Old 03-01-2017, 09:04 PM   #15
steve99
Drives: FT86
As other guys said it most likely a roblem with the VSC, this gets inputs from 4 wheel sensors and the steering angle input. if any of those are feeding in incorrect values or the steering is not reading zero at centre straight ahead position rearly weird stuff will happen.
if you have had a wheel allignment they can stuff it up if they alter teering zero position and dont reset it.
you can use techstream to check thge steering sensor is showing zero at straight ahead and also check the readout from all four wheel sensors to see they read same value when going straight.
Old 03-01-2017, 10:21 PM   #16
steve99
Drives: FT86
large difference in tyre pressures might also have an effect
Old 03-01-2017, 11:19 PM   #17
Nah
Drives: 2013 Scion Frs 6mt
Hmm I wonder what the hell that tech did... I'll check my tire pressure as it's been like 2 weeks.
Nah is offline   Reply With Quote
The Following User Says Thank You to Nah For This Useful Post:
Ultramaroon (03-01-2017)
Old 03-02-2017, 11:36 AM   #18
stevesnj
stevesnj's Avatar
Originally Posted by tato.valverde View Post
tell the dealership to "zero out" your VSC
That's probably it
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Nah (03-03-2017)
Old 03-02-2017, 11:53 AM   #19
stevesnj
stevesnj's Avatar
Here's a procedure but it's not specific for FR-s, there has to be a way to do it without a Techstream or going to a dealer
http://www.toyotanation.com/forum/88...libration.html
Old 03-02-2017, 01:52 PM   #20
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Does it only happen when you're driving alone, or also when you have a passenger? I've noticed I don't get enough weight transfer on left turns when I'm driving alone.
Weigaldo is offline   Reply With Quote
Old 03-02-2017, 02:40 PM   #21
The wording in that thread looks like it came straight out of the FSM. I suspect that if there was a way to do it without Techstream the FR-S manual would also describe the procedure.
Nah (03-03-2017), stevesnj (03-02-2017)
Old 03-03-2017, 01:44 AM   #22
Nah
the dealer told me it pulls to the left with the VSC because of "radial pull" from the tires...
Sounds like bs. Lol.
Im going to head to another dealer and have them have it done, hopefully I'll have better luck.
After the alignment the car does feel much better. Haven't checked my tire pressure yet and it's 12:41 am (EST). I'm so bored I may head up to wawa now hah
Old 03-03-2017, 01:45 AM   #23
Nah
With and without a passenger. It's worse when it's only me though.
Old 03-03-2017, 01:45 AM   #24
Nah
Yeah... I'll just take it to the dealer again. Lol
stevesnj (03-03-2017)
Old 03-03-2017, 01:54 AM   #25
Yeah, I can smell the bs all the way over here.
Oh, and -10 points for failure to check tire pressure. Get a gauge and toss that bitch in your glove box ...AFTER you use it!
Nah (03-03-2017), stevesnj (03-03-2017)
Old 03-03-2017, 02:20 AM   #26
Nah
lol than it's gonna be -20 because I do have one in my glove box...
Old 03-03-2017, 02:21 AM   #27
Nah
In all seriousness, I assumed the dealer inflated my tires because they did end up rotating my them, lets hope they at-least got that right.
Old 03-03-2017, 02:25 AM   #28
Oh, fuck me.
Humming noise on left turns. kphan Issues | Warranty | Recalls / TSB 10 10-27-2016 12:49 PM
New front sway, a little unstable on left turns loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-20-2015 08:38 PM
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
WTB: OEM Control Arms: Front Left & Back Left norcalpb Want-To-Buy Requests 0 02-26-2015 09:55 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
