Old 01-06-2016, 02:49 PM   #1
Bamsterman
Drives: 13' Scion FRS
Driver Upper Window Seal
I know this has been discussed previously, but there's so many different answers, and opinions on this.
My FRS upper driver window seal is "rolling" when the window rolls up. Besides replacing the part, I've done everything else. Cleaning, greasing, lubing...still have the same issue. A lot of wind noise on the highway too.
Now, my question: Is the only part needing to be replaced the upper seal (part number SU003-01634) or is there more involved? Like window adjustment/realignment, initializing, and so on...
Also, did the BRZ have the same issue? If so, what was the fix? Same seal? Does anyone have the part number for that seal?
Thank you all in advance!
Bamsterman is offline   Reply With Quote
Old 01-06-2016, 05:36 PM   #2
lupindub
Drives: Scion FR-S
I'm pretty positive that replacing the seal will only make the problem come back. The root of the problem is that the window is not aligned properly and causing the seal to roll up.
lupindub is offline   Reply With Quote
Old 01-06-2016, 05:49 PM   #3
Bamsterman
I've read that as well. Which makes perfect sense. But those same people who had that done ALSO had the belt molding issue. The TSB for that issue calls for the window to be realigned or initialized...then other people have said that there dealer only replaced the upper window/door seal.
Have you had this problem before?
Old 01-06-2016, 06:29 PM   #4
lupindub
Drives: Scion FR-S
Yep my driver's side seal rolls up - especially when it rains or when there is a lot of condensation. I have learned to live with it and am not planning to get it fixed unless water starts leaking in which it hasn't.
Old 01-06-2016, 06:32 PM   #5
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Is there a photo of what this looks like? Mine is slightly off, too.
TofuJoe is offline   Reply With Quote
Old 01-06-2016, 06:50 PM   #6
lupindub
Drives: Scion FR-S
It looks like this:
http://www.ft86club.com/forums/showthread.php?t=99082
The Following 2 Users Say Thank You to lupindub For This Useful Post:
funwheeldrive (10-26-2017), TofuJoe (01-07-2016)
Old 01-06-2016, 06:57 PM   #7
As bolded. If the dealer is lazy, cuts corners or is in any other way incompetent and only replaces the rubber without changing the guides and realigning the window (as the TSB specifically calls for) the problem will just come back. Properly done the TSB will completely resolve the issue.
There are temporary ways to resolve it (such as lubing the seal) if you catch it soon enough but it does not get rid of the root cause and has to be redone periodically.
Old 01-06-2016, 07:39 PM   #8
P3tras
Drives: Subaru BRZ '13 WRB
My BRZ has the same issue. Anyone has link to TSB? It would be interesting read, if it has any info about window realignment.
P3tras is offline   Reply With Quote
Old 01-06-2016, 08:26 PM   #9
The BRZ one isn't listed but there must be one.
Here is the FRS one:
http://www.ft86club.com/forums/attac...1&d=1409711423
You will see that stabilisers have to be changed. This is the step I think some dealers skip.
NOTE: This does not mention the rubber seal but the change in stabilisers seems to fix the issue.
P3tras (01-07-2016), Ultramaroon (01-09-2016)
Old 01-08-2016, 10:47 AM   #10
frslee
Just drive it
Drives: 13' FR-S
@Bamsterman if your car is under warranty, have them replace it. I had mine dealer replace it and new part looks to be thicker and smoother.
frslee is offline   Reply With Quote
The Following User Says Thank You to frslee For This Useful Post:
Tcoat (01-08-2016)
Old 01-08-2016, 01:22 PM   #11
Bamsterman
I definitely would, if it was still under warranty. Actually, if it was just the seal that needed to be replaced, I would just do that myself. But with the window needing to be aligned, I'd rather just have the dealer handle it all.
Do you happen to have the part number for the one that was replaced?
Old 01-08-2016, 01:38 PM   #12
frslee
Just drive it
Drives: 13' FR-S
Yea, found my old post. On paper from dealer's paper, it shows SU003-01634. However if you take a look at the revised TSB, that one shows SU003-05208.
Either way, I believe the dealer should use the newest part.
If you want to temporarily fix the issue, I have a solution.. I tried and it worked. Use the matte-type tape that has very smooth finish. Clean the affected weather strip and apply the tape where it contacts window glass. As long as it sticks to the rubber, you're good to go. It's going to look a bit funny when you open door/roll down window, but at least the rubber isn't going to roll when window is closed. Try it and let me know.
[ame="http://www.amazon.com/Scotch-Magic-Tape-Inches-104/dp/B00005C3YY/ref=sr_1_4?s=office-products&ie=UTF8&qid=1452277703&sr=1-4&keywords=3m+magic+tape"]Amazon.com : Scotch Magic Tape, 1/2 x 450 Inches (104) : Clear Tapes : Office Products[/ame]
Old 01-08-2016, 02:30 PM   #13
Bamsterman
SU003-01634 This number shows as the upper seal that keeps catching. But, this number SU003-05208 shows up as the belt molding thats actually on the door. Maybe its that both parts are replaced...Either way, I'll be taking it to the dealer. And thanks for the tip with the tape! Will definitely give that a shot for temp fix.
Old 01-09-2016, 12:23 AM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
Here's why the seal rolls up.
1. early 13 MYs window index was 2 cm so, with each door open/close the window rubs through the top of the seal. Both door switches must be replaced with updated ones set to index only 1 cm.
2. Window is too tight. Requires alignment to ease it out a little. Not trivial. I've spent a great deal of time getting familiar with how the mechanism 'likes' to be aligned.
PWBRZ (01-13-2016), Tcoat (01-09-2016)
:popcorn:, more tagz
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 01:08 PM
Window seal cracking ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2014 08:59 PM
window seal deforming mokinbird87 Issues | Warranty | Recalls / TSB 33 10-31-2014 05:14 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 05:12 PM
