Old 04-11-2017, 11:02 AM   #1
JPRodney
JPRodney's Avatar
Drives: 2016 Asphalt FRS
Camber Issues
Hey Guys,
Since this is my first car and all, I'm learning slowly but surely.
I took my frs into the dealership for an alignment after lowering the car on BC coils. I came up with some weird results in my mind.
I have
0/-0.05 toe in the front
0.05/0.05 toe in the rear
Then it gets weird.
-1.10/-0.90 camber in the front
-3.20/-2.70 camber in the rear ?
The dealership didn't change my camber at all, fixed my toe and then still charged me the $100.
What do I need to fix this problem?
Asphalt FRS - Ontario, Canada
JPRodney is offline   Reply With Quote
Old 04-11-2017, 11:15 AM   #2
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
Aftermarket rear lower control arms w/ camber adjustment. You lowering the suspension affects the rear camber but it can't be corrected because there is no adjustment available with the factory arms.
Yanbags is offline   Reply With Quote
The Following User Says Thank You to Yanbags For This Useful Post:
JPRodney (04-12-2017)
Old 04-11-2017, 11:17 AM   #3
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Originally Posted by JPRodney View Post
lowered the car on BC coils.
Then it gets weird.
The easiest way to get the rear camber in check after lowering the car is to install adjustable rear lower control arms. I have the basic SPC ones which are pretty inexpensive. If you would like to even out the camber in the front and maybe dial a little more in, try out front camber bolts. These will be the cheapest options to get your camber adjustable.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following 2 Users Say Thank You to yelsew For This Useful Post:
guybo (06-25-2017), JPRodney (04-12-2017)
Old 04-11-2017, 11:35 AM   #4
JPRodney
JPRodney's Avatar
Thanks for the quick reply, I guess I'll have to order some arms and bolts asap. I'm trying to correct the camber because having over -3 in the back is off spec. Would the lower control arms be enough to fix this issue?
Old 04-11-2017, 12:41 PM   #5
driggity
Drives: Silver Coupe with a Boxer
Rear arms should be sufficient to get the rear end where you want it.
Did you get the BCs without front camber plates or are there plates that the dealership just didn't adjust.
If you care about performance then "spec" isn't necessarily what you should be looking for. Also dealerships usually aren't the best place to go for a performance oriented alignment.
driggity is offline   Reply With Quote
The Following 3 Users Say Thank You to driggity For This Useful Post:
Cole (04-12-2017), JPRodney (04-12-2017), wparsons (04-12-2017)
Old 04-11-2017, 12:48 PM   #6
markitect
Drives: Scion FRS
The SPC Arms are supposed to be able to correct +/- 2 degrees. The aluminum ones (lots of people that make them) provide more adjustability, but at a higher price.
markitect is offline   Reply With Quote
Old 04-11-2017, 01:27 PM   #7
Yanbags
Yanbags's Avatar
This is a good point. What's your main purpose for the car? Daily driving? Will the car see any track events? Autocross? What tires do you have/use?
If daily, I would probably do something like -2 front camber, -1 to -1.5 rear camber. Will transform the car from stock spec and not really affect tire life.
On my track setup, I run -3F, -2R on street tires (Bridgestone RE71R).
Old 04-11-2017, 03:14 PM   #8
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
lol
smg1138 is offline   Reply With Quote
The Following 4 Users Say Thank You to smg1138 For This Useful Post:
churchx (04-11-2017), DavidBob (04-20-2017), Icecreamtruk (04-11-2017), kch (06-08-2017)
Old 04-11-2017, 04:10 PM   #9
Yanbags
Yanbags's Avatar
Originally Posted by smg1138 View Post
lol
DOT says they are hehehe
The Following 2 Users Say Thank You to Yanbags For This Useful Post:
Icecreamtruk (04-11-2017), smg1138 (04-11-2017)
Old 04-11-2017, 06:44 PM   #10
JPRodney
JPRodney's Avatar
It's my daily car and I will keep it that way, until I feel comfortable tracking the car a few years down the road. I believe I will need the camber arms anyways because the camber is really off from the left and right side. I was looking at Megan Racing; because I know I could get them before the weekend and having everything on, ready for an alignment by Saturday.
Also yes I do have camber plates for the front, just not the rear.
Old 04-12-2017, 02:27 PM   #11
Yanbags
Yanbags's Avatar
Yeah, so no need to go super aggressive on the alignment. Just even camber left to right, 0 toe (some toe-in in the rear is good for stability), and you'll be A+. Honestly I'd probably just do -1.5F and -1R camber.
Old 04-12-2017, 02:31 PM   #12
wparsons
wparsons's Avatar
There's no camber adjustment stock, so I bet they didn't even look under the hood to see the camber plates in the front.
Skip the camber bolts since you already have plates, and get some rear LCA's.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
Cole (04-12-2017), JPRodney (04-12-2017), Yanbags (04-12-2017)
Old 04-12-2017, 04:01 PM   #13
JPRodney
JPRodney's Avatar
Thanks guys,
I appreciate the feedback. I ordered some LCA today and hopefully receive them tomorrow.
The Following 2 Users Say Thank You to JPRodney For This Useful Post:
wparsons (04-12-2017), Yanbags (04-13-2017)
Old 04-13-2017, 03:00 PM   #14
fazlook
Drives: FRS
Smile
Thanks guys,
I am having the exact same problem as yours what did you order ? and from where ?
fazlook is offline   Reply With Quote
Issues with camber after new coilovers wizzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-24-2015 11:36 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Issues with getting camber to -3 in front? Churg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 03-22-2015 01:01 PM
Rear camber assymmetry and alignment issues ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-02-2015 12:46 PM
