Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
C-Street BRZ 192 Build Info
Figured I'd start one of these now that the 2014 season is underway...
If no one else reads it, at least I will have access to my notes when needed! First off the basics... A little about me, my name is Tim, I've been autocrossing with the SCCA since 2005, driving an ES 91 MR2, STX 05 WRX, and a BSP/ASP 2007 Solstice GXP along the way. I am a dual member of the Detroit Region and the NorthWest Ohio Region. In 2013 I took a break from the sport when my son was born, and now trying to build my own car for the first time since 2006 when I sold my MR2. My more recent drives have definitely pushed my driving style to be more of the get the car pointed the right direction and get on the gas as early as possible, so far in my experience I'm getting a lot of corner-entry push that I haven't been successful in getting rid of, this car really wants to take a more speed maintenance line, and that I need a lot more practice with. Details about the setup, I'll keep this updated as things progress: 2013 BRZ Premium, 6MT with no options StranoParts Front Sway Bar Koni Sport Single Adjustable Dampers - off the shelf valving Nameless Performance Axleback with 5" mufflers HKS Drop-In Filter EBC Yellow Stuff brake pads Schroth Rallye-4 harness OE "Crash" bolts Wheels/Tires: Enkei RPF-1 17x7 et+42 with 235/45R17 Dunlop ZII As well as Stock Wheels with 235/40R17 Dunlop ZII
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ Last edited by Sccabrz192; 04-26-2014 at 10:07 AM. |
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | Scooby South (04-20-2014) |
Detroit Region, MI
After a nice wake-up call of finishing 10th of 13 at the Wilmington Match Tour last weekend, I had an opportunity to go to Grissom AFB in Peru, IN for the Indy Region Test and Tune.
My experience: Yesterday was a great day out at Peru, started in the low to mid 40s and gradually warmed to mid 60s in the afternoon. Sun was shining all day long. I started off with the setup I left Wilmington with, which I knew needed work. My first 5 runs were with the 235/45R17 ZIIs mounted on the RPF1's which had 13 runs from Wilmington. Made a front tire pressure adjustment and lowered the rebound on the front dampers considerably for the next 2 runs and found it much better. After a break and some data analysis I switched onto a brand new set of 235/40R17 ZIIs mounted on the stock wheels. Immediately the gearing difference was noticeable, but there was also considerably more push on corner entry than there was on the previous tires, I never really found a setup that was balanced to my liking as the first set was. I struggled much of the rest of the day to match my time from the 235/45's and only managed 2/10ths slower. Later in the afternoon I switched back to the 235/45s and found 1 of those 2 tenths back. In the fastest section I was on the limiter on both sets, but not enough for either to really benefit from shifting, I tried it with no success. I hot lapped both sets a bit, with the cool ambient temperatures I never got the temps up to where they started falling off, good news I probably wont need to pack a tire sprayer in the immediate future! FWIW, I'm not going to claim the taller tire is faster, especially after 1 test and tune and the shorter tire was penalized to the tune of 5 lbs per corner with the stock wheels and the narrower wheel offset, but I am thinking there isn't a significant advantage one way or the other... 2/10's is noise at this point as far as I am concerned, but they do require some adjustments behind the seat. Naturally, I found I was on-throttle much early and longer with the 45 tires, and was able to maintain higher levels of throttle input through most of the high speed sections, compensating for the reduced acceleration with the taller gearing. While the acceleration was dulled compared to the 40, I found it was more predictable, and turn in was sharper. I'm sure spending more time on the 235/40 I'll find those to ultimately be faster, but maybe not to the amount I was anticipating. In the afternoon I had issues with setting off the panic ESC system in the slalom. In the morning I had tried to attack it smooth, managing the entry speed and gradually accelerating through. In the afternoon, I tried to be more forceful in attacking it, entering the first cone at as high of speed as I could, applying brakes (man these EBC pads have a ton of bite!), then turning in, breathing on the throttle and initiating each turn earlier than the last to stay ahead as the car transitioned. The first time was great, worked well and was, I feel, much faster than my morning runs. My second attempt triggered the panic ESC system, and every run after that did the same. I had never done the pedal dance and didn't know the sequence to try it and with no data network in the middle of nowhere-indiana, wasn't able to look it up. So I'll have to try that remedy at another time. Unfortunately, I had an issue with the memory card on the data logger and lost nearly all the data from the day, lots of video to try to sort through and make some judgements, but not as helpful as the data I was expecting to have. I was hoping I could use it to determine how much faster I was making it through the rest of the course before the slalom was screwing up my times. Oh well, such is life. Finally, one of the more disheartening things of the day... at the end of the day I hopped into the FP Solstice GXP for 2 runs. 2nd run was a full second faster on index than my best BRZ run of the day... and I was a second slower raw time than the car owner and his co-driver. Ugh.
