Old 11-20-2016, 01:33 AM   #1
redwing634
Drives: 2013 Scion FR-S (Firestorm)
Torque wrench necessary for putting on wheels?
Just wondering what common practice is on this forum. Hand tighten or torque wrench?
redwing634 is offline   Reply With Quote
Old 11-20-2016, 01:47 AM   #2
ryoma
ryoma's Avatar
hand tighten while in the air (with a tire iron) and then torque wrench on the floor
Old 11-20-2016, 01:51 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1
Old 11-20-2016, 01:57 AM   #4
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
People get by without torque wrenches every day. If you use common sense when tightening your lug nuts you'll be fine. If you want to have peace of mind when you drive though, invest in a torque wrench.
Redstar is offline   Reply With Quote
The Following User Says Thank You to Redstar For This Useful Post:
Tcoat (11-20-2016)
Old 11-20-2016, 02:10 AM   #5
humfrz
Well, I've tightened hundreds, maybe thousands, of lug nuts in my 73 years, never used a torque wrench and never had a wheel fall off.
Using a "cross" type lug wrench, cross rotating the tightening down of the DRY lug nuts, with the last tightening being two squeaks, worked for me up through the age of 60. After 60, it was two squeaks and a grunt.
(disclaimer - works for DRY lug nuts only)
If you wish to put that anti-seize stuff on the studs, it might be best to use a torque wrench.
humfrz
Cole (11-20-2016)
Old 11-20-2016, 02:16 AM   #6
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Ask to borrow a buddies torque wrench one time.
Torque your wheels with both the TR and you own personal breaker bar, star wrench , etc.
You will be able to feel what is right after that.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
humfrz (11-20-2016)
Old 11-20-2016, 07:24 AM   #7
p1l0t
p1l0t's Avatar
The TQ wrench is the right thing to do. You might be successful hand tightening... might being the operative word. Remember the bigger risk is almost always being too tight and breaking something. (Although too loose can be bad too)
Old 11-20-2016, 08:09 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You can get a torque wrench and a socket and it's not all that expensive. If you under-torque, obviously that's bad. But over-torquing can stretch threads and if you REALLY over-do it, warp your rotors.
That said, people tighten lugnuts using the German torque spec everyday and do fine.
The Following User Says Thank You to guybo For This Useful Post:
p1l0t (11-20-2016)
Old 11-20-2016, 08:55 AM   #9
redwing634
Can you recommend a decent affordable torque wrench? I see that there are some popular ones on Amazon in the $40-60 range but I'm unsure if those would do the trick.
Old 11-20-2016, 09:23 AM   #10
D_Thissen
D_Thissen's Avatar
Something like this would work if you just using it occasionally.
http://www.harborfreight.com/1-2-hal...rench-239.html
Old 11-20-2016, 10:00 AM   #11
Gunman
Drives: 2019 Mazda Miata RF
I use this one, watch for sales:
https://m.lowes.com/pd/Kobalt-1-2-in...Wrench/3381202
Gunman is offline   Reply With Quote
Old 11-20-2016, 10:17 AM   #12
Warp your rotors? Putting lug nuts on by hand? That is hilarious!
Where I work we make 4 million rotors a year. Every year we get about 6 warranty returns for heat warping (why not 4 or 8 I will never understand) we have never once received a cold warped rotor back.
JazzleSAURUS (11-21-2016), strat61caster (11-20-2016)
Old 11-20-2016, 10:28 AM   #13
guybo
Huge E85 fan!
guybo's Avatar
[IMG][/IMG]
Note the REALLY part. It has happened. Not having seen a pic of the OP, he may be a huge body builder, I don't know.
Old 11-20-2016, 10:41 AM   #14
Still tightening a flat surface against a flat surface. You will snap a lug bolt before you will warp a rotor. People may think they warped one tightening it but it is just not realistic. Unless of course you are using some flimsy ass bargain basement ones I guess.
Qadthane (11-20-2016), strat61caster (11-20-2016)
Recomend torque wrench jflogerzi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 06-08-2017 06:38 AM
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 04:02 PM
torque wrench dcfr CANADA 13 05-15-2014 01:28 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 12:46 AM
Torque wrench... Vendors welcome Freeman Off-Topic Lounge [WARNING: NO POLITICS] 8 01-23-2013 05:30 AM
