Old 12-10-2016, 03:20 PM   #29
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Dr. BRZ View Post
NOOB.....
For a Dr., your bedside manner is questionable
Patient: doc I broke my leg, halp me
Dr: lol rekt
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following 3 Users Say Thank You to DJCarbine For This Useful Post:
Simplicity (12-21-2016), Spartarus (12-10-2016), Ultramaroon (12-11-2016)
Old 12-10-2016, 05:33 PM   #30
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
I agree on transmission oil flush. Check for metal in fluid.
If you really don't wanna do anything, then dealer warranty. Go go.
Old 12-10-2016, 05:58 PM   #31
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Changing the fluid will not fix broken parts. Doesn't matter what variety of snake oil you put in there.
People say it all the time in Manual transmission threads, because they don't understand how manual transmissions work. Most people do not give sound advice about manual transmissions because they lack technical understanding.
This is roughly equivalent to telling you to "change the engine oil and see how it runs" if you had dropped a valve. ... F*ck.
You broke the baulk ring mechanism. That was the pop. That's why it's "crunchy" on the way in to gear.
It's fine, everybody makes mistakes. Replacements are cheap.
If this transmission grinds on the way into gear, in any gear, during a normal shift, something is broken. That's what the baulk ring mechanism in this transmission does. It prevents gear engagement until the synchro sleeve and gear are moving the same speed, and partially locked together. It can't grind. If it does, metal parts are broken.*
All of the gears (There are more than 6) are in constant mesh, they don't slide in and out. The only things that slide in this transmission are the engagement sleeves, over the engagement teeth. No teeth are "chipped." The engagement teeth can be chipped, but that's impossible unless you first break the baulk ring mechanism, and then continue to shift until one chips. Either way, "chipped teeth" don't cause grinding on shifts. If the baulk ring mechanism is functioning, everything is already locked at the same speed before anything ever slides over anything else.
*If it is first engaged, and then carefully half-disengaged with the clutch draging, you can make a correctly functioning transmission in this car grind, but that's for argument's sake, and can't happen on a normal shift. There are 2 distinct steps for every gear engagement. You should be able to feel them.
Originally Posted by Norville Rogers View Post
I'm not totally with Bodalenko. It should be moderately idiot proof. They did knowingly import it into North America.
Ever wonder why there are so few manual transmissions left here in North America? Ever wonder why you can't rent one here from any major company anymore? What happens to something when it can't be idiot-proofed? When it can't be ludicrously padded and softened for idiots?
Originally Posted by ajcarson11 View Post
Ever since I purchased the car used (at 20,000 miles) I've had a tiny little crunch going from 2nd to 3rd. Never happens in any other situation -- 4th or 5th to 3rd is fine. So i am probably in the same boat as you. I've put 20,000 miles on the car with the tiny crunch and have no problems.
Yours is broken too. It's internal to the 3-4 shift sleeve.
With the baulk ring mechanism broken, the car will shift into that gear fine most of the time, but you'll wear the engagement sleeve, the engagement teeth, and the synchro rings out at an accelerated rate. The grinding will get worse until the gear becomes virtually unusable. It's a god damn Toyota though, that wear could take 100,000 miles to happen..
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 5 Users Say Thank You to Spartarus For This Useful Post:
CxG (01-12-2017), DJCarbine (12-11-2016), headlikeahole (12-10-2016), jcw99 (12-27-2016), Ultramaroon (12-11-2016)
Old 12-10-2016, 10:45 PM   #32
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I don't think they are saying to change the fluid to fix it but to see if there's metal in it and to remove anything to do further damage.
You're right, the tranny itself is a big mystery to most humans. It's an oddly shaped box of magic and the stick is the wand.
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
Spartarus (12-11-2016), Ultramaroon (12-11-2016)
Old 12-11-2016, 05:56 AM   #33
DJCarbine
Thupercharged
DJCarbine's Avatar
I have never owned an automatic vehicle, and I've gone through maybe 7 or so
Plenty of car enthusiasts can drive or have a willingness to learn manual, but there are a lot more people who view their car as a tool and the easiest it gets the job done, the better. Can't fault that.
2013 FRS
Vortech V3 11psi
The Following 2 Users Say Thank You to DJCarbine For This Useful Post:
Old 12-27-2016, 09:35 AM   #34
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Thanks --
Life is too short to worry about little things like this for me. Thankfully used transmissions for this car are cheap! Either way, I'll monitor it and act appropriately.
ajcarson11 is offline   Reply With Quote
Old 12-27-2016, 11:09 AM   #35
Teseo
Drives: frs
Sorry the urge beat me. Still have grinding noises when driving normal ?
Teseo is online now   Reply With Quote
Old 12-27-2016, 11:12 AM   #36
FX86
be glad you blew a synchro and not a tranny
The Following 3 Users Say Thank You to FX86 For This Useful Post:
geezerbrzeezer (12-27-2016), gramicci101 (12-27-2016), guybo (12-27-2016)
Old 12-27-2016, 03:08 PM   #37
renfield90
The Stig's German cousin
I've had light crunches come and go with this transmission, especially early on. Honestly I wouldn't worry until it makes really bad noises. There are no shortage of "wrecked while drifting" twins in junkyards with perfectly good transmissions you can use when yours fails after 100k or whatever.
Change your fluid in case you got metal bits floating around and move on.
Old 12-27-2016, 03:43 PM   #38
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Okay, had to admit, that one took me a minute or so. Still chuckling.
geezerbrzeezer is offline   Reply With Quote
Old 12-27-2016, 04:16 PM   #39
Hey, geezerbrzeezer ....... ya wanna translate @FX86 's funny for me ..... he and I are on two different wavelengths ......
Thanks,
Synchro issue? and Dealership woes. lextrueno Issues | Warranty | Recalls / TSB 31 05-28-2017 03:16 PM
Synchro issue zypher10 Issues | Warranty | Recalls / TSB 10 02-18-2016 01:56 PM
Double Clutch vs Synchro wear Concorazon Engine, Exhaust, Transmission 72 12-10-2015 04:16 PM
5th gear synchro harshness? Subie Issues | Warranty | Recalls / TSB 28 05-29-2013 05:22 PM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 12:05 PM