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
| The Following 2 Users Say Thank You to Sccabrz192 For This Useful Post: | BRZ21 (04-22-2014), Scooby South (04-20-2014) |
Detroit Region, MI
My best run from Wilmington... which was terrible.
[ame]http://youtu.be/CvWDIRxBLas[/ame] Run from Peru where the ESC interference is very noticable [ame="https://www.youtube.com/watch?v=NPdFZexovpE"]Peru TnT ESC in Slalom - YouTube[/ame] Compared to a much better run earlier [ame]http://youtu.be/wCjBv2SpSBM[/ame]
Drives: 2013 Subaru BRZ
Interesting comments on the 235/40's. What kind of pressures were you running on the different sets? Also, where are you running the Konis?
I think your first post may be off as you mentioned you had two sets of 245's, not 235's. :-)
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold |
#5 | |
Detroit Region, MI
I am at 29 R 33.5 F on the 40 and 29 R 35 F on the 45. The pressures still need more tweaking, i just set it where the wear was good and the car felt comfortable. Thinking the next concrete event ill drop the front pressures a little more and see if that helps it bite.
#6 | |
Do you have the Konis set to the softer end?
-John L.
Detroit Region, MI
1/2 from soft front, 3/4 from soft rear.
At Wilmington it was 1 1/4 from soft F, 1/4 from soft R
OK, your TnT setup is very close also. I don't know if the 40's being new had something to do with it - maybe you could try again at a later date now that they are both heat-cycled.
-John L.
Detroit Region, MI
Definitely could be, even before I started making adjustments the car felt much more predictable and grippier on the 45s, even in the cold, than it had at Wilmington. Which were sticker tires at that event.
#10 |
C-Street AutoX
Quick thread jack from Tim, but have you decided if you're going to stick with the RX-8, or try running the BRZ again?
#11 | |
That being said, I'm not convinced the RX-8 isn't faster, if only slightly. It feels stronger coming out of slower corners and the grip is definitely there. For me I guess it is just a preference thing. I changed my DC pro registration to the BRZ, so we will see how that goes. For some reason only Mark Andy seems interested in the RX-8, so that will be my comparison point. I know his RX-8 is much better sorted than mine is.
-John L.
#12 |
Detroit Region, MI
John,
Any plans this weekend? You should make the trip to Perrysburg for the NWOR event on Sunday
#13 |
C-Street AutoX
#14 |
Detroit Region, MI
Already committed before DR got off their lazy asses and posted a schedule. Sent from my iPhone using Tapatalk
| CounterSpace Garage 2014 BRZ (aka BRZ 2.0) Street Concept build journal | CSG Mike | Member's Car Journals | 176 | 01-26-2016 01:04 AM |
| MINOCIN's FR-S Build, not because racecar, not because street car... just, because. | MINOCIN | Member's Car Journals | 27 | 11-08-2015 11:02 PM |
| [FYI] Street Legal Info | Calidrifter | Southern California | 7 | 06-29-2012 02:02 PM |
| mines13's living in the 90's boosted street DA build. My soon to be FRS driveway pal | mines13 | Other Vehicles & General Automotive Discussions | 16 | 03-30-2012 03:30 PM |
