Old 12-18-2016, 12:00 PM   #1
max20s14
Drives: 14' Raven M/T - 02' is300
Possible problem after suspension install?
Installed springs, spc lcas and front camber bolts.
For the rear I set them to max positive camber and the front to max negative camber and torqued to spec.
I tightened the strut bolts with a pass through wrench and an Allen key to hold the shaft still while the car was on the ground until it was snug.
Now the car will pull left then right while driving I dont know if unstable is the word for it. I was afraid to take it over 30. The suspension isn't making any noises at all, so I dont think anything came loose..
I plan on getting an alignment Monday. So I am hoping that fixes it.
I am hoping the alignment is just wacked. Are there other possibilities?
max20s14 is offline   Reply With Quote
Old 12-18-2016, 12:14 PM   #2
byun
byun's Avatar
Drives: 2015 BRZ CWP
The alignment specs are way out of wack causing it to feel unstable and scary. Baby it to the alignment shop and it will be ok. I was scared to go over 40 when I did mine but got it to be shop and all was fixed.
byun is offline   Reply With Quote
Old 12-18-2016, 12:18 PM   #3
max20s14
sweet. Im just paranoid I messed something up. haha
Old 12-18-2016, 05:50 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
Anytime you change suspension parts, get it re-aligned, there is no way to put it back exactly the way it was.
Old 12-19-2016, 12:21 PM   #5
Vital
Drives: 2015 BRZ
What springs did you go with? Let us know if the alignment was able to resolve the issue
Old 12-19-2016, 01:15 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Alignment or something is loose. Toe is probably pretty wonky making it feel that way though
Old 12-19-2016, 01:18 PM   #7
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
agreed-- since you've done a number of things at the same time, your alignment is probably pretty out of whack and should feel back to normal/much better after alignment is done
asdf is offline   Reply With Quote
Old 12-19-2016, 01:43 PM   #8
wparsons
wparsons's Avatar
If you set the rear to max positive camber, you probably had some rear toe out. Squirelly would be an understatement.
flickr
strat61caster (12-19-2016)
Suspension problem Border7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-17-2014 05:03 PM
I need info and help with suspension problem kkkirbyyy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-26-2013 11:37 PM
HELP kw coilover top hat install problem autoCAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-18-2013 10:55 PM
Revworks UEL Install Problem Admired Engine, Exhaust, Transmission 3 10-07-2013 10:37 PM
Problem Headlights after HID Install imravenit Cosmetic Modification (Interior/Exterior/Lighting) 2 09-30-2012 08:18 AM
