Old 04-16-2017, 01:39 AM   #3445
15limited
15limited's Avatar
Originally Posted by SmartedPanda View Post
Yeah, I'm 90% sure it'll fit on the rears, someone with RPF1's fit on the rears w/ stock. I'm more worried about rubbing on the front with 245/45, 245/40 is basically the common fitment for stock and 1" drops.
245/45 will work up front, even with maxed out SPC camber bolts with 1.3" drop springs. That was with 17X9 +35 wheels tho
Edit:oh yeah I'm running the same wheels, you're good
Edit edit: I was on rsr super down lowering springs on stock struts and I didn't rub even on harsh compressions. 1.3 lower in the front & 1.7 in the rear. You'll have to fine tune your camber tho, cause it's damn close
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
SmartedPanda (04-18-2017)
Old 04-17-2017, 12:57 PM   #3446
Joker
Drives: Car
Will staggered 57 xtremes 18x8.5 +33 w/ 255/35/18, 18x9.5 +40 w/ 265/35/18 going on RCE yellow springs and stock everything else work? I have coilovers atm, but they're popping/clunking (disassembled with no luck) & too harsh of a ride. Any insight would be greatly appreciated, thanks.
Joker is offline   Reply With Quote
Old 04-17-2017, 01:32 PM   #3447
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
How about stock w/ no suspension mods? That's the real question, I got 2 weeks to figure it out before my wheels and tires come in! Should've done this before buying.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 04-17-2017, 06:51 PM   #3448
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Hey guys, would 17x8.5 +48 with 215/50/17 tires fit? I've seen some people run 17x9 +42 with 245 tires and they barely fit, so I was wondering if I would need a small spacer. Thanks!
Cubix is offline   Reply With Quote
Old 04-17-2017, 11:10 PM   #3449
15limited
15limited's Avatar
At stock height you should have more than enough clearance. Only place I was close to rubbing was inner fender lining in the rear and spring perch in the front. If you're body is higher only thing I can think of is outside of the rear tire rubbing the fender edge at the top center because of the offset and width. But even then a small bit of camber should get you away from it.
Old 04-18-2017, 10:41 PM   #3450
Loetke
Drives: 2015 Scion FR-S Release 1.0
Just got my wheels, tires going on in a couple of days. Rear will be 18x9.5 +40 wrapped in 255/35R18. The front is where my question comes in. The front wheels are 18x8.5 +35. Should I be using 225/40R18 or 235/40R18? Will 225 be stretched? I only ask because the tire shop here quoted me about $75 more per tire for the 235s. Any help is appreciated, thanks.
Loetke is offline   Reply With Quote
Old 04-18-2017, 11:09 PM   #3451
Shims
Shims's Avatar
Drives: GTS86
Guys I really need some help on the offset or size on;
Work Meister S1 3P
front: 18x8.5 +37 R disk (45mm lip)
rear: 18x9.5 +37 O disk (83mm lip)
not sure what offset I need to get it flush without poke, tucking, or camber
I'm trying to match my TE37SL Black Editions which were 18x8.5+35 front, 18x9.5+40 rear
Shims is offline   Reply With Quote
Old 04-20-2017, 06:11 AM   #3452
TheWhiteWizard13
TheWhiteWizard13's Avatar
Drives: 2013 Subaru BRZ with Invidia N1
Check out tyrestretch.com and all your questions will be answered about how much stretch or how little. 👌🏾
Sent from my iPhone using Tapatalk Pro
TheWhiteWizard13 is offline   Reply With Quote
Old 04-20-2017, 02:02 PM   #3453
PR138
PR138's Avatar
Drives: '14 WRB BRZ | '17 CB STi
18x9.5 +45 Enkei Kojin front and rear.
Lowered about 1" all around on RCE T2s. Camber -2.4 F -1.9 R.
Will I be able to fit 265/35/18s square, or should I go with a 255 all around? From looking around, it seems like 265s will work without rubbing, except up front at full lock maybe. Anyone have experience with this offset/tire size setup?
PR138 is offline   Reply With Quote
Old 04-20-2017, 07:21 PM   #3454
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Work Meister S1 3P
I guess you were happy with the TE37SL fittment?
If so, the Work Meister Setup you've posted above will differ from the TE37SL fittment as follows:
Front -> Work wheels will be 2mm more "inside"
Rear -> Work wheels will be 3mm more "outside"
So nothing wrong with the figures you've posted with the work meister wheels. If you did like the TE37SL fittment, you will like the Work fittment (I doubt you will notice the 2-3mm difference once their are mounted)
hope this helps. Cheers
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Shims (05-10-2017)
Old 04-20-2017, 07:33 PM   #3455
Killerbee
Killerbee's Avatar
Doing the math, a 8.5" +48 is the same as a 9" +42 wheel (from a fitting point of view) -> boring calculations at the bottom of this post if you're interessted.
So if a 9"+42 works, a 8.5" +48 will work aswell. Its pretty damn close to the inner struits however. Also, I hope you're aware that a 215 tire on 8.5" wheel will generate a light stretch.
Boring calculations -> Only read if you're not sleepy:
8.5" wheel compared to 9" is 0.5" difference = 12.6ish mm.
Take half of that (as the wide will gain 50% on the inside, and 50% on the outside) and you have 6.3mm
Offset is always in mm. 42 offset is further "outside" than a 48 offset.
Now, if a 9" +42 wheel fits, an 8.5" +42 is 6.3mm less on the "inside", so a 8.5 +42 wheel would have 6.3mm more clearance than a 9" +42. Now your 8.5" is a +48 not a +42, so you have to substract the 6mm in offset difference, which eats up what you've "gained" in the calculation before. so you're pretty much ending at the same spot. (well, you got 0.3mm more clearance:-)
Old 04-20-2017, 08:36 PM   #3456
Prototype
Drives: Scion FRS 2016
Hey guys my car is stock but I eventually want to change the suspension and then look into forced induction. I need help with figuring out which offset wheels to get for my application.
I want to get some Enkei RPF1's but they come with two different offsets.
RPF1's: 17 x 9 +35 or +45
The tire size I am looking at is 245/40.
If I get the larger offset version does that mean I will need spacers to keep it flush?
I would like to avoid getting spacers.
I like to push the car and I am planning to track it so I will be looking to lower the car 1" for now and more in the future. I don't think I will be getting a BBK but would like to avoid any hassle if I do choose to go that route.
Any insight would be appreciated
Prototype is offline   Reply With Quote
Old 04-21-2017, 10:55 AM   #3457
PR138
PR138's Avatar
Will a 265/35/18 fit up front on a 18x9.5 +45 wheel (with coilovers)? I'm only lowered about an inch - will I have issues or should I pull the trigger on a set of 265 MPSS? Thanks!
Old 04-21-2017, 12:45 PM   #3458
Killerbee
Killerbee's Avatar
Its an odd setup, so I dont know. However, my best guess from what I've seen/read so far is that it will rub on the inside/inner fender.
But again, thats just a guess.
PR138 (04-21-2017)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
