#57 |
Turning is for Nerds
Drives: 35 characters is not enough
Look on the bright side, at least it wasn't a permanent part of the manifold. Can you imagine if a manufacturer did something as stupid as that?
#58 | |
Drives: stx class lava frs
1. All FI kits remove/replace emissions control equipment. ( intakes, air filter boxes, computer tunes, and sensors are all included with the cats under the heading of "emissions equipment "). 2. Removing and replacing these items is perfectly legal if there is a CARB/EPA certification-exemption for your specific application. This is an expensive, and difficult process,(I had to deal with it while working in R&D at AEM as well as DC Sports, among others) but the OEM guys are super good at it. 3. A turbo kit with the engine>turbo>cats sequence could be made CARB legal if you are willing to go through all that. (Certification of the new cat arrangement) 4. While I am running a SC and I am super happy with it, I am not anti-turbo. I think if I was into time attack, or drag racing, or was looking to make 400+ Hp, I would likely be running a turbo, and I would be just as happy. Again, not looking to push one over the other, but depending on your priorities, what works best for me, might not be best for you, and that doesn't make one of us wrong. Last edited by mitch t; 01-13-2017 at 09:17 PM. |
#59 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
This has been the most polite exchange of opinions I've seen on this forum.
Well done!
"I gotta rock." -- Charley Brown |
#60 | |
| The Following User Says Thank You to Tokay444 For This Useful Post: | johan (01-13-2017) |
#61 | |
Drives: Corsa VXR Stage 3
Thanks for the input. |
| The Following User Says Thank You to _debo For This Useful Post: | johl (01-13-2017) |
#62 | |
#63 |
Drives: blue - Cosworth SC stage 3.0
happy to discuss it openly , in the spirit of moving things forward
on a fair few OEM turbo Gdi engines we have found that they are adopting very late GDi injection timing coupled with a lot of spark retard to create a lot of post combustion in the exhaust and so spool the turbo up quickly now obviously you can only do this for 20-30 seconds or so before everything gets too hot but by that point it doesn't matter as the transient / acceleration event has passed and you're back onto steady state I feel ECUtek is capable of doing this with the custom map function and it would really help spool up a bigger turbo faster than normal however I've yet to see any tuner try this out |
| The Following User Says Thank You to Matt@Cosworth For This Useful Post: | Tokay444 (01-14-2017) |
#64 | |
As I said previously the kit from Ptuning would be my kit of choice but it's not compatible so I guess the chances are either adapt that kit, go custom or just listen to your professional advice. |
#65 | |
#66 |
#67 | |
Drives: '15 FRS
I can do that in my M150 ECU programming. I've dabbled with something like this before, and my concern has been in the 'feel' or drivability of the vehicle -- sure it might start moving the turbo sooner but is it making power to improve acceleration instead of causing what feels like a slight "delay" in the vehicle's acceleration? Worth experimenting on this motor... |
#68 | |
Drives: '15 FRS
Transient boost response is identical between shifts whether I'm using injection timing/ignition timing during transient conditions (shifts mostly in this case). I think a proper boost control system (which the MoTeC has -- I can keep the top of the WG completely closed until the moment of target boost if I want) helps more in turbo spool up than injection timing/ignition timing. |
| The Following 2 Users Say Thank You to VitViper For This Useful Post: | EAGLE5 (01-17-2017), Ultramaroon (01-17-2017) |
#69 | |
Dismember
Drives: 2013 Red Scion FR-S
#70 | |
Drives: '14 981CS, '99 NB1
The joke is on everyone. OEMs do this so they can claim their turbo engine has xyz torque from 1800rpm - 6000rpm. Doesn't matter that it destroys transient response.... because numbers win for marketing. |
| The Following User Says Thank You to johan For This Useful Post: | Ultramaroon (01-17-2017) |
| seat positioning | rainmonkey | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 12-07-2015 08:38 PM |
| Clutch Foot Positioning for MT | slow n FuRiouS | Scion FR-S / Toyota 86 GT86 General Forum | 107 | 07-14-2014 12:02 PM |
| Gauges Positioning | BadLuckZN6 | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-10-2013 07:24 PM |
| Go Pro Positioning | mechaghost | Tracking / Autocross / HPDE / Drifting | 7 | 12-15-2012 01:22 PM |
