Old 05-04-2017, 12:29 PM   #351
jerseymike1966
Drives: 2014 BRZ
Originally Posted by allowe View Post
Can you take a picture of your numbers by any chance to help others
I followed the 'High Rev Cold Start Noise Reduction in this thread'.
http://www.ft86club.com/forums/showthread.php?t=74754
The hard part was finding a def to get to 'MAF Correction after Start'
That folder was not in the def for my tune so I got a def from
http://www.ft86club.com/forums/showthread.php?t=83945
You have to make sure the def cal id matches your cal id. I am new to this tunig so there are better people here to ask for advice.
jerseymike1966 is offline   Reply With Quote
Old 05-04-2017, 12:42 PM   #352
allowe
allowe's Avatar
Disable high Rev cold start
Omfg that's what I've been looking for for half an hour now!! (The maf correction crap). It's safe though right ? To use another definition?
allowe is offline   Reply With Quote
Old 05-04-2017, 01:09 PM   #353
allowe
allowe's Avatar
Originally Posted by Kodename47 View Post
Latest OFT C series? If so, then you can use !one and will have all the tables. I'm not on my laptop but you should be able to find them on here somewhere:
http://www.ft86club.com/forums/showp...0&postcount=23
are these tables safe? im using these and man theyve got way more options!
Old 05-04-2017, 01:16 PM   #354
Kodename47
Kodename47's Avatar
Drives: UK GT86
If your tune is based on B01C, most OFT ones are, then they are correct. You can use the BRZcheck tool to confirm.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-04-2017, 01:18 PM   #355
allowe
allowe's Avatar
mine is ZA1JA01C, i only edited the maf in gear and Neutral tables
Old 05-04-2017, 01:20 PM   #356
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's likely a B01C edited to fool the OFT into flashing it. Look here
http://www.ft86club.com/forums/showthread.php?t=109565
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-04-2017, 01:22 PM   #357
allowe
allowe's Avatar
Alright I'll check that asap. I got the tune from oft website. It's the ofh specific tune
Old 05-04-2017, 01:29 PM   #358
Kodename47
Kodename47's Avatar
Drives: UK GT86
@allowe as expected the tune is a ID hacked ZA1JB01C. My definitions are setup for that so you can use them without issue.
.: Stealth 86 :.
Kodename 47 DJ:
allowe (05-04-2017)
Old 05-04-2017, 01:35 PM   #359
allowe
allowe's Avatar
Dude thank you so much!
holy crap my car is so much quieter at cold start and I've got ofh and mxp exhaust. I work a night shift and I leave my house at 11:30 pm and comeback early in the morning. Now I don't have to wake up my neighbourhood anymore... until I hit the main road hehe.
Thank you all for your help!
Old 05-04-2017, 01:49 PM   #360
allowe
allowe's Avatar
Hey random question. What does everyone do after they flash they're ecu? I usually wait 10 minutes instead of 45 seconds while not touching anything and letting it idle by itself.
Old 05-04-2017, 03:12 PM   #361
Kodename47
Kodename47's Avatar
Drives: UK GT86
Turn on ignition (engine off) - Pedal to the floor 5 times.
Start engine and idle for 1 minute - can be 30 seconds if engine is already warm (oil 50C+) as the AVCS will reset and become operational quicker.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-04-2017, 03:16 PM   #362
allowe
allowe's Avatar
Awesome thank u for that! The car seems a little jerky but that happened last time I flashed it. But it went away after
Old 05-04-2017, 08:21 PM   #363
allowe
allowe's Avatar
Hey what if you lowered your idle even more ? Let's say 1000, are there any risks if I end up lowering it even more? Or even 750
Old 05-05-2017, 02:21 AM   #364
steve99
Drives: FT86
Might not idle well and even stall in cold weather cold start
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
