Old 05-03-2017, 03:03 PM   #1
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
AC compressor pulley not spinning when dis-engaged?
So I just noticed the other day that what appears to be the AC compressor pulley doesn't spin sometimes, seems to be when the compressor isn't engaged. I'm just curious if this is normal operation or should it always be spinning?
In case I'm confused and it's not the AC compressor pulley, I've circled the pulley in question in this picture:
Lynxis is offline   Reply With Quote
Old 05-03-2017, 03:09 PM   #2
It is called a clutch pulley and will only spin fully when engaged. Sometimes the belt will just touch it and it will spin but not be doing anything.
Old 05-03-2017, 03:13 PM   #3
Lynxis
Lynxis's Avatar
It is called an "idler" pulley and will only spin fully when engaged. Sometimes the belt will just touch it and it will spin but not be doing anything.
Thanks Tcoat. Everything seemed to be operating normally so I wondered if it was normal operation but just wasn't sure and thought I should check.
Old 05-03-2017, 03:16 PM   #4
It is actually a clutch pulley not an idler. I typed faster than my brain functioned.
Old 05-03-2017, 04:04 PM   #5
@Tcoat is being gentle today ......
Old 05-03-2017, 04:09 PM   #6
Reasonable question asked in a reasonable manner gets a gentle, reasonable answer.
My response is always driven by the post prior to it.
Old 05-03-2017, 04:14 PM   #7
Well of course, if there wasn't a prior post, what would you be responding to ....??
Ma nap time .......
Old 05-03-2017, 04:16 PM   #8
Ma nap time .......
OK
My TYPE of response ...
"click" sound only when throttle is engaged, and dis-engaged AT BRZPDX Issues | Warranty | Recalls / TSB 50 10-11-2016 01:08 PM
Rust developing on a/c compressor pulley nickmerronesucks Issues | Warranty | Recalls / TSB 9 09-25-2015 02:49 PM
SOLD Cusco Engine Pulley Belt Cover Aluminum Blue Anodized Alternator Compressor hirollaz Engine, Exhaust, Bolt-Ons 2 05-31-2015 02:25 PM
pulley not spinning and then spins loud noise Composite Engine, Exhaust, Transmission 19 12-11-2014 07:09 AM
Spinning at Buttonwillow (1CW) ddeflyer Tracking / Autocross / HPDE / Drifting 76 05-22-2014 08:24 PM
