Old 03-25-2017, 12:04 AM   #15
Originally Posted by cmurp96 View Post
By no means am I a professional I simply meant I am not a 16 year old who just learned how to drive. I can drive well on a closed track that is suited for it. I will try that but before I did I wanted to get opinions. I have been told it could be the bump stops but idk how that works as i am not a car mechanic
Do not ever listen to that guy's automotive advice again! Ever.
No this is everyday road. This is what I was looking for if the car is able to handle this
Ya, at that speed and angle you will start to lose traction on most surfaces. The nannies whole purpose in life is to try to regain that traction and that is all that is happening. If you pull back the speed or reduce the angle you maintain traction to where the nannies can live with it but you are just hitting the point where they are screaming "OH HELL NO".
Just turn them off (if in a safe place) and drift away. Keep in mind that a bit of gravel or a dip in the road surface could mean you may be here asking "Is this totaled?
Atropine (03-25-2017), cmurp96 (03-25-2017), Hoahao (03-26-2017), humfrz (03-25-2017), Ultramaroon (03-25-2017)
Old 03-25-2017, 12:54 AM   #16
.............. I was having problems before when it came to certain left hand turns at around 40 degree apprx 60mph.........
This ol boy would like some clarification.
Are you saying the turn is a 60 degree curve (flat) OR a 60 degree (banked) curve ..... ??
Old 03-25-2017, 01:06 AM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Like eluded to above,
alluded
You elude the police.
Allude means to suggest.
ineedyourdiddly
Cole (03-25-2017)
Old 03-25-2017, 01:14 AM   #18
alluded
You alluded he eluded looting the lute?
Cole (03-25-2017), strat61caster (03-25-2017)
Old 03-25-2017, 01:50 AM   #19
40 degrees is pretty cold to be expecting that kind of traction from a summer compound.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
cmurp96 (03-25-2017), Cole (03-25-2017), finch1750 (03-25-2017), strat61caster (03-25-2017), Tcoat (03-25-2017)
Old 03-25-2017, 01:56 AM   #20
alluded
Yep, ya got me there .....
Old 03-25-2017, 01:56 AM   #21
Ultramaroon (03-25-2017), wparsons (03-28-2017)
Old 03-25-2017, 02:00 AM   #22
..... he said 40 degrees ....... NOT 60 degrees ...... you dumb shit!
Old 03-25-2017, 02:06 AM   #23
Now I'm all freaking confused ......
......and THEN @Ultramaroon pipes up with the temperature thing ..... and @Tcoat makes fun of him ...... and @strat61caster just sits there ...... waiting for ME to make another mistake.
OK, so much for me trying to back down on ma meds ......
Old 03-25-2017, 02:35 AM   #24
Don't be so hard on yourself. We're all fucked up in one way or another. You've just had more time to enjoy it.
Cole (03-25-2017), humfrz (03-25-2017)
Old 03-25-2017, 02:39 AM   #25
I didn't make fun of Ultra. His use of the alternative meaning of the word "degrees" was brilliant! The applause was well deserved.
humfrz (03-25-2017), strat61caster (03-25-2017), wparsons (03-28-2017)
Old 03-25-2017, 02:52 AM   #26
Yeah! What he said. Duh.
Besides, isn't it Strat's turn? Nobody likes a pedant.
Old 03-25-2017, 04:12 AM   #27
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You have no camber and take it to the track? I would imagine you understeer like mad and the outside edge takes a crazy beating.
Also, new tires take a bit to burn the grease off. Plus, the car doesnt like the different aged tires front and rear. I ran tires like that for a while and had terrible time with the TC til I replaced all 4 then it went away. Not sure if its due to varying size or the levels of grip
I'm also gonna go with there is likely an input somewhere (helping) cause this.
Old 03-25-2017, 10:23 AM   #28
Cole
Not a troll
Cole's Avatar
Pro tip: the 96 in his user name probably stands for 1996, which means he's a young buck full of hubris and ready to make bad decisions.
I also doubt that the track experience is real, if it was, I'm sure he'd have a far better idea of what's going on mid-turn. Doubly hard to believe he tracks given that alignment, didn't realize understeery alignments were so good for track days.
Cole is offline   Reply With Quote
The Following 2 Users Say Thank You to Cole For This Useful Post:
swarb (03-28-2017), wparsons (03-28-2017)
SPC LCA Alignment Issue? ssidd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-15-2018 12:58 PM
FRS Bumper alignment issue, help please Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 5 06-04-2015 02:27 PM
Do I just need an alignment or... (scraping issue) IDFWU 420 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-26-2014 12:26 AM
Alignment issue guscab Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-08-2014 10:26 PM
