Old 01-13-2016, 05:56 PM   #29
tinma
Drives: '13 BRZ
Originally Posted by NyC Zn6 View Post
Thanks for the response. Has it given you any issue's after they replaced it? Taking my car to dealer this weekend hopefully they don't give me a hard time.
No issues ever since. Looks perfect now
tinma is offline   Reply With Quote
Old 01-19-2017, 03:59 PM   #30
cto424
Originally Posted by stockysnail View Post
I just threw in the switches and called it done. Working much better now. I'm guessing a slight alignment would be ideal but that's too much work and it's good enough I think. To do the alignment look at Subaru Service Bulletin 07-79-13R. You have to remove the window and get a special window tool to do it. You'll also need to replace the weather strip if it has been damaged, but that's the easiest part of all of it. I say throw in the new switches first, then see if you need the rest.
Got a part number for the door switches? And is it easy to swap out?
cto424 is offline   Reply With Quote
Old 01-19-2017, 04:06 PM   #31
Everything including part numbers and how to swap instructions are here:
http://www.ft86club.com/forums/attac...1&d=1389643313
cto424 (01-19-2017), funwheeldrive (11-06-2017), Prodigalson (10-10-2024), Ultramaroon (12-06-2018)
Old 01-19-2017, 08:54 PM   #32
stockysnail
Just the tip
stockysnail's Avatar
I didn't write them down after I did the swap. See the guy's post above or go to the dealer and ask for the driver/passenger window switch. They are a p.i.t.a. to remove from the pastic housing as they weren't meant to be removed, but putting the new one's in is quick and painless. Eventually you'll pay a blood sacrifice to your car, so perhaps removing the window switch will be your time. May be easier with 2 people as one could pry the plastic away while the other pulls it out. You'll see what I mean once you remove the door panel and the plastic bit where the switches sit.
The Following User Says Thank You to stockysnail For This Useful Post:
cto424 (01-20-2017)
Old 06-29-2017, 10:52 AM   #33
PerCompLLC
Drives: 2019 86 TRD SE
Originally Posted by jeffchap View Post
Mine was rolling up and causing a gap at the top rear corner of the window, and the wind whistled thru it at highway speeds. Here's my redneck fix...
I cut a 6" piece of coax I had lying around and slipped it into the channel in the top of the seal right where it rolled over. No more rolling, and it's invisible and free.
I've been a member for awhile. I wish I had enough posts to "like" this post as I am having the exact same problem with my 2013 FR-S which is out of warranty. Thank you for this idea! I'm also going to try using some 3M adhesive to tuck the inside edge of the weatherstripping back into the door frame where it was pulled out by the rolling action. Hopefully that will solve the issue permanently. Thanks again!
PerCompLLC is offline   Reply With Quote
The Following User Says Thank You to PerCompLLC For This Useful Post:
jeffchap (07-03-2017)
Old 01-06-2019, 10:40 PM   #34
vladniko86
vladniko86's Avatar
Drives: FRS
Did anyone ever go and have the dealer do this and how much did it cost?
vladniko86 is offline   Reply With Quote
Old 04-16-2019, 12:01 AM   #35
tian105
Drives: M4
from my understanding, the glasslifters does not need to be replaced, replacing the old window switches with new ones and changing out the molding will remedy this issue?
tian105 is offline   Reply With Quote
:popcorn:, more tagz
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 01:08 PM
Window seal cracking ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2014 08:59 PM
window seal deforming mokinbird87 Issues | Warranty | Recalls / TSB 33 10-31-2014 05:14 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 05:12 PM
