Old 04-12-2017, 04:52 PM   #15
fika84
fika84's Avatar
Originally Posted by dostoyevsky View Post
How can the oil pressure problems be solved?
By over rev do you mean the stock 7.3k rpm is too much?
I mean upping the redline above stock.
there are some good threads on this forum talking about the oil pressure and how it can be "solved" for higher than stock rpm driving for sustained periods of time.
fika84 is offline   Reply With Quote
Old 04-12-2017, 05:57 PM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by CounterSpace Garage View Post
For example, the engine lasts for a long time with proper care, a very good tune, if foreign objects don't penetrate the walls (internally or externally).....
True but I am suggesting a con rod is not a foreign object.
Old 04-12-2017, 06:11 PM   #17
dostoyevsky
Drives: 2017 BRZ
So say, would 250whp be reliable with this engine, and for supporting mods.. say: catch can + oil cooler?
dostoyevsky is offline   Reply With Quote
Old 04-13-2017, 12:21 AM   #18
Turdinator
Señor Member
Turdinator's Avatar
Revs and oil pressure are the issue not power levels. If you could make that power below 8k rpm and keep oil temps and pressures intact it would be ok... most likely.
1974 TA22 Celica
2013 86 GT
Old 04-13-2017, 02:19 AM   #19
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It is very difficult to get 250whp with NA and for sure you'll need to increase the engine displacement with boring and honing.
As others mentioned the main engine issue is the low oil pressure on high rpms, but this is an effect and not the cause. The issue is that the engine is getting very hot and it is a reason that the stock tuning has unusually rich AFRs. It is clear that they were trying to keep it running cooler and not the b*shit that the tuning was wrong. An oil cooler will solve the issue partially. The revised engine (2016+) has internals with lower friction and this helps more.
Old 04-13-2017, 02:30 AM   #20
dostoyevsky
Drives: 2017 BRZ
Originally Posted by nikitopo View Post
It is very difficult to get 250whp with NA and for sure you'll need to increase the engine displacement with boring.
How reliable would a 250whp suoercharger, oil cooler be?
Old 04-13-2017, 02:46 AM   #21
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I believe that you'll be on the safe side if you choose some respected brand. HKS or Cosworth products come bundled usually with an engine tune and they should be good options.
Old 04-13-2017, 06:39 AM   #22
bfrank1972
Drives: 2013 FR-S Argento
The thing you should ask yourself: what am I able to do if the motor does blow. I.E. can I afford to fix it, is it going to be a minor financial headache or am I going to have to eat Ramen for 5 months?
Sent from my SM-N920V using Tapatalk
Old 04-13-2017, 06:57 AM   #23
People have managed to blow these engines up at stock HP.
They have also snapped parts at higher HP.
Some have run at 250 and over without issue.
Your question can not be answered and any answer you do receive is speculation at best.
Every single thing you do to the engine increases the risk of failure. The larger the change the larger the risk and potential impact from the failure.
Oil coolers, good tunes, etc may reduce the risk a bit but they do not eliminate it and it remains higher with FI.
As Bfrank said, are you prepared to accept that increased risk and able to deal with the results of catastrophic failure if it does blow up?
Old 04-13-2017, 11:57 AM   #24
max20s14
Drives: 14' Raven M/T - 02' is300
I think if you add a turbo it may deflect more bullets.
Disclaimer:
Sorry could not resist..
max20s14 is offline   Reply With Quote
Old 04-13-2017, 12:42 PM   #25
dostoyevsky
Drives: 2017 BRZ
I see, curious though how the fuck did someone manage to blow this engine at stock hp?
Old 04-13-2017, 12:43 PM   #26
Somerandom18
Drives: 2017 manual BRZ
Revving to 8k?
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 04-13-2017, 12:57 PM   #27
reeves
Revving to 8K has been fine [for me], doing it every now & then. I don't track or race my car though, so it's just for a split second when I do hit 8K. If my motor ever blows up, I'll be sure to let everyone know
The Following User Says Thank You to reeves For This Useful Post:
Somerandom18 (04-13-2017)
Old 04-13-2017, 12:58 PM   #28
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
They've probably built 200,000 of these at this point, not every single one came out perfect from the factory, and many many of them were driven very hard exposing weaknesses.
All mass produced engines have a measurable premature failure rate. ALL of them.
Oiling issues are the most common along with a few valves coming apart. There was also a tune issue on the first year of production cars that created knock under fast shifting at high rpm that damaged the direct injector seals, a few blew up from that.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Captain Snooze (04-13-2017), ~el~jefe~ (04-15-2017)
Headlight Modification like Bulletproof FRS. xFury Cosmetic Modification (Interior/Exterior/Lighting) 4 02-03-2016 09:59 AM
What is Currently Going On At Bulletproof Automotive BPAuto Off-Topic Lounge [WARNING: NO POLITICS] 6 12-18-2015 10:18 AM
Bulletproof frs yetiFR-S FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 05-19-2014 10:20 PM
Bulletproof Automotive's SWP 6MT BRZ Limited BPAuto BRZ First-Gen (2012+) — General Topics 22 08-18-2013 12:39 PM
ZELE x Bulletproof Automotive 86 BPAuto Cosmetic Modification (Interior/Exterior/Lighting) 44 06-26-2013 12:13 PM
