Old 02-28-2017, 11:42 AM   #267
Apex-Apex
Apex-Apex's Avatar
Originally Posted by spitfire481 View Post
id2000's with m1's control drive amazing on ethanol, did it on my fa20 and the shop 2j frs is on them. even low rpm/high load is no issue so i wouldn't bother changing them out. I feel like both the 2000 and 1700 might still share some of the same low pulse width issues with 93 octane so it may not even be worth it. as far as ethanol sitting in them, i never ran 93 and all were still spotless inside. when we run c85 the seals internally do swell up and we replace and flow every season
Thanks for the insight! I ran the 2000 on my RX-7 but had some issues after 2 years but I did leave it sitting for an extended amount of time.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 03-01-2017, 02:22 AM   #268
sqd
sqd's Avatar
Drives: '13 SWP GT86
Another +1 on the ID2000s. Had them in my SR20 S14 with 600whp on E85. Super easy to drive even at low RPMs, loved them. Combined with the Nismo twin plate, thing was not far from stock to drive, which is crazy seeing how those two things (huge injectors and multi-plate clutch) usually hurt driveability.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
The Following User Says Thank You to sqd For This Useful Post:
Apex-Apex (03-01-2017)
Old 03-01-2017, 11:41 AM   #269
Apex-Apex
Apex-Apex's Avatar
Yeah definitely! Twin disc isn't as harsh as most people say they are.
IG: @apexapexapex
Old 03-01-2017, 12:14 PM   #270
DerHauptDigga
DerHauptDigga's Avatar
Drives: 2016 FRS
I see you're running 18x10 ZEs, and 265/35/18s. You look pretty tucked in the front and rear. What is your camber set to? Are you rubbing.
I have practically the same setup (except my tires are MPSS), and I would like to go lower, but I rub in the rear still at -2.2 camber, and the inner fender is "trimmed"...
2016 Ablaze FRS
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101985
Immer Not geil.
DerHauptDigga is offline   Reply With Quote
Old 03-01-2017, 12:24 PM   #271
JT.86
Drives: Scion FRS 2016
What's your offset?
Sent from my ONEPLUS A3000 using Tapatalk
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut
JT.86 is offline   Reply With Quote
Old 03-01-2017, 12:40 PM   #272
Apex-Apex
Apex-Apex's Avatar
I have -4.x on the front and -3.x on the rear. I had to roll my rears and for the front, I just let the tires rub away on the fender liner.
IG: @apexapexapex
Old 03-06-2017, 09:19 PM   #273
forevergone
Drives: FRS
Nice rim choice!
forevergone is offline   Reply With Quote
The Following User Says Thank You to forevergone For This Useful Post:
Apex-Apex (03-06-2017)
Old 03-17-2017, 01:56 PM   #274
Apex-Apex
Apex-Apex's Avatar
Finally got the T56 Magnum in
IG: @apexapexapex
The Following User Says Thank You to Apex-Apex For This Useful Post:
DustinS (03-17-2017)
Old 03-17-2017, 02:04 PM   #275
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Nice!! Still waiting on mine... 4 months later... Really jealous.
Old 03-17-2017, 02:07 PM   #276
Apex-Apex
Apex-Apex's Avatar
Where did you order yours from?
IG: @apexapexapex
Old 03-17-2017, 04:55 PM   #277
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Nice! I orderd a magnum XL last week, from the same place as Dustin, Vorshlag...hopefully I don't have to wait 4 months.
ILLSMOQ is offline   Reply With Quote
Old 03-17-2017, 05:36 PM   #278
Apex-Apex
Apex-Apex's Avatar
ah nice! What made you decide to get an XL?
IG: @apexapexapex
Old 03-17-2017, 06:43 PM   #279
ILLSMOQ
Apparently with an LS swap the magnum XL puts the shifter base perfectly in the factory position.
The Following User Says Thank You to ILLSMOQ For This Useful Post:
DustinS (03-20-2017)
Old 03-17-2017, 08:08 PM   #280
Apex-Apex
Apex-Apex's Avatar
Oh that makes sense.
IG: @apexapexapex
Toyota GRMN 86 Concept is a Race Inspired FR-S for the Street vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 12 05-07-2016 12:49 PM
Alucard's BRZ Build alucard7755 Member's Car Journals 8 03-08-2016 02:18 PM
MINOCIN's FR-S Build, not because racecar, not because street car... just, because. MINOCIN Member's Car Journals 27 11-08-2015 11:02 PM
Street/Rally Build z3ro Member's Car Journals 3 06-07-2014 06:21 AM
C-Street BRZ 192 Build Info Sccabrz192 Tracking / Autocross / HPDE / Drifting 20 04-26-2014 10:12 AM
