Old 05-05-2017, 02:12 PM   #1
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Dyno results : 2017 BRZ with bolt-ons & tune
Interesting results from my dyno session with the 2017 car. Largely the same as my 2013 FRS, but with some differences. Primarily, the 2013 FRS made less power stock, while the 2017 BRZ made more power stock. However, peak power was nearly identical between both cars. I was hoping the 2017's would gain more overall, but it looks like they are pretty efficient from the factory compared to the old cars and end up almost the same when you have similar upgrades.
2017 peak power, 91oct street tune: 182hp/147tq @ the wheels (altitude corrected).
Details in the video.
[ame="https://www.youtube.com/watch?v=iWcGW-wlOEg"]MODIFIED BRZ dyno power numbers - YouTube[/ame]
justinco is offline   Reply With Quote
The Following 5 Users Say Thank You to justinco For This Useful Post:
DAEMANO (05-05-2017), funwheeldrive (05-05-2017), gtengr (05-05-2017), randomthoughts (05-06-2017), reeves (05-05-2017), Teseo (05-05-2017)
Old 05-05-2017, 02:40 PM   #2
Infinity
Drives: 2016 Scion FR-S
I thought people were getting 190-ish with bolt-ons + tune. Is this tuned for 92 or 93 gas?
Infinity is offline   Reply With Quote
Old 05-05-2017, 02:51 PM   #3
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
He said it's 91 octane. That can attribute a lot to it. I've seen close to 200 whp with straight bolt ons and tune but they were running 93 or E85.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 05-05-2017, 03:03 PM   #4
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Yea, 91 is the best we have here. I will be getting a 100 octane tune at some point, so we'll see what that does.
There are so many factors that go into the dyno numbers. This is also on a mustang dyno which a lot of people will say reads low. I do this primarily to see the difference (gains) between the stock dyno, not necessarily peak power numbers.
Old 05-05-2017, 03:29 PM   #5
reeves
Being a mile up from sea level is a factor too.
reeves is offline   Reply With Quote
The Following User Says Thank You to reeves For This Useful Post:
funwheeldrive (05-09-2017)
Old 05-05-2017, 03:33 PM   #6
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Yes. Don't look at the uncorrected numbers unless you want to be really depressed
The Following 2 Users Say Thank You to justinco For This Useful Post:
reeves (05-05-2017), wparsons (05-05-2017)
Old 05-05-2017, 03:53 PM   #7
wparsons
wparsons's Avatar
The engines are internally the same, and the intake manifold doesn't make much difference from what I've seen. The bulk of the increase stock vs stock is the exhaust manifold and much better stock tune.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
Cole (05-06-2017), D_Thissen (05-05-2017), justinco (05-05-2017)
Old 05-05-2017, 04:07 PM   #8
Lantana frs
Drives: 13 frs red
179 is strong for stock, no?
Lantana frs is offline   Reply With Quote
Old 05-05-2017, 04:42 PM   #9
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Yes, I would agree. See wparsons reply above.
Old 05-05-2017, 07:26 PM   #10
Lantana frs
Drives: 13 frs red
Have you tried an ots tune?
Old 05-05-2017, 07:39 PM   #11
D_Thissen
D_Thissen's Avatar
If he had a custom tune done, why would he use an OTS? Unless you mean 'has he ever tried an ots tune'?
Old 05-05-2017, 07:53 PM   #12
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Right, this was a custom tune, which usually starts as an OTS tune and then modified.
I did have an OpenFlash OTS tune on this car early on, but that was just to begin. Also, my FRS ran on an OpenFlash OTS tune before we dyno tuned it.
The Following User Says Thank You to justinco For This Useful Post:
Old 05-05-2017, 08:02 PM   #13
Lantana frs
Drives: 13 frs red
I should've asked if it was remote tuned or done in house. My bad. Excellent video btw.
Old 05-05-2017, 08:04 PM   #14
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Ahh, this one was all remote e-tuned tuned with ECUtek.
My FRS we dyno tuned with OpenFlash/Romraider.
stock tune only bolt ons dyno slow15frs Engine, Exhaust, Transmission 14 05-12-2016 12:42 AM
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 04:54 PM
My Dyno Tune Results brz961 Software Tuning 3 08-28-2014 11:43 PM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
Moar power with simple bolt-ons & ECUTek tune @ OnPoint Dyno l8apexr CANADA 23 04-25-2013 06:50 AM
