Old 03-07-2017, 02:01 PM   #15
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Seems like a vague non-answer.
So, in the specific context of a twin, there's nothing in the engine bay that will get damaged by getting water on it?
No more than it being an issue on any Evo, Ferrari, Viper, Vette, etc.
Originally Posted by humfrz
I'm old and lazy
Old 03-07-2017, 02:40 PM   #16
Fuse box and alternator but there really wouldn't be much get at them with the position of the opening. Not a real concern.
Old 03-07-2017, 03:55 PM   #17
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Originally Posted by blackfireball5 View Post
Wondering if this will have clearance with the FBM Turbo Kit. Seems as though that vent drops pretty far down.
Likely. Go to my build thread and look at my clearances. I have a relatively high turbo setup. This hood was made to fit on my car so if you have anything sticking up higher than I do, it will interfere.
Originally Posted by shiumai View Post
Wondering the same thing about the Edelbrock SC kit/intake. I really like the look of this hood (as far as all the vented ones go).
I would say very likely since the Edlebrock sits so far back in the bay, albeit tall.
The vent scoop is a 3" drop and the opening is just in front of the pulleys/belt.
xkalelx is offline   Reply With Quote
Old 03-07-2017, 04:11 PM   #18
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
How far back is the lowest part of the drop from the leading edge of the hood? It looks to be around 8" or so. And how wide is the vent? 15" or so? On the Edelbrock, the airbox and MAF housing tube would be the main cause for clearance concerns, I believe.
shiumai is offline   Reply With Quote
Old 03-07-2017, 08:10 PM   #19
CSG Mike
CSG Mike's Avatar
On a stock car? No.
Aftermarket parts? Depends on the part.
Old 03-07-2017, 09:46 PM   #20
Gunman
Drives: 2019 Mazda Miata RF
FYI, that radiator exit duct would work a lot better, if there was a duct from the back side of the radiator, up to the hood exit.
Old 03-08-2017, 12:29 AM   #21
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
On a stock car? No.
Makes me wonder about worst case scenarios though. For example, if I were to park on the street here in NYC and it happened to snow a ton. Snow would basically build up on top and potentially fall into the engine bay through the reverse scoop. Once in there, would the snow sitting on belts, pulleys, compressors, etc. not be damaging?
Looks like a damn good hood though, has my attention more than any other aftermarket one I've seen so far. Actually functional and not too gaudy (I'd definitely have it paint matched to OEM, with some bits like the scoop/ducts left in CF).
Old 03-08-2017, 01:55 AM   #22
CSG Mike
CSG Mike's Avatar
I wouldn't worry about that. I'd be more concerned about water dripping onto a hot turbocharger, or header.
A few well placed heat shields can mitigate that, as can just taping over the vent.
Old 03-08-2017, 08:58 AM   #23
shiumai
shiumai's Avatar
Since it's custom made, I'm sure that it wouldn't be too hard to ask for a removable cover for the scoop that has a smaller vent near the top, to close it off if needed. If it's cold enough outside for it to be snowing, you don't really need the duct to be fully open when driving.
Old 03-11-2017, 10:08 PM   #24
xkalelx
xkalelx's Avatar
Heres a sweet shot of the hood. Photo credit to Cisco.
Old 03-11-2017, 10:18 PM   #25
xkalelx
xkalelx's Avatar
Not sure and dont remember, Ill post some shots once I get it in my hands. Kind of annoying Joel isnt on the forums. I know its roughly 14"x3".
Agreed. May do that someday but in the meantime my turbo and plumbing all run in between the engine and radiator.
The opening is forward of the pulleys and belt so I dont think a mound of snow would do anything detrimental. I have Joel epoxying in some hexagon wire mesh on my opening to keep leaves and snowballs out.
Thats a sexy idea depending on the color. I personally love that effect on red cars.
Theres a lip on the opening. Would be easy to (or have Joel) drill holes for a removable plate. Joel is currently epoxying in hexagon wire mesh on mine.
Old 03-12-2017, 01:46 PM   #26
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
@xkalelx is this a 2-piece hood that has been bonded together? (Inside/structure skin and outside/exterior skin.)
Old 03-13-2017, 08:18 AM   #27
xkalelx
xkalelx's Avatar
No. This is a full 100% carbon fibre part. No internal structure like the Seibon. Which explains the super light weight. Its only a couple layers thick. Joel also excludes all of the unnecessary ribbing/structure on the underside that are needed on a metal hood.
Old 03-22-2017, 01:26 PM   #28
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Got a price point update. its $1300+freight.
Any possibility of a lower priced FRP version?
kask2_6.0 is offline   Reply With Quote
APR Carbon Fiber Radiator Cooling Plate & Brake Ducts LANI86 Exterior Parts (Aero, Lighting, Etc.) 3 12-21-2016 06:19 PM
Looking for R35/GT-R Aero data... on the NACA ducts Kiske Other Vehicles & General Automotive Discussions 0 03-03-2016 08:34 PM
Hood Venting, NACA Ducts Lunatic Scion FR-S / Toyota 86 GT86 General Forum 70 02-08-2015 11:10 AM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 01:39 AM
APR Performance Carbon Fiber Brake ducts! enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2013 02:56 PM
