Old 02-10-2017, 08:22 PM   #43
troek
troek's Avatar
Drives: 2012 Toyota 86
P.S. my car makes more with the stock front pipe on... which tells me something is causing a power reduction. My car also has smaller gains on Ethanol than the original 2015 car used for testing, which only tells me that my 91 tune even more spot on.
So you haven't run into issues with the stock front pipe on during track use, such as the cat over heating?
troek is offline   Reply With Quote
Old 02-10-2017, 09:52 PM   #44
CSG Mike
CSG Mike's Avatar
I have not.
My EGTs are rather high too...
troek (02-12-2017)
Old 02-10-2017, 10:24 PM   #45
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
- This is a dedicated AutoX car, with 2.5 years of competition on the motor. The motor may be getting tired.
Do you guys have evidence of the FA20 losing power over its lifespan?
If 2 seasons of autocross is enough to make a measurable loss of power then the way you guys track yours you must have seen a huge hit...
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Pat (02-11-2017), shu5892001 (02-13-2017)
Old 02-11-2017, 03:52 AM   #46
CSG Mike
CSG Mike's Avatar
Well if you've seen how many FA20's i've already killed....
We have several local AutoX'ers who're not on their original engines as well, some NA, some FI.
wparsons (02-14-2017)
Old 02-11-2017, 02:20 PM   #47
strat61caster
So engines blowing = loss of power over time?
Sorry, that's a new relationship to me and based on my limited knowledge I can't even dream up a hypothetical cause and effect.
It's fine if you don't care to elaborate, it just stuck out to me as an unusual revelation given that we've entered an era where some well designed engines are still putting out factory numbers after a decade+ of abuse and these things were theoretically designed to put up with a fair amount.
I'm well aware the FA20 isn't invincible and many have blown up under mundane usage, let alone hard autox and even casual track usage.
ineedyourdiddly
Old 02-11-2017, 05:00 PM   #48
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Aside from what the peak numbers show, the ace header does look to have a much nicer torque curve, IMO. You get the torque surge before 3k rpm and is maintained up to 6.8k vs the nameless where that mound of torque builds right before 4k rpm and drops at about the same spot. Another thing I noticed form looking at dyno graphs from Churches' dyno. They always read very high for a given setup compared to all others.
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
blues15dp (06-28-2017), Tokay444 (02-11-2017)
Old 02-11-2017, 07:12 PM   #49
Tokay444
Originally Posted by Decay107 View Post
Ten out of ten adult tuners agree, EL>UEL.
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
2015firestormFRS (09-08-2017), Hyper4mance2k (02-14-2017)
Old 02-11-2017, 10:36 PM   #50
CSG Mike
CSG Mike's Avatar
Tell that to Ferrari Challenge teams who rebuild every 2000km of use because the output drops to noncompetitive levels, even for gentleman drivers.
Old 02-11-2017, 11:28 PM   #51
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Your tuners are mistaken.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Old 02-11-2017, 11:30 PM   #52
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
That's quite a different comparison... don't you think?
Old 02-12-2017, 02:49 AM   #53
Tokay444
You could argue that leak down numbers outside the factory allowances could constitute as a blown engine.
Old 02-13-2017, 12:30 AM   #54
strat61caster
Well that's exactly why I'm asking, if two measly seasons of autocross is enough to make a >$2k modification not worth it, it seems like some of us would be better off finding low mileage replacement engines than buying nice headers.
ineedyourdiddly
shu5892001 (02-13-2017), Ultramaroon (02-13-2017)
Old 02-13-2017, 10:12 AM   #55
Icecreamtruk
Drives: Track preped NA FRS
I will actually know how much 13 track days (some HPDE, some time attack, average track time is around 2h per track day) can do to the engine output. I will dyno it again at the same dyno it got tuned after getting headers, altho it had already seen a fair amount of track time by then (car had 3 years and over a dozen track days already when I got the headers+tune). I will try to report after I do it (if I dont forget). I still have the original dyno plots laying around (and can probably ask for an overlay of both of them).
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
strat61caster (02-13-2017)
Old 02-13-2017, 11:30 AM   #56
Lantana frs
Drives: 13 frs red
From my experience tired motors have more leakdown and less energy transfer due to worn crank and rod bearings. I wonder what effect e85 will have on valves and seats.
Lantana frs is offline   Reply With Quote
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Has there been a direct comparison of JDL UEL vs Nameless EL Headers? Kido1986 Engine, Exhaust, Transmission 9 02-13-2015 02:47 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Header comparison. NO E85 NickFRS Engine, Exhaust, Transmission 29 05-16-2013 04:01 PM
Header comparison itwillboost Engine, Exhaust, Transmission 1 03-19-2013 12:58 AM
