Old 12-07-2016, 11:41 AM   #43
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I haven't had one built, but to get a built block and heads from Fullblown (or MAP Performance or similar) is just about $6K, + shipping cost + cost of removing your engine and sending it as a core (plus the money you lost because you didn't sell it), plus shipping again, plus whatever money is added to assembling the built engine, it all adds up to close to $10K.
After that, you're still left to deal with the glass trans, whose packages to build start at $6K (only to be rated at 350 tq), and can go as high as $20+K, or need to buy a T56 or similar plus the fab work to get it mated to this motor, plus custom driveshaft, custom mount, etc... add another minimum $6K....
Basically, you add all of that money, plus the money you can get selling your your motor, trans and other mods you have bought that work, and you can swap an LS or any other motor to the car and make more power and have it more reliable...
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
D_Thissen (12-21-2016), olsonpg (12-07-2016), Teseo (12-21-2016)
Old 12-07-2016, 12:17 PM   #44
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by x808drifter View Post
If money was no object and you wanted NA....
http://www.junauto.co.jp/sale/jun-sy.../index.en.html
I'd buy this thing in a heart beat if money was no object.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Teseo (12-21-2016)
Old 12-07-2016, 02:48 PM   #45
celek
Resident Gear Head
celek's Avatar
Originally Posted by jsimon7777 View Post
Cool story, Tom Celek.
As it was said in jest your Selleck reference shows impressive cognitive accuracy ,dating yourself.
celek is offline   Reply With Quote
Old 12-07-2016, 02:52 PM   #46
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
EAGLE5 (12-07-2016), wparsons (12-08-2016), xkalelx (12-21-2016)
Old 12-07-2016, 03:26 PM   #47
celek
Resident Gear Head
celek's Avatar
Too much but thats not the point
The Following User Says Thank You to celek For This Useful Post:
Leonardo (12-07-2016)
Old 12-07-2016, 03:36 PM   #48
[ame="https://www.youtube.com/watch?v=-Xoxdr0m2os"]Burt Reynolds Mustache.3gp - YouTube[/ame]
Old 12-08-2016, 09:59 PM   #49
choi0706
Drives: t
Originally Posted by wise345 View Post
Say just rods and Pistons. I'm more curious as to labor costs. Part costs are easy to find out
ask DD performance research,they're in tx.
choi0706 is offline   Reply With Quote
Old 12-09-2016, 01:07 PM   #50
kch
Senior Misanthrope
kch's Avatar
Or PRT Performance in Dallas (Lewisville). They're much closer to him, and have done several FA20s.
The Following User Says Thank You to kch For This Useful Post:
weederr33 (12-09-2016)
Old 12-09-2016, 02:22 PM   #51
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Pretty inexpensive if using basic forged components and simply labor. It gets more expensive if you are looking for more experienced builders and better parts.
CounterSpace Garage is offline   Reply With Quote
The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post:
Boris_Petrov (08-29-2019), celek (12-09-2016), Teseo (12-21-2016)
Old 12-21-2016, 10:10 PM   #52
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Originally Posted by moto-mike View Post
As long as you keep a short block clean, QC all the parts, and take your time--they are actually pretty easy to do. Not the first time, but once you've done a few it is very routine. Clean, inspect, assemble, disassemble and check clearances, file rings, then reassemble. Really straight forward. Doing a flat 4 long block involves many alignment pins, two timing chains, head/lash clearances, resealing what must be about a hundred yards of silicone, then the tally of the multiple o-rings, VVT filters, pesky rear main seals, making sure all machine work is 100%...it's a lot more work. There's a reason most shops don't do whole long blocks--its much more liability.
Excited to be sending you 2 blocks after Christmas (well, one and a half lol). I havent been following motor data on the forums lately, are there any updates on fixing the rocker axles that can slide out and punch holes in rocker covers? Do you guys currently do anything to modify them?
TIA
Sam
xkalelx is offline   Reply With Quote
Old 12-21-2016, 11:11 PM   #53
Teseo
Drives: frs
Can you do a pessimist guess how much would cost? Asking because i want to build an engine capable of 8k-9k rpms reliable and use it daily. Im not looking crazy hp's
Old 12-22-2016, 06:54 AM   #54
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
You can't push this engine past 8200 reliably.
Oil pressure is the bottleneck, and can't be solved without a major redesign.
If you're not looking for more than 300-350 whp leave the engine stock. Do your clutch.
If you have a rocker failure at those RPM's, replace with a '14 or later engine.
You need boost or the powerband fails hard after 7400. Even then it's gonna be downhill after 7k.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 3 Users Say Thank You to Spartarus For This Useful Post:
Boris_Petrov (08-29-2019), Tcoat (12-22-2016), Teseo (12-22-2016)
Old 12-22-2016, 09:35 AM   #55
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
TIA
Sam
Awesome! We just finished up our new engine room so we can keep up with the demand.
As for the rocker axles, we have never seen that happen. What we've seen is rockers being ejected completely intact. This is a result of valve float and not anything deficient with the rocker assembly. When the valve spring cannot keep up you end up getting a large amount of valve lash and the rocker is no longer held in place. Then if you get unlucky it will be ejected. In theory if that happens enough the rocker axle may start to walk out of the rocker itself, which is maybe what happened in that isolated case we keep hearing about on the internet. But the solution is to use adequate spring pressure, and not necessarily do anything to the rocker.
Xero-Limit is offline   Reply With Quote
The Following 4 Users Say Thank You to Xero-Limit For This Useful Post:
Boris_Petrov (08-29-2019), Icecreamtruk (12-22-2016), Teseo (12-22-2016), xkalelx (12-22-2016)
Old 12-22-2016, 10:09 AM   #56
xkalelx
xkalelx's Avatar
Outstanding @moto-mike. Will definitely be selecting good springs to upgrade to as well as the oil pump as you mentioned earlier in the thread.
Built engine - GEN-2 GTX3076r Kris86 Forced Induction 242 05-05-2024 09:15 AM
Blown engine. Built time? Theratt1 Engine, Exhaust, Transmission 19 02-27-2016 11:41 PM
Boost pressure for built engine ChrisD Forced Induction 75 01-06-2016 01:24 PM
Built engine question 86 driver Engine, Exhaust, Transmission 13 09-10-2015 11:16 PM
Anyone has Stroked and Built FA Engine yet ? Whitigir Engine, Exhaust, Transmission 11 03-14-2014 05:31 PM
