Old 01-13-2014, 10:33 PM   #1
Raven604
Disable high Rev cold start
Is it possible to disable the ~1500 idle cold start. It's loud as Fuck and if you start moving a few feet right after a cold start and stop, the idle goes back down to normal 700/800 ish anyways.
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 01-13-2014, 11:11 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
With a tune it is. I believe the OFT has it reduced in their off the shelf tune and I am positive any competent tuner using Ecutek, BRZedit or any other tuning solution could do it also.
1974 TA22 Celica
2013 86 GT
Old 01-13-2014, 11:15 PM   #3
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We do it in some of our Stage 2 tunes.
FT-86 SpeedFactory is offline   Reply With Quote
Old 01-13-2014, 11:17 PM   #4
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
But that's what makes cold starts fun...
Old 01-13-2014, 11:22 PM   #5
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
I'd leave it as it is...you risk damaging the engine without a proper warming. Just saying.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline   Reply With Quote
Old 01-14-2014, 12:16 AM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I'm not so sure about this statement. I believe I have read elsewhere on the forums that the only point of the overlap/high idle upon cold start is to kick start the CATs to reduce pollution and meet emissions requirements.
Without this behavior hard coded into the stock ECU flash, the car would start up and have a natural high idle for a period of time, and then slowly drop - much like almost every other car on the road.
I've personally noticed that on super cold starts (around 30 degrees F), the high/overlap idle will do it's thing and then stop, but the idle will still stay high for another minute or two before finally dropping down.
I'm torn on it though myself. Part of me would want to turn it off so my early morning weekday starts aren't so obnoxious and neighbor-waking, but part of me likes how loud and crazy it sounds... because racecar
Originally Posted by humfrz
I'm old and lazy
Old 01-14-2014, 12:28 AM   #7
Raven604
Maybe if you peel out of your driveway... But cruising you shouldn't damage anything...
Old 01-14-2014, 12:29 AM   #8
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
Can the Unichip / Flux2 do anything about changing the cold idle level?
Maybe @Unichip Jack could chime in here?
TSW Nurburgring 18x8, BFG Comp-2 235/40, KW V3's w/ Vorshlags, ECUTek by Evasive, Injen intake, FT86 Header, Motiv OP/DP, Nameless Axleback, 4.88 Weir gears, Subaru Legacy GT brakes, Five Axis spoiler, Shark Fin, 3000k HID's, LED goodies
KVDB31 is offline   Reply With Quote
Old 01-14-2014, 03:10 AM   #9
ncmx5
ncmx5's Avatar
Drives: 2013 BRZ premium
Because Race Car
ncmx5 is offline   Reply With Quote
Old 01-14-2014, 03:30 AM   #10
PSJohnDoe
I don't think so, the Unichip doesn't get input from the ECU. Without talking to the ECU it has no way of knowing why it is at that RPM, for all it knows, you're coasting. The only things it can detect are throttle position, timing/cam position, and air flow.
PSJohnDoe is offline   Reply With Quote
Old 01-14-2014, 06:48 AM   #11
FR-S Matt
It's there to get the liquids up to operating temperature and warm the cat up before taking off. I always sit for the full time when its cold outside. It's an extra 30 seconds. I also put a quieter exhaust on with my catless header so I'm not a jerk in my apartment complex. Even then, my car is still fairly loud cold start.
Old 01-14-2014, 07:27 AM   #12
wparsons
wparsons's Avatar
There's two levels of the cold start program.
1) Higher revs, and tons of valve overlap. This is WAY louder. After a few seconds the revs stay up but it's much quieter when the ECU scales back the overlap. This is 100% to get heat into the cats faster. I would have zero issue disabling the overlap part (or minimizing it), it's bordering on obnoxiously loud for no good (to me) reason.
2) Normal higher revs, normal valve overlap. This is the part meant to get heat into the fluids. I wouldn't want to get rid of this.
^^ This guy gets it!
flickr
Old 01-14-2014, 07:47 AM   #13
FR-S Matt
I think the best way to look at this is simple. Drive the car easy until fluids are warm. Most people don't wait once they start their car and take off before the cats have a chance to warm up.
Even with the loudness on the cold start, I kept it with my 3" exhaust. Sure, it was brutal, but I didn't care, lol. No complaints from the apartment complex!
Old 01-14-2014, 08:45 AM   #14
mad_sb
I will look at my logs in a bit for overlap and throttle angle but, a big component is the afterstart timing. The default after start timing is -15, when the high cold start idle drops the timing does back to the normal +13 - +15 degrees... this is easy enough to edit and does change the noise level but it also creates stability issues for the idle system and can throw numerous codes.
I'l still messing with it. at one time i had set the after start timing to 0 and it would throw an ignition timing out of range code or somethings like that but it was a lot quieter.. The idle rpm also went up. at the time i was not messing with the idle speed tables.
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
