Old 01-29-2017, 08:11 PM   #1
Shady195
Drives: '13 10 Series FRS #1203
Fan on Oil cooler?
Curious if anyone has done this?
When drifting there is not a ton of airflow going through the oil cooler, and with back to back runs it can get pretty warm. I usually just drive my car up and down the lot a few times and they start to decrease.
I was debating running a fan in the pull configuration to help aid airflow while drifting or after a run for cool downs.
Are there any real drawbacks? I figure it may hinder airflow a bit, but not sure if there are any real adverse effects to doing this or how severe they might be?
Is it worth it? It would be a pretty small fan, the few I've seen are around ~150CFM rated and they are all kind of pricey. If anyone has any input id be open to hear it!
Shady195 is offline   Reply With Quote
Old 01-30-2017, 01:46 AM   #2
steve99
Drives: FT86
If your oil cooler radiator is in front of your coolant radiator then you (or your tuner) could just adjust the radiator fan temps and speed thresholds to get the radiator fans to run at lower speeds and temps.
see below
or just turn the air con on at end of run and fans will run
Old 01-30-2017, 11:55 AM   #3
Shady195
Oil cooler sits off to the right side out of the way with ducting next to my intercooler so unfortunately the stock fans don't do much for me. Thanks for the tip though!
Old 01-30-2017, 12:14 PM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I cannot think of a drawback. I would just make the fan manually controllable. You don't want it running all the time, just during and after runs.
Old 01-31-2017, 01:24 AM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The only question is going to be, what are your oil temps before, during, and after your runs?
If you are getting enough heat where you are in need of active airflow, then the answer is yes.
If you are not getting hot enough (over 125C) then you should not.
-alex
Oil Cooler ryoma Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 04-12-2023 03:09 PM
oil cooler in PA/NJ nickmerronesucks Want-To-Buy Requests 0 03-30-2016 01:44 PM
B&M Oil Cooler? LS1M Engine, Exhaust, Transmission 7 06-05-2015 10:54 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
