Old 05-03-2017, 04:11 PM   #1
dostoyevsky
Drives: 2017 BRZ
1st gear shake and grind?
Hey guys, just finished the breakin period for my 2017 BRZ and sometimes when I'm going 5mph and try and put it into 1st, I hear a whining sound which I understand are the synchros spinning up but sometimes when it refuses to go into 1st and I manage to put it in, I hear a grinding sound and the shifter shakes violently , keep in mind this is with the clutch pushed all the way to the floor. Any help would be appreciated.
I'm on mobile so ignore any grammar mistakes
dostoyevsky is offline   Reply With Quote
Old 05-03-2017, 04:30 PM   #2
imnotsureaboutbrz
Drives: between cars...
I'm interested to hear people's take on it. I notice my car does too, but it goes away once the car is good and warmed up.
imnotsureaboutbrz is offline   Reply With Quote
Old 05-03-2017, 04:34 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Since you both are from up north I'm assuming it's from the tranny and fluid not warmed up yet.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-03-2017, 04:37 PM   #4
imnotsureaboutbrz
That's definitely a possibility. But what I found is strange just like the op, on my way to lunch while coasting to a stop from about 10-15mph it was like there was a gate blocking my shifter from getting into first until I was going like
3-4
Mph.
Old 05-03-2017, 04:49 PM   #5
HimBRZ
HimBRZ's Avatar
Drives: 2013 BRZ Limited
Why are you shifting into 1st before you stop? Seriously just want to know. There was a time when cars didn't have synchronizers in 1st gear and it was impossible to do.
HimBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to HimBRZ For This Useful Post:
Tcoat (05-03-2017), Trust86 (05-03-2017)
Old 05-03-2017, 05:03 PM   #6
3-4
Mph.
That sounds about right.
Old 05-03-2017, 05:05 PM   #7
Or at all!
And ...
We only had 3 gears so you would really have liked to be able to go into first. If you did try to force it the resulting scream sounded like cats were mating under your car.
Exrald (05-03-2017)
Old 05-03-2017, 05:05 PM   #8
Trust86
Drives: 2016 Halo FRS
Don't shift to 1st gear unless your completely stopped. You can use 2nd gear that low no problem. If you insist you must, then blip the throttle and it will slide right in.
Trust86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Trust86 For This Useful Post:
Exrald (05-03-2017), jcw99 (05-03-2017), Tcoat (05-03-2017)
Old 05-03-2017, 06:00 PM   #9
StraightOuttaCanadaEh
Wes
Ditto, do not shift into first unless you're at below walking pace
Old 05-03-2017, 06:25 PM   #10
Was waiting to see who else would bring it up but I guess nobody is.
Both your cars are new and although "broken in" by the requirements they still have a way to go before they are fully done. Give your tranny a few more thousand miles and it will loosen up more. Many here have reported stiffness and grinding disappearing after they drove the car enough.
Old 05-03-2017, 06:26 PM   #11
funwheeldrive
I feel like this is true most of the time, but I find that going 3-5mph on a slope in 2nd will make the car bog. I don't normally shift into first while the car is moving, but there are circumstances where it's the smoothest way to drive in congested areas.
Old 05-03-2017, 07:08 PM   #12
spike021
spike021's Avatar
I think it's possibly something like this. It's happened to me before as well (@Tcoat has heard my asks about this :P).
As far as I can tell it's only happened going into first, though I've had it happen from stops, not downshifting 2nd to 1st. I think there's been once or twice when shifting up that it's sort of happened in 2nd or 3rd. Like it doesn't go all the way into them, or at least not very easily. But not nearly as often (but the issue itself is even less frequent).
Usually it just takes pulling it back into neutral with clutch fully engaged and then putting the stick back through the 1st gate and all the way in and it's fine (as in, it won't happen twice in a row of it happening).
As said here already, I think it's a matter of letting things warm up more as well as getting more miles on the car past the break-in period.
spike021 is offline   Reply With Quote
Old 05-03-2017, 07:15 PM   #13
dostoyevsky
Drives: 2017 BRZ
2nd gear that slow seems to be lugging the engine..
So how much damage did i do to my synchros since this happened?
Old 05-03-2017, 08:47 PM   #14
Your transmission will be OK. You really have to slam on it to break it. As mentioned, just don't try to put it into first unless you are stopped. It just takes a few thousand miles to smooth out (as much as it's ever gonna).
spike021 (05-03-2017)
5th gear grind Hugo Issues | Warranty | Recalls / TSB 7 06-08-2016 08:33 AM
4th gear grind dallenj Engine, Exhaust, Transmission 15 06-03-2016 04:04 PM
4th gear grind aaguirre123 Engine, Exhaust, Transmission 8 08-03-2015 04:58 PM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 11:50 AM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
