#43 |
I Love custom Turbo kits
Drives: Limited BRZ
I haven't had one built, but to get a built block and heads from Fullblown (or MAP Performance or similar) is just about $6K, + shipping cost + cost of removing your engine and sending it as a core (plus the money you lost because you didn't sell it), plus shipping again, plus whatever money is added to assembling the built engine, it all adds up to close to $10K.
After that, you're still left to deal with the glass trans, whose packages to build start at $6K (only to be rated at 350 tq), and can go as high as $20+K, or need to buy a T56 or similar plus the fab work to get it mated to this motor, plus custom driveshaft, custom mount, etc... add another minimum $6K.... Basically, you add all of that money, plus the money you can get selling your your motor, trans and other mods you have bought that work, and you can swap an LS or any other motor to the car and make more power and have it more reliable...
#44 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
| The Following User Says Thank You to weederr33 For This Useful Post: | Teseo (12-21-2016) |
#45 |
Resident Gear Head
As it was said in jest your Selleck reference shows impressive cognitive accuracy ,dating yourself.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
#46 | |
Country Boy 4 Life
via Imgflip Meme Generator
#47 | |
Resident Gear Head
| The Following User Says Thank You to celek For This Useful Post: | Leonardo (12-07-2016) |
#48 |
[ame="https://www.youtube.com/watch?v=-Xoxdr0m2os"]Burt Reynolds Mustache.3gp - YouTube[/ame]
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Leonardo (12-07-2016) |
#49 |
Drives: t
#50 | |
Senior Misanthrope
| The Following User Says Thank You to kch For This Useful Post: | weederr33 (12-09-2016) |
#51 |
Drives: Subaru BRZ / Toyota 86 Experts
Pretty inexpensive if using basic forged components and simply labor. It gets more expensive if you are looking for more experienced builders and better parts.
| The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post: |
#52 | |
Drives: 2013 BRZ black
TIA Sam
#53 |
Drives: frs
Can you do a pessimist guess how much would cost? Asking because i want to build an engine capable of 8k-9k rpms reliable and use it daily. Im not looking crazy hp's
#54 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
Oil pressure is the bottleneck, and can't be solved without a major redesign. If you're not looking for more than 300-350 whp leave the engine stock. Do your clutch. If you have a rocker failure at those RPM's, replace with a '14 or later engine. You need boost or the powerband fails hard after 7400. Even then it's gonna be downhill after 7k.
There are many ways to displace.
-Spartarus |
| The Following 3 Users Say Thank You to Spartarus For This Useful Post: |
#55 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
As for the rocker axles, we have never seen that happen. What we've seen is rockers being ejected completely intact. This is a result of valve float and not anything deficient with the rocker assembly. When the valve spring cannot keep up you end up getting a large amount of valve lash and the rocker is no longer held in place. Then if you get unlucky it will be ejected. In theory if that happens enough the rocker axle may start to walk out of the rocker itself, which is maybe what happened in that isolated case we keep hearing about on the internet. But the solution is to use adequate spring pressure, and not necessarily do anything to the rocker. |
| The Following 4 Users Say Thank You to Xero-Limit For This Useful Post: |
#56 |
Outstanding @moto-mike. Will definitely be selecting good springs to upgrade to as well as the oil pump as you mentioned earlier in the thread.
| Built engine - GEN-2 GTX3076r | Kris86 | Forced Induction | 242 | 05-05-2024 09:15 AM |
| Blown engine. Built time? | Theratt1 | Engine, Exhaust, Transmission | 19 | 02-27-2016 11:41 PM |
| Boost pressure for built engine | ChrisD | Forced Induction | 75 | 01-06-2016 01:24 PM |
| Built engine question | 86 driver | Engine, Exhaust, Transmission | 13 | 09-10-2015 11:16 PM |
| Anyone has Stroked and Built FA Engine yet ? | Whitigir | Engine, Exhaust, Transmission | 11 | 03-14-2014 05:31 PM |
