Old 09-22-2015, 04:43 PM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Rust developing on a/c compressor pulley
Working in dealers and repair shops i always see subarus with this issue..now its building up a rusty dust on my a/c pulley..What is the cause of this?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 09-22-2015, 06:42 PM   #2
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
Cheap metal and coating.
GotMunchies? is offline   Reply With Quote
Old 09-22-2015, 07:40 PM   #3
humfrz
Maybe, since the A/C clutch is sometimes magnetized, it’s attracting metal particles from the surrounding air …..
humfrz
Old 09-25-2015, 11:48 AM   #4
Poodles
Drives: 2015 Series.Blue
Pics? The clutch is metal on metal, so it WILL rust if you don't use the A/C (much like brakes that are sitting)
Old 09-25-2015, 11:52 AM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Why is this an issue??
Old 09-25-2015, 02:00 PM   #6
humfrz
It was a slow day in Morrisville, PA ...... ??
humfrz
Old 09-25-2015, 02:06 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
humfrz
LMAO No kidding!
Old 09-25-2015, 02:07 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
"Rust is another name for iron oxide, which occurs when iron or an alloy that contains iron, like steel, is exposed to oxygen and moisture for a long period of time. Over time, the oxygen combines with the metal at an atomic level, forming a new compound called an oxide and weakening the bonds of the metal itself."
There now we know what causes rust.
Old 09-25-2015, 02:10 PM   #9
nickmerronesucks
Ned flanders
I was bored and wondering. Makes sense i dont ever use my ac
Sent from my SPH-L720T using Tapatalk
797Performance.com
Old 09-25-2015, 02:49 PM   #10
aagun
Drives: 86
my two sub pulleys start bleed out oil and make bearing sound so i replace the bearing
aagun is offline   Reply With Quote
AC compressor tweet Hanzo Issues | Warranty | Recalls / TSB 96 07-04-2020 07:19 PM
SOLD Cusco Engine Pulley Belt Cover Aluminum Blue Anodized Alternator Compressor hirollaz Engine, Exhaust, Bolt-Ons 2 05-31-2015 02:25 PM
Tools for air compressor ;) Mikeez Issues | Warranty | Recalls / TSB 6 11-30-2014 05:14 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
