Old 01-28-2014, 01:37 AM   #1
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
window seal?
My driver side window seal on the top rolls and curls up after window is rolled up... I have to push out on the window to allow is to close properly. Anyone else having this problem? Tried to search threads but found everything but window seal thread come up. I can take pics if you need to see what I'mtalking about.
Thanks,
Mike
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 01-28-2014, 02:44 AM   #2
strat61caster
strat61caster's Avatar
http://www.ft86club.com/forums/showthread.php?t=11682
If it's letting water in the dealership should replace the seal. You can try complaining and getting the seal replaced just because it's annoying but it seems to just be a little quirk.
Mine did it and went away over time, no issues keeping water out of the cabin after a year of ownership. Some have tried a lubricant to allow for some sliding with success. I haven't touched mine.
ineedyourdiddly
Old 01-28-2014, 09:36 PM   #3
kodyo
Drives: Scion FR-S
Same issue. Strongly debating gluing it in place to keep from rolling up as bad as well as lubricating. Maybe try 3M weather strip sealant seeing as I have a whole tube left over from the gasket replacement.
kodyo is offline   Reply With Quote
Old 01-29-2014, 05:12 PM   #4
Mongo
Mongo's Avatar
If its leaking get it replaced
If its just aesthetically annoying you might try this \/
Rubbed the "seal"(for lack of a better word) down with tire shine
then cleaned with interior cleaner
fixed the problem
6 months later the problem hasn't come back I use Griots interior cleaner on the strips about once a month. Don't think brand of cleaner matters but griots smells nice
note: It did leave streaks of tire shine bleeding from the rubber on the window for about a week. Just used microfiber cloth to wipe the window down every time I got in
Mongo is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Drivers Side Window (Not Seal) Mister Issues | Warranty | Recalls / TSB 20 12-16-2013 02:56 PM
Window Seal Leaves Marks on Windows AsianStyle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-22-2013 03:28 PM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 05:32 AM
