Old 01-10-2016, 02:13 PM   #15
Richyjc
Richyjc's Avatar
Drives: brz
same thing happened on my 2013, they changed the seal under warranty. this was 1-1/2 years ago and its been working fine ever since.
Richyjc is offline   Reply With Quote
Old 01-11-2016, 10:10 AM   #16
Bamsterman
Drives: 13' Scion FRS
Here's why the seal rolls up.
1. early 13 MYs window index was 2 cm so, with each door open/close the window rubs through the top of the seal. Both door switches must be replaced with updated ones set to index only 1 cm.
2. Window is too tight. Requires alignment to ease it out a little. Not trivial. I've spent a great deal of time getting familiar with how the mechanism 'likes' to be aligned.
Well I hope I don't have to replace the switches...I'm sure thats not cheap out of warranty.
Any chance I could get you to PM the alignment details? Like any tips or tricks...anything like that. If its not too difficult, I might just do it myself.
Bamsterman is offline   Reply With Quote
Old 01-12-2016, 12:11 AM   #17
I started a DIY last year but cut my losses after realizing there's just no way to define a step-by-step process. It's all about getting a feel for what each of the adjustment points do and then tweaking all of them to get it just right.
Each adjustment affects all the other points so it becomes quite an adventure homing in on the sweet spot.
You really need the switches. No way around it. @stockysnail?
Another member gave me a copy of the official process. It might help a little but it still comes down to patience and feel.
File Type: pdf BRZ_door_window_adjustment_procedures.pdf (127.6 KB, 843 views)
Prodigalson (10-10-2024)
Old 01-12-2016, 12:26 AM   #18
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Mine was fixed. It's fkn back!~ Grrrr....
Old 01-12-2016, 03:33 AM   #19
stockysnail
Just the tip
stockysnail's Avatar
I just threw in the switches and called it done. Working much better now. I'm guessing a slight alignment would be ideal but that's too much work and it's good enough I think. To do the alignment look at Subaru Service Bulletin 07-79-13R. You have to remove the window and get a special window tool to do it. You'll also need to replace the weather strip if it has been damaged, but that's the easiest part of all of it. I say throw in the new switches first, then see if you need the rest.
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
cto424 (01-19-2017), funwheeldrive (10-26-2017)
Old 01-12-2016, 09:27 AM   #20
Bamsterman
I foresee this being an expensive fix...
Old 01-12-2016, 09:30 AM   #21
Bamsterman
Is there a bulletin for the switches? Or is it any new switch from the dealer will be the new "fixed" switch?
**EDIT**
Never mind, I found it.
Old 01-12-2016, 02:15 PM   #22
No need to remove the window. The tool would be good to have if doing an installation from scratch and working against a clock. The final tweaks to which I am referring are within the tolerance specified in the published procedure, require patience, and a keen eye.
Old 01-12-2016, 02:23 PM   #23
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Mine was rolling up and causing a gap at the top rear corner of the window, and the wind whistled thru it at highway speeds. Here's my redneck fix...
I cut a 6" piece of coax I had lying around and slipped it into the channel in the top of the seal right where it rolled over. No more rolling, and it's invisible and free.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
The Following 5 Users Say Thank You to jeffchap For This Useful Post:
kravi (03-10-2017), NyC Zn6 (01-13-2016), ShoGun (04-08-2017), soulreapersteve (04-08-2017), Ultramaroon (01-12-2016)
Old 01-13-2016, 03:16 PM   #24
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Same issue i am having right now when i close my door and windows roll up it pushes the rubber back. Is there a TSB for that issue? If not time to haggard my rubber like yours lol. Sucks we have to resort to this smh shitty ass car lol
Old 01-13-2016, 05:30 PM   #25
tinma
Drives: '13 BRZ
I had the same issue and brought it to the dealer. They replaced the strip for free and everything is OK now
tinma is offline   Reply With Quote
Old 01-13-2016, 05:46 PM   #26
NyC Zn6
NyC Zn6's Avatar
Did they replace the top strip located on the car frame on the strip on the door?
Old 01-13-2016, 06:07 PM   #27
tinma
Drives: '13 BRZ
They replaced the strip located on the frame of the car
The strip that you are pulling down on in your first picture
The Following User Says Thank You to tinma For This Useful Post:
Old 01-13-2016, 06:32 PM   #28
NyC Zn6
NyC Zn6's Avatar
Thanks for the response. Has it given you any issue's after they replaced it? Taking my car to dealer this weekend hopefully they don't give me a hard time.
:popcorn:, more tagz
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 02:08 PM
Window seal cracking ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2014 09:59 PM
window seal deforming mokinbird87 Issues | Warranty | Recalls / TSB 33 10-31-2014 06:14 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 06:12 PM
