Old 11-21-2016, 07:16 PM   #57
cjny
Drives: 2016 BRZ
As it happens, I just put my brand new aluminum wheels on the car last Saturday. Each lug was torqued with a Snap-On torque wrench, which I trust (because it was so expensive ). I left the wrench set to 89 Ft-lb. After driving about 70 miles I checked each lug. Out of 20 lugs, only 14 were still at spec. Six lugs needed a noticeable (but unmeasured) bit of re-torquing.
cjny is offline   Reply With Quote
Old 11-21-2016, 07:33 PM   #58
Originally Posted by justatroll View Post
And I have a torque wrench that is JUST for my wheels. It is set at 92 lbs
That's bad for the wrench. Breakaway torque wrenches need to be stored unloaded.
But you're an EE so you get a pass.
johan (11-22-2016), justatroll (11-21-2016), Yardjass (11-22-2016)
Old 11-21-2016, 09:24 PM   #59
"new fangled alloy wheel" Like the ones in my avatar on my vintage race car?
Welp, grasshopper, I reckon that depends on where you started from......
justatroll (11-22-2016)
Old 11-22-2016, 11:55 AM   #60
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Yeah, if this is the case, that torque wrench definitely needs a calibration check at least.
Yardjass is offline   Reply With Quote
The Following User Says Thank You to Yardjass For This Useful Post:
Ultramaroon (11-22-2016)
Old 11-27-2016, 01:52 PM   #61
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Ok, just for fun I went out to the garage.
I took out my wheel torque wrench that is left at 92 ft-lbs (pretty much all the time).
I also took out my "good" torque wrench that is stored unloaded.
I turned DOWN the 92 ft-lbs to 70 ft-lbs.
I set my unloaded "good" TR to 70 ft-lbs
I then conencted them together and "calibrated".
Guess what?
They BOTH click at precisely the same setting even after going up & down a few pounds.
So you guys might be right!
My "loaded" torque wrench could be off maybe more than 0.1 ft-lbs!!!
Oh No! My wheels are going to fall off!
BTW - I am torque wrench certified by Lockheed Martin & NASA for use on flight hardware, so I have almost as much knowledge about the subject as your average internet desk-jockey expert.
I know that storing a TR loaded will cause an error over time, but the magnitude of the error is insignificant for a wheel lug bolt.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following 2 Users Say Thank You to justatroll For This Useful Post:
johan (11-27-2016), Ultramaroon (11-27-2016)
Old 11-27-2016, 01:59 PM   #62
Your good wrench is out of cal.
#totaled
justatroll (11-27-2016), p1l0t (11-29-2016)
Recomend torque wrench jflogerzi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 06-08-2017 06:38 AM
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 04:02 PM
torque wrench dcfr CANADA 13 05-15-2014 01:28 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 12:46 AM
Torque wrench... Vendors welcome Freeman Off-Topic Lounge [WARNING: NO POLITICS] 8 01-23-2013 05:30 AM
