Old 06-04-2015, 05:20 PM   #1
LS1M
Drives: 2015 BRZ
B&M Oil Cooler?
Has anyone ever looked into using one of the B&M supercoolers with the built-in fans for oil cooling? Model 70297 or 70298? How do they compare to some of the others like the Mishimoto or Perrin models, or the Jackson Racing model? I did a search and only found a couple of people using them for automatic transmissions. Assuming I can find a place to mount it, would it cool as well?
Thanks!
-Mark
LS1M is offline   Reply With Quote
The Following User Says Thank You to LS1M For This Useful Post:
DAEMANO (06-05-2015)
Old 06-04-2015, 10:22 PM   #2
stevesnj
stevesnj's Avatar
with the fan and aluminum construction this will work great IMHO. No need to buy a racing oil cooler when something like this would be sufficient. I am considering this also. If you intend to race other than Auto X or weekend track days I say this is a good deal.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Old 06-04-2015, 11:25 PM   #3
LS1M
Drives: 2015 BRZ
I just wonder where it might fit... Engine bay is crazy tight already. Behind radiator under the air filter maybe?
Old 06-05-2015, 02:47 AM   #4
DAEMANO
Time Traveller
I like this idea. It should fit in the same place the Full Blown Oil Cooler goes (under the passenger headlamp, behind the foglight).
The Following User Says Thank You to DAEMANO For This Useful Post:
stevesnj (06-05-2015)
Old 06-05-2015, 04:44 AM   #5
sw20kosh
Drives: 2013 Black FR-S
You do realize that fans play 0 part in cooling in anything above rush hour traffic and parking lot speeds? In fact they hinder cooling at high speed. Speed seen on a race track or a back mountain road.
Fans are only on radiators etc for low airflow situations.
Old 06-05-2015, 09:39 AM   #6
stevesnj
stevesnj's Avatar
I disagree, but it has a thermal switch for fan cooling when necessary. If the fan goes on then off it is cooling the oil passing through it. Usually the oil gets hotter under load and this extracts the heat. B&M has been around a long time. I'm sure this wouldn't be on the market if it didn't do what it is advertised to do. Just don't know how an oil cooler with a fan is ineffective in all driving conditions. I may be wrong
Old 06-05-2015, 10:20 AM   #7
zooki
Drives: waiting on a 2021...
This is true if the cooler directly in the airflow. With a fan it allows more mounting options.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Old 06-05-2015, 10:54 AM   #8
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by stevesnj View Post
I disagree
“The good thing about science is that it's true whether or not you believe in it.”
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
stevesnj (06-05-2015), sw20kosh (06-05-2015)
Oil Cooler Set Up – DIY? toraider Engine, Exhaust, Transmission 25 08-12-2015 06:59 AM
Oil Cooler Wyattkb Want-To-Buy Requests 0 02-22-2015 12:27 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
