Old 02-06-2017, 07:28 PM   #4033
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
Originally Posted by timso098 View Post
Sounds good. Going to install at my shop with the mechanic I work with. But for the placement of the reservoir where did people install them? Ive seen people with it in the front in the middle by the bumper. Any reason why it would benefit from being located there instead of being by the battery?
I tried to mount it near the battery location that the instructions told me to, but the directions were vague and I think I was missing a bracket or two. I did get as far as removing the battery and trimming the plastic tray it sits in in order for the SC oil reservoir to fit. However, after thinking to myself this is a dumb place to put it and then looking at some pictures online from others' installs "the front in the middle by the bumper" location made more sense. Also, it reduces the length of hoses that have to route in between the SC, oil cooler, and reservoir. So, no. There is no benefit from mounting it near the battery from my experience.
Helios is offline   Reply With Quote
Old 02-06-2017, 07:29 PM   #4034
Helios
Helios's Avatar
Originally Posted by pgranberg11 View Post
I don't know how you would do it with one person otherwise.
I used my 18V Ryobi air pump to "blow"/ prime the oil through the system. Worked like a champ.
The Following User Says Thank You to Helios For This Useful Post:
pgranberg11 (02-07-2017)
Old 02-06-2017, 08:34 PM   #4035
bfrank1972
Drives: 2013 FR-S Argento
Yup that's what I'm planning to do, here's a good video for illustration:
[ame="https://www.youtube.com/watch?v=AeyqWWKE7b8"]Kraftwerks. Priming Oil System - YouTube[/ame]
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 02-07-2017, 08:51 AM   #4036
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I've seen both places. I put mine by the battery since that's what the instructions stated. But I do notice some people put them in the front by the bumper. So I suppose whatever is easier for you.
pgranberg11 is offline   Reply With Quote
Old 02-07-2017, 10:02 AM   #4037
bfrank1972
Is this system gravity fed? Just wondering as if it's mounted too low it might cause flow issues?
Old 02-07-2017, 10:08 AM   #4038
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Not sure to be honest, I just followed the instructions stated. this was also taken from the rotrex handbook:
"The oil lines and the oil system components (filter, canister and cooler)
must be placed below or level with the supercharger shaft"
and
"To prevent oil leaks it is of utmost importance that the oil cooler, oil
filter and the oil canister with its cap are placed below or level with
the supercharger shaft."
Old 02-07-2017, 10:15 AM   #4039
bfrank1972
and
Ah so it's opposite of what I'm thinking
Old 02-10-2017, 09:33 PM   #4040
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
is there any kind of guide for regular maintenance for this kit?? Like how often belts should be changed, fluid intervals, etc?
Super Dave is offline   Reply With Quote
Old 02-11-2017, 06:11 AM   #4041
Helios
Helios's Avatar
I don't remember anything about a belt change interval, but it can depend greatly on where you live, garage kept, miles, etc. A new belt cost approx $65-85.
https://www.yourmechanic.com/article...rger-belt-last
The Rotrex manual states to change the supercharger oil every 50k miles or 2 years, whichever comes first. Rotrex oil is $100/ litre.
What I will most likely do is replace the belt, filter, and oil every 50k miles or 2 years. It'll be a couple hundred dollars, but that's cheap insurance to ensure many happy miles from the kit.
Old 02-11-2017, 12:42 PM   #4042
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
Thank you for replying. Thats actually a whole lot less than i was expecting!
Old 02-11-2017, 04:35 PM   #4043
Helios
Helios's Avatar
Originally Posted by Sgtfluffy16 View Post
This is my plan as well. However I may take it to three years because I only put 6-7000 miles on my car every year
Not many miles for sure, but I'd personally be worried about how well the oil has held up over 3 years.
Old 02-27-2017, 06:28 PM   #4044
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
Originally Posted by scionfr_s View Post
Can anyone tell me what is this noise that come from SC?? I guess it is a pulley when it get hot
Did you ever figure out your noise? Im getting a similar noise.
Old 02-28-2017, 07:49 PM   #4045
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
For both people who posted videos, does the abnormal noise speed up with the revs? If they do then you most likely have a bad bearing in one of the pulleys.
Sent from my Nexus 6 using Tapatalk
The Following User Says Thank You to pgranberg11 For This Useful Post:
Freeman (03-05-2017)
Old 03-01-2017, 10:36 AM   #4046
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
Honestly its somewhat difficult to hear while im driving. But from what I can hear yes it speeds up with revs. I know it only really happens once the car warms up. We had tightened the belt at one point and it definitely got louder. Once we loosened the belt up it went away for a bit and is now back but not as loud. I also sprayed a little belt spray on the cogged supercharger belt and the noise got quite a bit louder. At this point im hoping that means its not the blower its self and rather a bearing.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
