| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#71 |
Site Moderator
Drives: Stuff
Nope, the BRZ has HID projectors (bi xenons at that) and the FR-S just has halogen projectors.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#72 |
Drives: Attitude
#73 | |
♥カレー大好き !!
Drives: ♿
#75 | |
Drives: 86
And they are more than $200 a pair. Philips Ultinon D4S 6000K |
#76 |
Drives: 2005 Legacy GT
I'd probably do the opposite and run 3000k in the headlights. It's worked well for me in the past...
#77 |
Does anyone know if these bulbs can be replaced by a simple plug-n-play with any D4S bulbs or does it have to be specifically BiXenon?
#78 |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
D4S is D4S.
Bi-Xenon has nothing to do with the bulb. ![]() Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
| The Following User Says Thank You to Jeff Lange For This Useful Post: | kevinnivek8877 (07-02-2012) |
#79 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
This.
The "Bi-Xenon" effect is actually made by changing the internals of the projector. On most, the shield that makes the cutoff in the low-beam pattern is withdrawn. I believe the higher end cars actually move the reflector as well. But that's why HIDs always have such extreme cutoff. The bulbs put out so much light that they can work as high-beams. |
| The Following User Says Thank You to Draco-REX For This Useful Post: | kevinnivek8877 (07-02-2012) |
#80 | |
Drives: 2013 Subaru BRZ MT Limited
People who just take HID lamps and stick them in Halogen housings are the EXACT people who blind oncoming drivers with shitty headlight focus and piss me off to no end. Buy a proper fucking HID housing or stick with Halogens, otherwise you have no business on the road, causing accidents with your crappy headlights just because they look "cool." Trust me...I'm a theatre/concert lighting designer by trade, I know what I'm talking about. I deal with HID lamps 50 times the size of our little D4S's on a daily basis.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#81 | |
The Bi-Xenon effect in our lamps are created by the placement and removal of a "shield" or as we call it in our industry a "shutter" into the light path at a specific focal point in the optics, which creates the hard line you see in projection on the wall. Which is why most HID's you see require more than just a reflector to work properly, they have those huge front lenses that we now see as common in HID setups. The lenses are required to create that hard edged beam which cannot be created with a reflector alone. The High Beams are just a solenoid removing the shield from the light path which creates a full beam. Most common halogen's create high beams in a completely different way. The first and most common way is to use a lamp with 2 filaments, one filament has a sheild around the bottom half of the filament which blocks light coming out of the bottom. This reflects light only from the top portion of the reflector housing which reflects the light downwards onto the road creating the low beams. The Second filament has no reflector which means the entire reflector housing is used, throwing light in all directions, not just down. The second type of system just uses the same premise but uses two different lamps, in two separate reflectors, one lamp has a shield, one does not. There is one more way which is similar to/the same as the Bi-Xenon way except using Halogen lamps, however this is rare. From what I have seen of the FRS/BRZ Halogen housings, the Halogen housings in our cars using the first 1 lamp 2 filament type High/Low Beams.
| The Following User Says Thank You to Sony For This Useful Post: | kevinnivek8877 (07-02-2012) |
#82 | |
Drives: Attitude
#83 | |
