Old 12-16-2013, 11:54 PM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Foglights Stopped Working?
I installed my Winjet headlights today, and that worked great. I snapped some photos, the foglights were working excellent.
Then I went driving and they stopped working, only to turn back on halfway through the drive, then off again once I hit my driveway bump.
Haven't been able to turn them on since. I can push the button and hear the relay clicking, but no lights. Anyone have any ideas, or what I can do to troubleshoot? Thanks!
I'm using the Nigel-JDMParts Kit.
636 is offline   Reply With Quote
Old 12-16-2013, 11:57 PM   #2
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
a connection is loose somewhere. usually its the alligator clamps that fail. mine were having this issue, so i ended up soldering most of my connections instead.
Old 12-17-2013, 12:04 AM   #3
636
636's Avatar
Drives: '23 CWP BRZ
Where are the alligator clamps? I'm using the Nigel-JDMParts harness if you're familiar with that.
Old 12-17-2013, 12:16 AM   #4
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
How did you install them? When i used to drive my car, every bump i would hit, the bump would either flicker or turn off for a little.. Turns out it was my ground from my h11 harnest!
Low&Slow is offline   Reply With Quote
Old 12-17-2013, 12:17 AM   #5
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
There was a picture on southeast86 FB page, something about melted connector that looked to be by the computer in the engine bay.. I'll look and see if I can find it
Gixxersixxerman is offline   Reply With Quote
Old 12-17-2013, 12:19 AM   #6
636
636's Avatar
Drives: '23 CWP BRZ
Just wired up the red cable to battery, black to the same ground the battery is grounded to, then wires to the H11 bulbs. Other wire through the firewire, connected at the footwell and spliced into the ignition.
I would appreciate it.
Old 12-17-2013, 12:20 AM   #7
m.box.design
you must have the new harness, i have nigel's earlier harness that was a tad short, so i made some extensions. hm.. a possible loose connection is the male and female connector between the switch and the rest of the relay (i snipped the male/female connectors off and soldered a connection). you can also check your positive and negative connections at the battery terminal. initially mine were touching the relay from my plug n play hid harness also using the terminals and they were causing my lights not to come on.
Old 12-17-2013, 12:22 AM   #8
Gixxersixxerman
This was giving some of them some problems
Old 12-17-2013, 12:25 AM   #9
Low&Slow
Low&Slow's Avatar
hmm.. Could be what indesign is saying.. I would try moving the ground somewhere as a little test. (It's free!) if not, go with what indesign is saying and buy a new harness or extend yours. It could also be contacts for the.. i guess i can call it a remote wire? LOL I'm running nigel's harness, with an extra harness to convert power. (I'm running h.i.d fog lights and spliced into the side marker wire.)
Old 12-17-2013, 12:36 AM   #10
636
636's Avatar
Drives: '23 CWP BRZ
I checked that area, the switch is still sending power to the relay, so I'm assuming all's well there.
Does this look like the problem they were having? >.< I'm new to electrical, don't know what this should look like.
I'll try moving my ground if the above isn't the problem.
Old 12-17-2013, 12:41 AM   #11
Low&Slow
Low&Slow's Avatar
o.o Blew a fuse.
Old 12-17-2013, 12:50 AM   #12
m.box.design
you blew the fuse. it's supposed to be a piece of blue plastic, all you have left is a blob.
Old 12-17-2013, 12:56 AM   #13
636
636's Avatar
Drives: '23 CWP BRZ
o.o Blew a fuse.
Great, how did I manage that? Haha. Well, do you guys know which fuse I need to buy to fix this? Also am I going to have to replace the green blob thing as well?
Old 12-17-2013, 12:59 AM   #14
Low&Slow
Low&Slow's Avatar
Pull it out, i believe it is either a 20 or a 30a fuse. they go for cheap! bought myself a few dozen for $2-$5!
some guy rear ended me in stopped traffic ric342 Southern California 64 11-19-2013 05:42 AM
Scion 10 display stopped working. mid_life_crisis Cosmetic Modification (Interior/Exterior/Lighting) 2 11-05-2013 01:54 PM
AT BRZ - stopped rev matching... ray7792 BRZ First-Gen (2012+) — General Topics 2 10-31-2013 07:24 PM
Left fog light stopped working 2 days after LED switch, possible culprit? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 5 09-18-2013 12:41 AM
weird pulsing while stopped neil125 Issues | Warranty | Recalls / TSB 2 05-14-2013 11:04 PM
