CANADA Canada
Old 04-20-2017, 10:54 AM   #15
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
Originally Posted by tinma View Post
After doing more reading...(which i really should have done prior to my alignment and not just relied on the shop for the best outcome) should my front camber not be in the negatives?
here is a great link for help for anyone that needs it
http://www.ft86club.com/forums/showthread.php?t=25001
You definitely do not want positive camber ever
I just got my alignment today. Here are my specs. Any good?
Front: left
Camber 1.63
Caster: 5.86
Toe: 0.01
Right
1.50
6.21
0.00
Judging by the question about negative camber, I assume these camber figures above are negative and not positive, right?
Yanbags is offline   Reply With Quote
Old 04-20-2017, 11:05 AM   #16
tinma
Drives: '13 BRZ
Those are positive
tinma is offline   Reply With Quote
Old 04-20-2017, 02:01 PM   #17
Yanbags
Yanbags's Avatar
Those are positive
Ouch... that's so far off even from OEM alignment specs. I kind of find it hard to believe any tech would do that. Do you have any camber adjustment in the front? It should be close to 0 in stock form.
Old 04-20-2017, 04:36 PM   #18
tinma
Drives: '13 BRZ
Whiteline front camber bolts. Nothing in the rear.
Old 04-21-2017, 02:06 AM   #19
Ad8707
Ad8707's Avatar
Drives: 2013 frs whiteout
Front should be negative camber....camber bolts should help with this. Re install and Re align. Get the toe as close to zero in the front. No rear toe adjustment with a stock car
Ad8707 is offline   Reply With Quote
Old 04-21-2017, 06:50 AM   #20
Cole
Not a troll
Cole's Avatar
Cole is offline   Reply With Quote
The Following 2 Users Say Thank You to Cole For This Useful Post:
Ad8707 (04-21-2017), D_Thissen (04-21-2017)
Old 04-21-2017, 09:32 AM   #21
Yanbags
Yanbags's Avatar
Yeah, do yourself a favor and get them to fix it to ~-1 to -1.5 camber in the front to make use of your camber bolts. Rear you can't do anything about without aftermarket camber adjustment.
The Following 2 Users Say Thank You to Yanbags For This Useful Post:
tinma (04-21-2017), wparsons (04-21-2017)
Old 04-21-2017, 09:37 AM   #22
wparsons
wparsons's Avatar
Toe is definitely adjustable both front and rear with 100% stock parts. People buy aftermarket toe arms if they're drastically altering camber with a LCA because the stock adjuster doesn't have enough range if you've drastically changed the length of the LCA.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Ad8707 (04-21-2017), tinma (04-21-2017)
Old 04-21-2017, 12:33 PM   #23
Ad8707
Ad8707's Avatar
Sorry to misinform the OP..my bad lol..but definitely should be negative with the use of camber bolts...did I get that right? Lol ..
The Following User Says Thank You to Ad8707 For This Useful Post:
Old 04-21-2017, 02:04 PM   #24
D_Thissen
D_Thissen's Avatar
Yes
Old 04-21-2017, 02:58 PM   #25
Ad8707
Ad8707's Avatar
Originally Posted by D_Thissen View Post
Yes
Thanks Dan lol
Old 04-21-2017, 07:24 PM   #26
Import_Lexus
Import_Lexus's Avatar
Drives: 2016 Scion FRS
My steering wheel is a little off....can I just go to any place to get an alignment?
I don't need all this hardcore stuff for tracking etc since I just drive like a grampa in the Toronto traffic >_<
Import_Lexus is offline   Reply With Quote
Old 04-24-2017, 11:56 AM   #27
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
NV Auto can dial you in no problems. Just went there on Friday:
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Taka (05-01-2017)
Old 04-24-2017, 04:54 PM   #28
Cole
Not a troll
Cole's Avatar
[IMG]http://i.imgur.com/kEjZcQo.jpg[IMG]
I find your lack of camber disturbing
alignment shop ? FR-Sky Northern California 17 04-08-2016 10:33 PM
Recommended Alignment Settings? BFIFE22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-27-2015 04:57 PM
Alignment settings for Auto club speedway ddeflyer Tracking / Autocross / HPDE / Drifting 12 07-08-2015 08:10 PM
Recommended Toe Alignment Settings brillo Tracking / Autocross / HPDE / Drifting 18 02-05-2014 11:36 AM
RCE yellow springs. Expected alignment settings after install. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-24-2013 02:48 PM
