Old 03-23-2017, 09:50 AM   #43
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Just came across this thread. Dope as fuq and such a clean build.
The Following User Says Thank You to NyC Zn6 For This Useful Post:
xkalelx (04-11-2017)
Old 04-05-2017, 07:05 PM   #44
504
504's Avatar
Drives: 2014 86 GTS
Just out of curiosity, was there a conclusion as to why the engine threw a rod? Tune always seems suspect during low load failures to me but I guess something could've given before the incident
504 is offline   Reply With Quote
Old 04-11-2017, 09:37 AM   #45
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Got my new STILLEN calipers mounted and bled. Im pretty stoked. Still waiting on an engine though. This wait is killing me.
xkalelx is offline   Reply With Quote
Old 04-11-2017, 09:55 AM   #46
xkalelx
xkalelx's Avatar
Thanks man! #savethefenders
I completely agree with you. I would like to think my tune was bombproof and still stand by it regardless of the catastrophic event. It was tuned at Dynosty by Hal in Louisville via EcuTek for a total of 3 days to work all the bugs out on my 93/e85 maps. Ive never had a better running car. There were multiple failsafes build into the tune as well as running hardware failsafes.
Here is the best synopsis I can provide. The morning it let go was around 5degF. There were a series of really cold days that week as I used this is my primary vehicle to drive to work. I think heat cycling propagated micro fissures/cracks in the #1 rod small end neck. Seeing the track abuse it did (it gets the piss kicked out of it) and being at 380/300 for 30k miles took its toll on the OE rods. I always let the engine idle for 20sec or so before taking off an do not put any more than 20% load/zero boost on the engine until completely warmed up. The day she let go was no different. Engine was warmed up, oil temps were ~190degF. AFRs looked fine the whole way into work with no alarms. There was no evidence of a detonation event. It is my best guess that I developed a structural linear defect in the rod end and due to the heat cycling on that cold morning that linear defect finally grew to failure.
All in all, I'm impressed the stock form FA lasted as long as it did at the power level I was at. I'm just glad it didn't fail on track as that would have been worse. I plan on having Hal tune the new engine and will be shooting for 400whp for now until I can get a transmission upgrade.
Thanks for the look!
Sam
The Following User Says Thank You to xkalelx For This Useful Post:
504 (04-11-2017)
Old 04-17-2017, 05:51 PM   #47
xkalelx
xkalelx's Avatar
Prepping my intake/fuel setup. MY17 manifold ported to 72mm, Grams 72mm TB, Radium Eng fuel rails, Deatschwerks 700cc injectors fresh from being cleaned and flow tested at Fuel Injector Clinic. So excited to results of dyno next month.
Old 04-17-2017, 06:00 PM   #48
xkalelx
xkalelx's Avatar
Engine being assembled at Moto-East! <itshappening.gif>
olsonpg (04-17-2017)
Old 04-18-2017, 10:15 AM   #49
xkalelx
xkalelx's Avatar
Thinking about running this Bosch 3bar TMAP instead of an OMNI. I keep hearing they are way better tuning wise. Going to give my tuner an option. Would be easy to modify the manifold to accept it. Would only run a 3 wire connector so the IAT wouldnt be utilized. This is a MAP sensor used in boosted Mercedes.
Old 05-08-2017, 02:34 PM   #50
Apex-Apex
Apex-Apex's Avatar
Sooo time for that Motec?
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 05-08-2017, 03:58 PM   #51
xkalelx
xkalelx's Avatar
Motec M150 PnP is being purchased today through Dynosty.
DustinS (05-09-2017)
Old 05-09-2017, 02:39 AM   #52
Apex-Apex
Apex-Apex's Avatar
yessss!!
IG: @apexapexapex
Old 04-19-2019, 02:20 AM   #53
Go Frogs
Go Frogs's Avatar
Drives: '19 WRX Base in Lapis Blue
samweldspooru, is that you?
I just saw your post on the vortex and I would like to ask you a few questions.
I am considering a BRZ as my next car, but I'm also considering a GSW 4mo/Alltrack as well; each for their unique qualities and I'd like to get some words with people that have experience with both.
I'm a 15 yr Mk4 GTI owner, so I know my way around the VW community and cars; however, the BRZ is a new game.
If you don't mind, I would like to drop you a private IM to discuss more about the BRZ as a "practical" daily as that is what it would be if i choose it over the GSW/Alltrack.
Thanks. Cheers.
#Savethemanuals
#Savethewagons
#Savethemanualwagons
Dear SoA, what petition do I need to sign to bring the LeVorg 2.0t 6spd to North America?
Go Frogs is offline   Reply With Quote
Old 09-11-2019, 06:55 PM   #54
rixter145
Sleep Chomper
rixter145's Avatar
Can you show where you routed the ducting to?
rixter145 is offline   Reply With Quote
Old 09-12-2019, 09:21 AM   #55
xkalelx
xkalelx's Avatar
I still havent ran the ducting anywhere. Lazy.
Old 09-12-2019, 06:40 PM   #56
rixter145
Sleep Chomper
rixter145's Avatar
Lol so how does it look like right now? Can you just snap a pic?
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 03:41 PM
Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA bren5279 Engine, Exhaust, Bolt-Ons 69 06-29-2015 11:56 PM
Garage fr-s oaroyale Scion FR-S / Toyota 86 GT86 General Forum 0 01-07-2013 06:38 PM
