| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3445 | |
Edit:oh yeah I'm running the same wheels, you're good Edit edit: I was on rsr super down lowering springs on stock struts and I didn't rub even on harsh compressions. 1.3 lower in the front & 1.7 in the rear. You'll have to fine tune your camber tho, cause it's damn close Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
| The Following User Says Thank You to 15limited For This Useful Post: | SmartedPanda (04-18-2017) |
#3446 |
Drives: Car
Will staggered 57 xtremes 18x8.5 +33 w/ 255/35/18, 18x9.5 +40 w/ 265/35/18 going on RCE yellow springs and stock everything else work? I have coilovers atm, but they're popping/clunking (disassembled with no luck) & too harsh of a ride. Any insight would be greatly appreciated, thanks.
#3447 | |
Drives: SWP BRZ Limited Manual. 2014
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
#3448 |
Drives: 2015 FR-S
Hey guys, would 17x8.5 +48 with 215/50/17 tires fit? I've seen some people run 17x9 +42 with 245 tires and they barely fit, so I was wondering if I would need a small spacer. Thanks!
#3449 | |
#3450 |
Drives: 2015 Scion FR-S Release 1.0
Just got my wheels, tires going on in a couple of days. Rear will be 18x9.5 +40 wrapped in 255/35R18. The front is where my question comes in. The front wheels are 18x8.5 +35. Should I be using 225/40R18 or 235/40R18? Will 225 be stretched? I only ask because the tire shop here quoted me about $75 more per tire for the 235s. Any help is appreciated, thanks.
#3451 |
Drives: GTS86
Guys I really need some help on the offset or size on;
Work Meister S1 3P front: 18x8.5 +37 R disk (45mm lip) rear: 18x9.5 +37 O disk (83mm lip) not sure what offset I need to get it flush without poke, tucking, or camber I'm trying to match my TE37SL Black Editions which were 18x8.5+35 front, 18x9.5+40 rear Last edited by Shims; 04-19-2017 at 12:33 AM. |
#3452 | |
Drives: 2013 Subaru BRZ with Invidia N1
Check out tyrestretch.com and all your questions will be answered about how much stretch or how little. 👌🏾 Sent from my iPhone using Tapatalk Pro |
#3453 |
Drives: '14 WRB BRZ | '17 CB STi
18x9.5 +45 Enkei Kojin front and rear.
Lowered about 1" all around on RCE T2s. Camber -2.4 F -1.9 R. Will I be able to fit 265/35/18s square, or should I go with a 255 all around? From looking around, it seems like 265s will work without rubbing, except up front at full lock maybe. Anyone have experience with this offset/tire size setup? |
#3454 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
If so, the Work Meister Setup you've posted above will differ from the TE37SL fittment as follows: Front -> Work wheels will be 2mm more "inside" Rear -> Work wheels will be 3mm more "outside" So nothing wrong with the figures you've posted with the work meister wheels. If you did like the TE37SL fittment, you will like the Work fittment (I doubt you will notice the 2-3mm difference once their are mounted) hope this helps. Cheers
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
| The Following User Says Thank You to Killerbee For This Useful Post: | Shims (05-10-2017) |
#3455 | |
So if a 9"+42 works, a 8.5" +48 will work aswell. Its pretty damn close to the inner struits however. Also, I hope you're aware that a 215 tire on 8.5" wheel will generate a light stretch. Boring calculations -> Only read if you're not sleepy: 8.5" wheel compared to 9" is 0.5" difference = 12.6ish mm. Take half of that (as the wide will gain 50% on the inside, and 50% on the outside) and you have 6.3mm Offset is always in mm. 42 offset is further "outside" than a 48 offset. Now, if a 9" +42 wheel fits, an 8.5" +42 is 6.3mm less on the "inside", so a 8.5 +42 wheel would have 6.3mm more clearance than a 9" +42. Now your 8.5" is a +48 not a +42, so you have to substract the 6mm in offset difference, which eats up what you've "gained" in the calculation before. so you're pretty much ending at the same spot. (well, you got 0.3mm more clearance:-)
#3456 |
Drives: Scion FRS 2016
Hey guys my car is stock but I eventually want to change the suspension and then look into forced induction. I need help with figuring out which offset wheels to get for my application.
I want to get some Enkei RPF1's but they come with two different offsets. RPF1's: 17 x 9 +35 or +45 The tire size I am looking at is 245/40. If I get the larger offset version does that mean I will need spacers to keep it flush? I would like to avoid getting spacers. I like to push the car and I am planning to track it so I will be looking to lower the car 1" for now and more in the future. I don't think I will be getting a BBK but would like to avoid any hassle if I do choose to go that route. Any insight would be appreciated |
#3457 | |
#3458 | |
But again, thats just a guess.
| The Following User Says Thank You to Killerbee For This Useful Post: | PR138 (04-21-2017) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
