Old 11-22-2016, 06:39 PM   #29
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
You don't have to jam it into the floorboard to get the clutch to disengage.
The bite point is way up ^here^.
Only have to press it far enough to get the job done.
Old 11-22-2016, 07:11 PM   #30
cat94
Drives: '17 86
So essentially, any movement before the biting point (when releasing the clutch) does absolutely nothing?
cat94 is offline   Reply With Quote
Old 11-22-2016, 08:51 PM   #31
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
It engages the clutch.
And don't ride the clutch, get your foot off of it when not shifting. Wears out your throwout bearing. Keep your foot off when not shifting. Don't sit at lights with your foot on the clutch.
Old 11-22-2016, 09:29 PM   #32
cat94
Drives: '17 86
Not that I'd ever do this, but that means if I let out the clutch a couple inches before the biting point, then floor it (car won't be moving), I'm still burning the clutch? -- more of a technical question rather than a practical one
Old 11-22-2016, 09:36 PM   #33
Sapphireho
Famous Potatoes
Sapphireho's Avatar
You're fine. Go for it.
Old 11-22-2016, 09:38 PM   #34
Only if it is touching the flywheel. If touching at all though it will burn in a hurry.
Old 11-22-2016, 09:42 PM   #35
Sapphireho
Famous Potatoes
Sapphireho's Avatar
He needs to burn it a bit to learn. I know it has been YEARS ago for us. He's on the right track. More seat time and he will be a pro!
Old 11-22-2016, 09:42 PM   #36
cat94
Drives: '17 86
Cool, I'll let you know how it goes
Hm.. only one way to find out where it starts touching the flywheel...
Old 11-22-2016, 09:45 PM   #37
You do not need to find out while flooring it though.
cat94 (11-23-2016)
Old 11-22-2016, 09:48 PM   #38
Sapphireho
Famous Potatoes
Sapphireho's Avatar
He will quickly learn to back off
Old 11-22-2016, 09:48 PM   #39
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I like the direction of this thread; perhaps we can merge it with the "What you HATE the most on your FR-S/BRZ/GT86/FT86?" thread by having someone burn their clutch till it is slipping really bad and see if the gear indicator is affected!!!
nextcar is offline   Reply With Quote
The Following 3 Users Say Thank You to nextcar For This Useful Post:
cat94 (11-23-2016), Sapphireho (11-22-2016), Tcoat (11-22-2016)
Old 11-22-2016, 10:03 PM   #40
LOL!
Oh wait, now Cat will ask "What gear indicator?"
Old 11-23-2016, 01:06 AM   #41
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Yeah it's scrapping in there.
I just got my act SB7 hdss in today and I'm scooting the seat further up to have better leverage till I'm comfortable and flexible with how I sit and depressing the clutch I'll reposition when I'm used to the bitting point. Till than the goal is to be comfortable when pushing down the clutch all the way and releasing after locked in gear
turtlefeeder is offline   Reply With Quote
Old 11-23-2016, 02:53 AM   #42
TelMinz
Rotary for the win
Drives: BRZ, FD3S RX7
I started looking into this because I noticed that sometimes when I shift, the clutch has maybe 0.5 - 1cm of travel left that I'm not using and I don't want to end up unnecessarily damaging anything.
If anyone has any thoughts or advice, I'd really appreciate it.
If you hear grinding noises when you shift you might want to try pressing it further. If not you should be good.
You could also try going in reverse, then coming to a complete stop, then quickly pressing the clutch and shift into gear. If it grinds then the clutch didn't disengage all the way.
"Behold, my field of phucks, lay thein eyes upon it, and notice, tis' barren."
TelMinz is offline   Reply With Quote
Whining noise when pressing clutch? cupcake917 Issues | Warranty | Recalls / TSB 14 03-12-2019 02:49 PM
Upgraded Clutch now seems like TOB is pressing on pressure plate when not depressed. Rybot Issues | Warranty | Recalls / TSB 35 03-06-2016 09:23 PM
clutch won't fully engage/8000 miles small dent stockscionfrs Scion FR-S / Toyota 86 GT86 General Forum 2 10-14-2014 12:06 PM
Car sensing clutch fully engaged when its not// 504 Issues | Warranty | Recalls / TSB 1 09-16-2014 11:02 AM
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch tanner BRZ First-Gen (2012+) — General Topics 26 06-03-2014 09:24 PM
