 1 afr point) so that correlates fairly well with the 10.8-11 values in the OL fuel tables.
The stock tune 2012-2016 sensor only calibrated to 12.17 so that's the lowest afr it will read.
Correct in open loop their is no feedback. But the ecu learns fuel trims in closed loop and apples these in open loop. The maf scaling to a large extent determines how close the commanded afr and actual afr will be during open loop operation. The old cars did run way rich as per the OL fuel tables, if you have a tuning device just flash a stock tune with the o2 sensor scaled lower and you will see.
Old 05-10-2017, 02:37 PM   #53
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Please don't draw conclusions without additional evidence. I asked them and when I have feedback I'll let you know.
I have a tactrix cable, but I don't have a plan to plug it to my BRZ.
Weird things happened when I plugged it last time to my Forester ...
Old 05-10-2017, 03:52 PM   #54
steve99
Drives: FT86
That chart you posted up says "Dyno Simulator" so what exactly is that ?
heres some other charts to look at
http://www.ft86club.com/forums/showthread.php?t=19413
Tactrix works fine used it hundreds of times, you can rescale your 02 and tweak your throttle tables as well :-)
The Following 3 Users Say Thank You to steve99 For This Useful Post:
D_Thissen (05-10-2017), FRSBRZGT86FAN (06-25-2018), phm14 (05-11-2020)
Old 05-10-2017, 04:57 PM   #55
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
I'm having the opposite affect. I can swap maps, but have to count in my head what map number I'm in since my tach doesn't move. I'm on a delicious tune and JRSC
Barefootdan is offline   Reply With Quote
Old 05-11-2017, 12:59 AM   #56
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They said that they are using a high precision air-fuel ratio meter: http://www.gtworks.ico.bz/Works.html
They build their own ECUs known as GENROM. Everything is internally developed:
stock tune only bolt ons dyno slow15frs Engine, Exhaust, Transmission 14 05-12-2016 12:42 AM
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 04:54 PM
My Dyno Tune Results brz961 Software Tuning 3 08-28-2014 11:43 PM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
Moar power with simple bolt-ons & ECUTek tune @ OnPoint Dyno l8apexr CANADA 23 04-25-2013 06:50 AM
