Old 03-08-2017, 01:01 PM   #1
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Backup camera stopped working
It's been years since I installed it but I think it's the Rydeen Duo camera with SVXdc wiring harness
I checked and have power for the reverse lights signal
I have power at the 12v ACC
AND I have power at the camera power connector (but the test light is not nearly as bright) but only when it's unplugged from the radio.
When the harness is plugged back into the radio the red wire loses power.
So what's going on here?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 03-09-2017, 01:46 PM   #2
NickB34
Drives: 2014 BRZ
I just went through this same thing, only my camera lasted about 4 months... From everything that I can tell, if the head unit doesn't detect a video signal on startup then it will stop sending out the 6V power from the head unit. I narrowed my problem down to being a bad camera by using a different source for the head unit (old digital camera with an RCA output). I've got another backup camera on the way from Amazon... I'll try and update when I get that installed.
Another thing that was helpful was to go into the diagnostics menu of the head unit as it is able to detect all the connections. If you go into the camera settings, you can see any feed that is present. Do this by holding down the "Audio" button for 3-4 seconds and then hold down another button while you are still holding the "Audio" button.
NickB34 is offline   Reply With Quote
Old 03-09-2017, 07:40 PM   #3
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Had an issue with my camera a few weeks ago, but I'm not exactly sure you'll be having the same issue. Mine turned out to have a broken wire going to the camera itself. How did you route your wiring in the rear?
I fed mine through the rubber connector that houses all the wires going from the body to the trunk. Had to do some emergency surgery to fish the wire out and re-solder it. If everything looks good up front, might have to head back to the camera.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
The Following User Says Thank You to Manic For This Useful Post:
FLYFISHR (03-15-2017)
Old 03-09-2017, 11:27 PM   #4
IgamaS
Drives: 2015 Whiteout FRS
Where did you tagged all your wires at?
IgamaS is offline   Reply With Quote
Old 03-09-2017, 11:36 PM   #5
NickB34
Drives: 2014 BRZ
Not sure what you're asking here...
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 03-10-2017, 09:44 AM   #6
tobin
tobin's Avatar
Drives: '13 BRZ
I would start by redoing all the connections, even if they look good. I bet something came undone.
tobin is offline   Reply With Quote
Old 03-10-2017, 10:05 AM   #7
jasonojordan
Drives: 2013 satin white brz limited
Id also consider soldering the joints or at the very least use a crimp connection
jasonojordan is offline   Reply With Quote
Old 03-10-2017, 09:04 PM   #8
z2two
Drives: Frs
you're ground wire could be broken somewhere, check where you feed the wire through the trunk lid to the trunk, there's alot of friction there where the wires move.
z2two is offline   Reply With Quote
The Following User Says Thank You to z2two For This Useful Post:
Old 03-15-2017, 02:35 PM   #9
NickB34
Drives: 2014 BRZ
Mine ended up being the wiring that goes from the trunk to the camera, couldn't really tell where it failed. My guess is something to do with either cheap wiring or the cheap connector. For reference, this is what I put in and it has a funny connector in a not so great spot for our cars that makes it nearly impossible to feed it through the trunk grommet.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 03-15-2017, 02:51 PM   #10
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
My failure was also where the wires went through to the trunk lid at the flexible rubber tube. I bought a extra camera and used it for testing and that's how I tracked the problem down.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following User Says Thank You to FLYFISHR For This Useful Post:
z2two (03-26-2017)
Touchscreen stopped working bmsi30 Issues | Warranty | Recalls / TSB 9 02-28-2017 08:41 AM
drl stopped working! help. blkmamba Issues | Warranty | Recalls / TSB 10 09-29-2016 06:52 PM
Foglights Stopped Working? 636 Cosmetic Modification (Interior/Exterior/Lighting) 34 01-11-2015 05:34 AM
Lights stopped working! LittleMonster Cosmetic Modification (Interior/Exterior/Lighting) 4 10-21-2014 11:15 AM
Foglights stopped working? 636 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-05-2014 05:13 PM
