Old 03-26-2012, 02:02 PM   #57
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Pretty much; the only problem is your visibility outside the lighted portion of the road is so much worse because of how bright it is INSIDE your lighted field of vision. Not sure if that's the bleaching of receptors that a previous poster was talking about, as I didn't look it up. Essentially, the differential between lighted and unlighted is so great that you don't have night vision. Light a match or ignite a lighter in the dark (after your pupils have dilated) and stare at the lighter: you'll see that while the lighter is bright, the area surrounding it is MUCH darker than it was without the light.
This is true. I'm personally fine with that though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-26-2012, 02:02 PM   #58
Longhorn248
Hook 'em
Longhorn248's Avatar
Originally Posted by tranzformer View Post
These guys?
http://www.amazon.com/PHILIPS-6000K-.../dp/B000LYRFLC
Note: These are the D2S version. Do they make these in a D4S?
Btw Longhorn, what would it take to go from the D4S 42V to a D2S 85V? Need a new HID ballast?
You'd need a different ballast, and then you're getting into retrofit territory
Longhorn248 is offline   Reply With Quote
Old 03-26-2012, 02:03 PM   #59
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Ballast, not sure if the burner (bulb) plug is different or not with D4S since I've never had a D4S system before but the ballast is definately different.
That is what I figured, thanks for confirming guys. Might as well just stick with the D4S and swap out the bulbs when needed.
tranzformer is offline   Reply With Quote
Old 03-26-2012, 02:05 PM   #60
Longhorn248
Hook 'em
That's probably your best option. IMO it's not worth the hassle and money to do that kind of retrofitting on a car that already has HID headlights.
Old 03-26-2012, 02:06 PM   #61
tranzformer
Drives: Zoom Zoom
Exactly. :happy0180:
Old 03-26-2012, 02:06 PM   #62
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Unless they suck There are some horrible OEM HID setups out there. Here's to hoping we won't have one of those
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-26-2012, 02:07 PM   #63
tranzformer
Drives: Zoom Zoom
I can only hope we get something along the lines of a S2000/TSX setups. But I am doubtful.
Old 03-26-2012, 02:08 PM   #64
Longhorn248
Hook 'em
From what I saw in the highway video of the red BRZ at night it looks promising. It was somewhat hard to tell though since they were also running with the fog lights on which hides a lot of the pattern.
Old 03-26-2012, 02:16 PM   #65
zoomzoomers
zoomzoomers's Avatar
Wow, this thread is like dejavu from '05 - '06 on the G35 forum. That thread was probably like 100 times longer than this and some serious experts came on to contribute.
Unless you're really bent on color of the discharged light, stick with 4300k. If you're dead bent on a warmer color, then go no further than 6000k. Or you might as well have saved your money and bought the FRS without the HID's.
Old 03-26-2012, 02:27 PM   #66
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Unless you're really bent on color of the discharged light, stick with 4300k. If you're dead bent on a colder color, then go no further than 6000k. Or you might as well have saved your money and bought the FRS without the HID's.
fixed. :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-26-2012, 02:54 PM   #67
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
you mean, cooler?
different strokes for different folks :]
on another note, will both the brz and fr-s share the same projectors?
zAnSh1n is offline   Reply With Quote
Old 03-26-2012, 02:55 PM   #68
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
btw, cooler, meaning less temperature [colder]... before t3h flames starts shooting o_0
Old 03-26-2012, 03:25 PM   #69
Longhorn248
Hook 'em
Originally Posted by zAnSh1n View Post
you mean, cooler?
I believe that halogen projectors are different from xenon projectors.
Old 03-26-2012, 03:27 PM   #70
zoomzoomers
Hahaha oops. Thanks for the fix guys. I must have had a brainfart.
