Old 02-26-2017, 04:26 PM   #43
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by allowe View Post
Do you actually have to take off the lca, trailing arm and toe arm in order to take the hub off?
Thanks for your reply!
Are we talking about the hub with the bearing and the studs?
No, just wheel and brake needs to come off, hub is held on by four bolts.
http://www.ft86club.com/forums/showp...0&postcount=43
ineedyourdiddly
allowe (02-26-2017)
Old 02-26-2017, 04:34 PM   #44
allowe
allowe's Avatar
Damn, strat, pro tip.
@allowe, this is a must. Frequent rookie oversight.
Fellow member's friend hosts this important page. I don't know how long they'll stay up so read while you can.
Is this the fsm? Damm id love to have this downloaded because i have the fsm but that thing is a maze to find anything.
allowe is offline   Reply With Quote
Old 02-26-2017, 04:37 PM   #45
allowe
allowe's Avatar
Yea the entire assembly, I bought the whole thing instead of trying to pack bearings myself.
Reason why I asked is because I asked someone on YouTube and they said that you have to take those arms off in order to get to the axle but he also stated that it's the same process for the hub. That's great information though! That speed censor looks like something that's easily damagable. Thanks for the info !!!!
Old 02-27-2017, 06:08 PM   #46
allowe
allowe's Avatar
Does anyone know how to take off this part of the bearing?
It's stuck on
Old 02-27-2017, 07:15 PM   #47
It's stuck on
Haha... Holy crap! That's not supposed to come apart.
Pull all the parking brake parts off and get in there with a screwdriver. It's just a little rusty. Don't cock it sideways or it will bind. Work all around so it comes out evenly.
Or, since you'll be tossing it, you can get behind it where the screw holes are and whack it with a drift punch?
If you're gentle or have extras, you can put the screws back in until almost seated and tap on those with the drift punch.
allowe (02-27-2017), strat61caster (02-27-2017)
Old 02-27-2017, 08:32 PM   #48
allowe
allowe's Avatar
I've tried a screw driver, putting weight on it. Using 2 bolts one north west and other south east and it using something in the middle to make that put spin and no luck. Idk what to do anymore :S
Thanks for your post!
Old 02-27-2017, 08:44 PM   #49
Well, there's nothing but rust holding it to the carrier. It's a tight fit. If it's crooked, it's wedged even tighter. If you got it somewhat pulled away then cinch it back down so it's straight and try again. Tap all around in a circular pattern. Not just 2 corners. Just a little at a time. You'll get it.
Old 02-28-2017, 06:43 AM   #50
allowe
allowe's Avatar
Any other ideas ? Still can't get it out
Old 02-28-2017, 12:26 PM   #51
Has it budged at all?
In detail so we don't end up going in circles, tell us exactly what you've done to this point.
allowe (02-28-2017)
Old 02-28-2017, 12:29 PM   #52
allowe
allowe's Avatar
I took a slide hammer, put it in the back of the hub part that's stuck. Went at it for 30 minutes and it didn't budge at all! I put the bolts in reverse and used a hub puller and it still won't come out
Old 02-28-2017, 12:32 PM   #53
From your pic, it looks like it may have moved some initially. That's why I ask if it has budged at all.
Is that true?
allowe (02-28-2017)
Old 02-28-2017, 12:41 PM   #54
allowe
allowe's Avatar
Is that true?
Nope it hasn't budged at all .
The Following User Says Thank You to allowe For This Useful Post:
Ultramaroon (02-28-2017)
Old 02-28-2017, 01:05 PM   #55
Shit. Take all the brake parts off. Go at it with a custom chisel (reshaped as a wedge) and a BFH.
If that doesn't work, heat the carrier with a torch and try again.
Old 02-28-2017, 03:12 PM   #56
allowe
allowe's Avatar
Anyone know how to take the parking brake off? What about the upper control arm part? I might just take that part to a shop and have it pressed out.
How do I remove this bolt o.o? Mikeez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 06-22-2016 08:38 AM
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 09:29 AM
Missing bolt.... cooldandani Scion FR-S / Toyota 86 GT86 General Forum 12 12-03-2014 07:00 PM
Bolt Ons Available for your 86! AutoRnD Engine, Exhaust, Bolt-Ons 1 07-08-2014 11:27 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
